#21
Thing is
though, as far as I know, none have crashed or been repaired to evaluate for their crashworthiness or repairability VS. other models. Not true. Janusz Centka crashed one in Finland and he walked away from it without a scratch, he was just bruised up. The control surface play is certainly an issue. Someone should ask the factory about that. Is it correctable or not? Was it down to BB or is it fleet wide? D-2 was tested quite extensively in Poland by Aviation Institute and found no problem with that. In your discussions you forgetting that all gliders manufactured in Europe are made to EASA standard, not just the German gliders. The same regulations are applicable to D-2 as well as to V-2 or ASG-29. Jacek Pasco, WA |
![]() Quote:
![]() The trend in European sailplane crashworthiness seems to have been to supplement the primary cockpit structure with structural elements of very limber fibers of aramid (such as Kevlar) or advanced polyethylenes such as Spectra or Dyneema. After the carbon gives up the ghost, these very stretchy fibers absorb a lot of energy as they load up into their plastic range, stretch out, and tear free of the resin matrix. The penalty for such a system seems to be unavoidable extra weight. Thanks Bob. Good points. |
On Aug 6, 11:33*pm, wrote:
Thing is though, as far as I know, none have crashed or been repaired to evaluate for their crashworthiness or repairability VS. other models. Not true. Janusz Centka crashed one in Finland and he walked away from it without a scratch, he was just bruised up. The control surface play is certainly an issue. Someone should ask the factory about that. Is it correctable or not? Was it down to BB or is it fleet wide? D-2 was tested quite extensively in Poland by Aviation Institute and found no problem with that. In your discussions you forgetting that all gliders manufactured in Europe are made to EASA standard, not just the German gliders. The same regulations are applicable to D-2 as well as to V-2 or ASG-29. Jacek Pasco, WA Diana 2 was tested by two test pilots, past PZL-SZD test pilots. Testing was done in ideal conditions. Pilots who flown/own Diana 2 were few times in trouble during the flight when they lost control. Kawa lost control on RP during final glide and Ghostner was in spiral during the flight without chance to correct turning. At last he used highest forces but was ready to jump from it away. At last Kawa has trouble with blocked airbrakes in Chille and was lucky that it was before start line near arifield. About Diana 2 in desing and production faults know Polish Aviation Institute, Europan EASA and Australian CASA. It is reason why Diana 2 is without Certificate, flying on Polish registration only (two are in USA as Experimental Category). It is reason why the life time is limited to 12000 hours. So little correction not only for Jacek Kobiesa who is originaly Polish and proud of Polish products ![]() Cheers, Hana |
Thing is though, as far as I know, none have crashed or been repaired to evaluate for their crashworthiness or repairability VS. other models. Not true. Janusz Centka crashed one in Finland and he walked away from it without a scratch, he was just bruised up. The control surface play is certainly an issue. Someone should ask the factory about that. Is it correctable or not? Was it down to BB or is it fleet wide? D-2 was tested quite extensively in Poland by Aviation Institute and found no problem with that. In your discussions you forgetting that all gliders manufactured in Europe are made to EASA standard, not just the German gliders. The same regulations are applicable to D-2 as well as to V-2 or ASG-29. Jacek Pasco, WA Diana 2 was tested by two test pilots, past PZL-SZD test pilots. Testing was done in ideal conditions. Pilots who flown/own Diana 2 were few times in trouble during the flight when they lost control. Kawa lost control on RP during final glide and Ghostner was in spiral during the flight without chance to correct turning. At last he used highest forces but was ready to jump from it away. At last Kawa has trouble with blocked airbrakes in Chille and was lucky that it was before start line near arifield. About Diana 2 in desing and production faults know Polish Aviation Institute, Europan EASA and Australian CASA. It is reason why Diana 2 is without Certificate, flying on Polish registration only (two are in USA as Experimental Category). It is reason why Diana 2 life time is limited to 1.200 hours. So little correction not only for Jacek Kobiesa who is originaly Polish and proud of Polish products ![]() Cheers, Hana |
Could I please get more details on this life limit? Who imposes it?
And how does one find out about it before buying a used glider? Neither the manufacturers web site nor the report in Soaring mention it. It would be easy to make a colossal mistake when buying one! Thanks It is reason why Diana 2 life time is limited to 1.200 hours. Cheers, Hana |
On Aug 10, 2:29*am, Martin wrote:
Could I please get more details on this life limit? *Who imposes it? And how does one find out about it before buying a used glider? Neither the manufacturers web site nor the report in Soaring mention it. *It would be easy to make a colossal mistake when buying one! Thanks Hi Martin If the glider is without EASA Certification it is general rule. But I think in USA it should be different. What I know all Diana's are there flying in Experimental category. It means as "home build" gliders and the responsibility is on the pilot. It was funny when I was handover glider to Beres back for repair (which he didn't fulfill but found a buyer instead of it) the Polish Aviation Authority ULC inspector (young arrogant boy, who answered me to question why he didn't signed protocol before first test flight that he signed an internal protocol which have producer) he told me that all Diana’s are prototype and all Diana’s are experimental so if anything happen it is on pilot and not on producer's or his responsibility. You can read it also in the document below but what is wrong that you obtain glider and you are not informed about inspection. It means, If it exist and the ULC inspector is agree it can do first flight if he simply signed other document. But it was without signature. It looks the test pilot flown it without signature of ULC official technical. See here other document where is signature of CIAB Engineer Beres http://picasaweb.google.com/diana2.s...49199072766050 It is official document which needs all test pilots before first flight on a glider which was produced. You can read there the limit 1200 hours which means, after it it have to came back to producer who can prolong the time life according EASA Certificate if it exist. If not, you can't prolong life time.. You can read therethat the glider was build according JAR-22 rules but in Australia CASA Engineer found a lot of differences of it. Here is short report which prepared Australian engineer. http://picasaweb.google.com/diana2.s...46666089458690 The full version is with approx. 50 in design and in production faults, which didn't correspond with EASA/JAR-22 rules. The so called “valid technical documentation” was also funny. It didn't correspond with this serial number at all. To this point producer told me that it is a general documentation and if he wrote on the top of it that it is for the serial number 003 it is not necessary to put there every time different details for different serial numbers, because it is serial production and all gliders are identical. To EASA Certificate. Producer promised that it will be before handover, after it that it will be before it came to Australia, after it... Only promises. There was trouble that we were in rush to send glider for expedition to Australia. Originally we ordered in October 2005 second production number with delivery time 16. March 2006. When we came visit him from Australia we were surprised. There was a glider ready to go but for other customer. He told us that our one will be s/n 003 and it will be ready at end of May. At last we were there some time in August and glider was just ready so we offered container. It was at end of August when it was again clear that the delivery time is unknown. Timing was not fulfill again and we has to move container back on truck and wait if he will fulfill another promise for next week. He told that he is in trouble with test flight, at first test pilot has holiday and as second the ULC inspector.... (funny should be opposite). Not sure if he was not waiting also for serial number 000 prototype when it came from contest flying – means “BB” or for photographer, because one week before ended September he organized test flights with promotional action. The serial number did 2 flights, one 15 minutes and second 47 during which was flying together with factory serial number 000 and they took promotional pictures for Diana 2 calendar.. Payment of this flights were on customer/our account. http://picasaweb.google.com/diana2.s...910057801 714 Container was offered again before the trip but when we came back in our country with glider but we found message that they are sorry but they have not capacity on ship in this moment. So was necessary wait few days for this reason. Handover was done in thrust to producer, who was my long therm friend. So just basic thinks with his words that it is best piece which he produced till yet... (may be some differences between pieces anywhere? ![]() document as well ![]() How it continue was written. Promises only and at last he was deaf or mystifying or lying. So don't be awaiting that producer's web site will promote something which is about real situation.. It was this why I started to be not happy with promotion of Jacek Kobiesa here. What he wrote looks as that Diana 2 having EASA Certificate and is without troubles. We “meet” each other in past on forums as well. Greetings, Hana PS. Jacek Kobiesa just wrote on Polish forum that my English is not best and Polish as well, that I didn't understand his words here... My English is not best, Polish a bit better ![]() meaning.... It was written as in main origin of Diana 2 technical documentation which was in English and understand by English (If Australian) engineer, that that Diana 2 is with certificate. So question from Mike was: Why we have to do an experimental registration? ![]() |
#29
Just a small correction. The USA Experimental category of a Diana is "Racing/Exhibition" not "Homebuilt." There is a difference.
To be considered "Homebuilt" at least fifty percent of the construction must be completed by an amateur builder. Normally this means the aircraft is delivered as a "kit" and assembled and flown by the builder. However, many have been built directly from a set of plans. (Woodstock, Duster, Tern, BG series, etc.) The most popular US "Homebuilt" series of sailplanes were designed by Dick Schreder. http://www.soaridaho.com/Schreder. I fly one; however, I am its' third owner and wasn't involved in its' construction. Wayne HP-14 "6F" http://tinyurl.com/N990-6F "HZ" wrote in message ... On Aug 10, 2:29 am, Martin wrote: If the glider is without EASA Certification it is general rule. But I think in USA it should be different. What I know all Diana's are there flying in Experimental category. It means as "home build" gliders and the responsibility is on the pilot. |
#30
On Aug 10, 3:53*pm, "Wayne Paul" wrote:
Just a small correction. *The USA Experimental category of a Diana is "Racing/Exhibition" not "Homebuilt." *There is a difference. * To be considered "Homebuilt" at least fifty percent of the construction must be completed by an amateur builder. *Normally this means the aircraft is delivered as a "kit" and assembled and flown by the builder. *However, many have been built directly from a set of plans. (Woodstock, Duster, Tern, BG series, etc.) The most popular US "Homebuilt" series of sailplanes were designed by Dick Schreder.http://www.soaridaho.com/Schreder. *I fly one; however, I am its' third owner and wasn't involved in its' construction. Wayne HP-14 "6F"http://tinyurl.com/N990-6F "HZ" wrote in ... On Aug 10, 2:29 am, Martin wrote: If the glider is without EASA Certification it is general rule. But I think in USA it should be different. What I know all Diana's are there flying in Experimental category. It means as "home build" gliders and the responsibility is on the pilot. Thank you for correction. They informed me as this in factory.. Please, how it is with this "Racin/Exhibition" Category? Who is responsible for glider? Also and "Operator" or only pilot, means needn't a operator. Thx, Hana |
NPR discussion on NAS | Neil Gould | Piloting | 9 | September 3rd 07 09:47 PM |
Good ILS discussion | NoneYa | Instrument Flight Rules | 2 | August 18th 07 08:12 PM |
Rules for the OLC (Discussion) | Hans L. Trautenberg | Soaring | 4 | August 18th 04 10:36 PM |
Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 08:04 AM |
Following the Eye Candy Discussion | Quilljar | Simulators | 2 | March 8th 04 12:40 AM |
