Sydney,
What you have here is a pretty classic case of intermodulation interference. Judging from he results of your investigation (good work on that, by the way) I would say that the most likely cause is the frequency mixing ("heterodyning") of two very strong out-of-band signals in the "front end" of whatever radio you are listening to. Yes, it is possible that the mixing could be taking place in some corrosion of an antenna mounting or some such, but that is, in my opinion, far less likely. It's a good bet that at least one, and very likely both, of the very strong out-of-band signals is in the commercial FM broadcast band. There may be several such signals being broadcast at high power from the antenna farm. At this point the question is whether the interference poses a threat to safety or merely an annoyance. When the interference "breaks squelch while you are tuned to the TRACON freq are you still able to hear the controller when he/she transmits? It may be a good idea for you to notify the FAA about the problem. Further investigation may involve the use of a spectrum analyzer, not a tool you are likely to have laying around in the garage. If the Feds determine that the potential for intermodulation interference is a hazard they can take corrective measures, such as reassigning the TRACON frequency in the area to one that has a lower risk of interference from whatever signals are being transmitted from the antenna farm. -- -Elliott Drucker |
How close are you flying to the antenna farm? The field strength
decays exponentially with radial distance. Put another way, as you get close, you may be flying into a VERY strong field, outside the design parameters of the radios your using. The spectrum analyzer (if you can get one) will answer your inter mod products question. You might make friends with your local HAM group. Some of these guys may enjoy the hunt, an airplane ride, and have the high dollar equipment to do it. But I'm betting that the cause something simpler than that. The fact that you mentioned that they were AM broadcasts reminds me of the times I used to get AM radio on my telephone. In very high fields with amplitude modulation you can get what's often called "detection by overload". Any non-linear circuit element in your radio- front end through audio amp have all kinds of semiconductors which can "detect" and demodulate the AM broadcast if the signal is powerful enough. In the case of my telephone, the bridge rectifier that protected the polarity of the phone was the detector. If this turns out indeed to be the case, and you need to fly your plane into fields that are that strong, you might be able to get some relief with improved grounding, sealing radio case gaps with copper foil, a filter network right before the antenna enters the radio. |
"Mark Hickey" wrote in message
... (Jay) wrote: In very high fields with amplitude modulation you can get what's often called "detection by overload". Some people have reported picking up radio on their fillings in their teeth. I used to be able to turn OFF my car radio and STILL get a loud "bbBBBRRRRrrrrzzzz" every time the long range radar swept past my car You can get that sitting in the car on top of one of the car parks in Heathrow. Paul |
I would start by disconnecting the antennas from ALL of the receivers
or if the antenna does not have a separate connector then removing the receivers and using the hand held to detect the offending signal. If you inject a strong enough signal into the antenna input you force the receiver's RF amp into overload and it generates the intermod products and sends them back OUT the same antenna to be picked up by the other antenna's There is one brand of ELT that is infamous for this type of problem but I can not remember the model and brand. On 4 Nov 2003 06:01:30 -0800, (Snowbird) wrote: wrote in message .. . What you have here is a pretty classic case of intermodulation interference. Elliot, given what we did, is there a way to pinpoint what signals might be the source of the problem? Given the lat-long, is there a way to find out what antennas are located there? Is there something which might be a problem in our radios, which could be fixed? Yes, it is possible that the mixing could be taking place in some corrosion of an antenna mounting or some such, but that is, in my opinion, far less likely. Well, one of the things which we did when the problem started was take off all the easily-accessible antennae and clean the connectors and check their ground. They all looked very good, very well sealed and tight although the comm antennae didn't have as strong ground as I'd like at first. The only antennae we didn't check were the VOR/Glideslope because they're way up at the top of the horizontal stab. and a b**ch to get at. So unless it's the VOR antenna, I don't think corrosion in the antenna mounting is likely, either. At this point the question is whether the interference poses a threat to safety or merely an annoyance. When the interference "breaks squelch while you are tuned to the TRACON freq are you still able to hear the controller when he/she transmits? On one installed radio and the handheld, yes. On the other installed radio, the controller becomes very faint against a background of continued noise. It may be a good idea for you to notify the FAA about the problem. OK, I was thinking about this. Can you suggest which person in the FSDO I'd ask for? Thanks, Sydney |
September issue of Airman available | Otis Willie | Military Aviation | 0 | September 2nd 04 04:39 AM |
Bogus Issue | jls | Home Built | 2 | August 15th 04 04:47 AM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! | Bill Mulcahy | General Aviation | 3 | October 1st 03 05:39 AM |
September issue of Afterburner now on line | Otis Willie | Military Aviation | 0 | September 9th 03 09:13 PM |
