Wanted: Transponder antenna
Old November 25th 03, 06:35 PM
Grandpa B.
Default Wanted: Transponder antenna
I'm starting the fabrication of a new boot cowl for the Champ project. The
transponder antenna got wiped off the bottom during the groundloop (no, I
didn't do it!), so I gotta get a new one.
I've seen the 'bargain' version in AS&S for $22 or so. Are they useful, or
should I spend the ~$60 for a decent one?
Anybody have one laying around that they no longer need?
Jon B.
Old November 25th 03, 09:36 PM
David O
Jon B.
I'll give you one anecdotal data point. I bought the $22 "TED"
transponder antenna from Aircraft Spruce a few years back. It seemed
well constructed and my transponder signal is apparently getting out
as I've had no complaints of dropouts from ATC.
David O -- http://www.AirplaneZone.com
Old November 25th 03, 10:34 PM
Paul Lee
There is nothing wrong with the $22 one. Only for fast birds,
you may want an aerodynamic shaped one.
Composite projects can even build the $22 jobs into wings, etc.
"Grandpa B." never.mind wrote in message ...
Jon B.
Old November 25th 03, 11:01 PM
Rich S.
"Paul Lee" wrote in message
m...
Hey! Don't forget us wood and fabric types. I was going to install mine
under my seat, but then I thought about possible radiation effects on the
family jewels. I mentioned this to my wife who poo-pooed my concern. So I
put it under her seat.
Rich S.
Old November 26th 03, 03:54 AM
David O
Rich S.
My transponder antenna is under my Long EZ pilot seat under an
aluminum ground plane disk with aluminum foil glued to the underside
of the seat as added protection for the "jewels". I don't know how
effective the shield is but I'm out of the kid making biz anyway
(hopefully).
Old November 26th 03, 04:05 AM
- Barnyard BOb -
Rich S.
Any new additions to the family since?
Barnyard BOb
Old November 26th 03, 04:24 AM
Rich S.
"- Barnyard BOb -" wrote in message
Rich S.
No, but after a long cross-country, I can use her as a night light. ;o)
Rich S.
Old November 26th 03, 04:42 AM
Paul Lee
AFAIK the tranponder antenna should be 8+ feet away from warm bodies.
"Rich S." wrote in message ...
m...
Rich S.
Old November 26th 03, 04:57 AM
Jerry Springer
And where would you be getting that information from? Don't know many small
single engine airplanes that would meet that requirement.
Jerry
. com...
Rich S.
Old November 28th 03, 08:03 AM
Paul Lee
Sorry. Don't remember the source. Had it when I was installing the
antenna. Suppose I could find it if I spend hours of searching,
but don't have time for it now - just remember it off hand.
But I think the 8+ feet refers to the body being in direct
path of the radiation pattern. If you place it in such a way that your
body is on the other side of the ground plane or on other side of a metal
shield you should be OK.
Jerry Springer wrote in message thlink.net...
Jerry
. com...
Rich S.
Nav antenna diplexers Paul Lee Home Built 6 October 30th 03 05:52 AM
transponder check? Russell Duffy Home Built 10 August 14th 03 11:36 PM
Foil antenna and carbon fiber BD5ER Home Built 11 August 6th 03 04:44 AM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 05:21 PM
Recommendation for Radio, transponder and Altimeter Ron Natalie Home Built 0 July 8th 03 03:40 PM
