Have you ever seen a C-130 Hercules trying to do a hover over the runway ?
Old December 18th 04, 05:19 AM
Gord Beaman
"C.D.Damron" wrote:
"Gord Beaman" wrote in message
"C.D.Damron" wrote:
I don't know but it could have been after the a/c was on the deck
and even before with some futzing with the squat switch circuits
that normally prevent that. I've seen both of the tapes. How do
you know that they didn't use reverse?
I meant reversed pitch prior to touchdown, but I could be wrong. I recall
reading that they reversed pitch upon touchdown. I don't recall the source
being definitive.
Ok, thanks...
-Gord.
(use gordon in email)
Old December 18th 04, 05:28 AM
Larry
"Bob Moore" wrote in message
. 122...
"Larry" wrote
Uhm- Scuse me! I don't think I heard that right.
Aircraft landing on a carrier DO NOT use their brakes for any part of
the arrested landing. Once they come to a full stop (slowed by the
arresting wire) then and only then they use their brakes (as directed
by the Yellow Shirt) to hold position.
Larry...Uhm- Scuse us!
The topic is a C-130 making UN-arrested landings
on the Forrestal. I'll bet that he DID use the brakes.
Bob Moore
As described he http://www.cgaux.com/C-130carrierlanding.htm
One of the very few times brakes are used.
Larry
Old December 18th 04, 05:42 AM
Yofuri
Gord Beaman wrote:
"C.D.Damron" wrote:
"William W. Plummer" wrote in
message news:h7mwd.768167$8_6.703195@attbi_s04...
Iwan Bogels wrote:
There was a famous experiment to prove that a fully loaded C-130 could
land on a carrier. The roll-out was 270 feet. Thrust reversers were
used before it was on the deck. I'll bet those landings left something
to be desired for comfort. I think I can find a short video of the
landings and will be happy to post it if someone can tell me where.
I don't think that pitch was reversed in those trials.
-Gord.
Smoky Stover told me that they used pitch reverse, and that the squat
switches had been bypassed to allow it without WOW.
I never knew on how many of the landings they used it or not.
Rick
Old December 18th 04, 06:03 PM
Gord Beaman
-Gord.
Rick
Thanks Rick...
-Gord.
Old December 18th 04, 11:28 PM
Jake Donovan
More moons ago, Gator Chunning, after retiring from the Navy and heading up
Lockheed's Navy Projects division told me no mods were done to the prop
pitch. The only mods done were to the brakes, they installed new anti skid
brakes and a smaller nose gear. All external tanks were removed
The aircraft was taken directly out of the USMC stock, a KC130F, sent to
Lockheed for the mods. Then Lt., James Flately III was qualed in the
aircraft by Lockheed's chief test pilot, whose name escapes me right now.
There was a measured 40kt head wind over the bow during the trials. 21 full
unassisted landings and take offs were made before the end of the tests.
Flately was awarded a DFC.
All other stories about rocket assists, modified pitch, downward thrust are
all fairy tails.
Jake
PS On a lighter side - On the fuselage below the cockpit was painted "Look
Ma, no hook!"
"Yofuri" wrote in message
-Gord.
Rick
Old December 19th 04, 01:22 AM
Iwan Bogels
"Jake Donovan" schreef in bericht
news:223xd.4183$Qk5.3046@lakeread04...
up
skid
full
are
all fairy tails.
Jake
Hi Jake,
Thanks for explaining, but the original message had nothing to do with C-130
carrier landings. It was about a special project to liberate hostages in
Iran in 1980, by landing a C-130 on a soccer field in downtown Teheran. The
video is available at http://www.dappa.nl/crash.htm and as you will see it
has EVERYTHING to do with rocket assists and downward thrust. See for
yourself, it's an amazing video.
Nevertheless your project and 'mine' make me wonder how many other
undiscosed project have been around with the C-130.
Anyone ?
Cheers,
Iwan
Old December 19th 04, 04:15 AM
Yofuri
Jake Donovan wrote:
snip
all fairy tails.
Jake
Ma, no hook!"
-Gord.
Rick
Yep, stories do change over time:
http://www.globalsecurity.org/milita...ft/kc-130f.htm
Mine was heard at a meeting in 1969 when LCDR Bob Browning was chosen to
take a maintenance crew to get a Herc off the ice in Antarctica before
winter broke it up. It had taken off a wingtip on a snowbank. The crew
cleaned off the crunched metal, faired off the nub, and it flew out with
one wing 11 feet (IIRC) shorter than the other.
I have no idea how many feet it took on the opposite rudder pedal under
full power. Trim probably wouldn't quite handle it.
Rick
Have you ever seen a C-130 Hercules trying to do a hover over the runway ? Iwan Bogels Instrument Flight Rules 6 December 18th 04 12:03 AM
Hercules Engines Phil Miller Military Aviation 195 January 24th 04 09:02 PM
Hercules Engines Tarver Engineering Home Built 0 January 19th 04 11:05 PM
Hercules Engines B2431 Military Aviation 0 January 18th 04 12:00 AM
C-130 Hercules on a carrier - possible ?? Jan Gelbrich Military Aviation 10 September 21st 03 04:47 PM
