VFR Practise Approaches
Old September 30th 10, 01:16 AM posted to rec.aviation.ifr
Default VFR Practise Approaches
On Sep 29, 4:54*pm, Mike Adams wrote:
Back to the original question, are there any other cases (besides possibly the extremely offset localizer)
when you would not be able to track the ILS when doing a VFR straight-in approach?
Exactly like I said, in Bravo. If you intend to do a practice ILS
approach, I would hope you would want to pick it up at the IAF?
If you have been given instructions by ATC, approved straight in
approach, it's expected you make a reasonable beeline to the threshold
so ATC can maintain spacing. Part of that includes getting lined up
for the runway so yes, you can slide down the glide slope at will but
that hardly is a practice ILS approach!
If you are outside the IAF and it's between you and the threshold OR
OFFSET from the final approach course in a reasonable distance, sure,
knock your socks off but if it requires more then a significant
heading change from my nose pointed toward the threshold, I MYSELF
would get a clearance for that practice approach FROM THE CONTROLLER
in BRAVO airspace.
All ATC sees is your nose pointing away from the airport and you right
fully should get chewed out or asked what your intentions are since
your deviations may become an spacing issue for the controller AND THE
AIRPLANE BEHIND YOU.
Mx is clueless in the real world, he plays a game in MSFS and thinks
that MSFS simulates the real world.
On Sep 29, 5:17*pm, Mxsmanic wrote:
It doesn't sound like you spend a lot of time in Class B airspace, however.
Old September 30th 10, 01:26 AM posted to rec.aviation.ifr
CORRECTION TO THE ABOVE
The above should read.
that MSFS IS the real world.
On Sep 29, 5:16*pm, Mxsmanic wrote:
writes:
WRONG.
YOU OBVIOUSLY ARE NOT CONSIDERING THERE IS MORE TO A GLIDE SLOPE TO AN
ILS APPROACH IN RELATIONSHIP TO WHERE YOU ARE.
What?
EXACTLY WHAT I SAID.
Old September 30th 10, 11:17 PM posted to rec.aviation.ifr
On Sep 30, 1:36*pm, Mxsmanic wrote:
writes:
AND HOW MUCH TIME HAVE YOU SPENT IN BRAVO AIRSPACE AS PIC IN A REAL
PLANE???????????????????
I've spent hundreds of hours in it in simulation, and
SO YOU PRETEND YOU ARE SOMETHING YOU ARE NOT?????????? AND YOU STILL
FAILED TO ANSWER THE DIRECT QUESTION.
that's a lot more useful
as experience than nearly zero hours in real life.
WRONG AS YOU HAVE PROVEN BY YOUR REPLIES IN THIS THREAD.
Old October 1st 10, 09:01 AM posted to rec.aviation.ifr
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Mxsmanic wrote:
writes:
WRONG. I DO WHAT ATC WANTS.
If ATC doesn't give you any instructions, it is impossible to do "what ATC
wants." In Class B airspace, you must follow ATC instructions, but ATC won't
necessarily give any restrictive instructions unless traffic conditions
warrant them.
This is incorrect. You forget to take into account that ATC
doesn't need to talk to you at all. That in itself is restrictive. If
ATC tells you "Aircraft calling for Class B clearance remain outside of
Class B airspace", it is restrictive, even if they do not acknowledge
you directly. If ATC doesn't answer your call, you are to remain
outside of Class B until they do. If they don't answer, too bad.
But I fly in the real world to know this.
Nor do you, it seems.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
iD8DBQFMpZVVyBkZmuMZ8L8RAkHLAKDTsyj+6wktBVgEckgvfJ KFuviVfACgkm/t
V8PHdGg5aXl4f7V+tFCPd4k=
=9hgx
-----END PGP SIGNATURE-----
Old October 1st 10, 12:13 PM posted to rec.aviation.ifr
Mxsmanic
A Guy Called Tyketto writes:
I've already excluded that by considering only the case in which you are
cleared into the Class B, which makes the rest of your post moot.
  #29
Old October 1st 10, 12:48 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
of Class B airspace", it is restrictive, even if they do not
acknowledge
Answering you isn't enough, if ATC does not clear you into Class B airspace
you are to remain outside.
  #30
Old October 1st 10, 01:35 PM posted to rec.aviation.ifr
YOUR ORIGINAL POST WAS WRONG.
LAS approaches Ron Garret Instrument Flight Rules 10 March 28th 09 06:46 AM
My First GPS Approaches john smith Instrument Flight Rules 10 November 9th 04 09:14 PM
ILS PRM approaches Riddler Instrument Flight Rules 2 October 28th 04 12:37 PM
Channel News Asia: Taiwan Jets Practise Emergency Landings on Freeway Amid Tensions with China Dionaea muscipula Military Aviation 0 July 21st 04 08:18 AM
NDB approaches -- what are they good for? Dylan Smith Instrument Flight Rules 15 July 10th 03 09:15 PM
