PS Engineering Report
Old December 2nd 03, 04:19 AM
Jay Honeck
Thanks, Mark!
We love our CD/Intercom, but...do you have a unit that combines:
- Audio Panel
- Intercom
- CD Player
- MP3 Player
- AM/FM/XM Radio?
If so, I'm trading mine in! ;-)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 2nd 03, 05:46 AM
Blanche
Mark:
When you find the little rubber gadgets that fit over the ISO switch,
would you please post the details? I'd love to have one (I've got
the 4 place unit) and seem to use that switch more and more often!
Thanks!
Old December 2nd 03, 08:45 AM
Thomas Borchert
G.R.,
You can tell any of your management
The person posting is Mark Scheuer. Have you ever wondered what the S
in PS Engineering might stand for? ;-) Yes, they do care for their
customers.
Thomas Borchert (EDDH)
Old December 2nd 03, 10:50 AM
W9MV
Just about!
The intercom/audio panel would be the PMA7000B, the CD/MP3/MP3Pro/AM/FM/Sirius
Satellite Radio would be the PXE7300 with Option SR.
Total MAP cost? $3789
There really isn't any advantage of putting the units into one chassis. In
fact, the unit would become taller in the panel, from the current total height
of 3.25" to 3.5".
Thanks for the great report Jay!
Sincerely,
Mark Scheuer
PS Engineering, Inc.
www.ps-engineering.com
Old December 2nd 03, 10:52 AM
W9MV
Sure will, as soon as I get an answer on what color the rubber cover should be,
I'll get them on order.
Mark
Old December 2nd 03, 04:58 PM
Jim Weir
And there is nobody in aviation that I have more respect for than Mark. We may
be competitors in the avionics field, but competition and respect are two
powerful allies in this case.
Thomas Borchert
-G.R.,
- You can tell any of your management
-The person posting is Mark Scheuer.
http://www.rst-engr.com
Old December 3rd 03, 03:41 AM
SeeAndAvoid
"W9MV" wrote
Do you have a preference in color? White seems to be a standard.
When I asked the wife (being it was her idea) she said "red" (favorite
color), I automatically thought black to blend in with the unit. White
would probably work too, but what would be the best color to also work at
night? To take advantage of the panels interior lighting? That'd probably
be the best choice. Maybe in the future those can be internally lit. The
wife also mentioned the problem (minor, mind you) she had was that the
switches didn't stick out very far and she was afraid of pushing one of the
buttons next to it. So tackiness with rubber/plastic and a little more
length I guess is what she meant. I supposed it'd be a good idea for the
marker switch as well right above it.
The 182, if I'm not mistaken, has its battery in the rear of the aircraft.
The
engineers at Cessna felt that using the airframe for the ground return
path
saved weight (no copper cable) and certainly aluminum is an excellent
conductor (ask all those home owners who wired their homes with
aluminum in the '80's). Anyway, one strong possibility is that the noise
is
coming from your charging system, and that would be because the who
airframe has the noise supperimposed on it from the return charging
current.
Now that you mention it I've read that somewhere else, too. That's probably
the case. Minor thing. I forgot to ask the kids if they heard a similar
sound during their CD/DVD playback through ENT2.
Are you using your cigarette ligther adapter to power your entertainment
device? If you are, USE BATTERIES, otherwise you will have ground
loop noise from the power source.
Yes, it was powered from the cig lighter. Being it's an Ipaq with internal
batteries, I'll try it unplugged. The Ipaq itself may put out some noise.
I should also mention, right above the audio panel was a TrafficScope, which
should be only a receiver, not emitting a signal.
"The manual says in the ISO mode the pilot should hear ENT1 at a muted
level, I wasn't hearing it at all."
Again, sounds like it is working the way it is designed, you'll notice our
mute level is very low. Without the engine running sometime (preferably on
the ground) get your entertainment running, speak into the mic, and listen
to the mute level, it's way down.
Now I'm a little confused. Earlier you said..."We had more recommendations
to have the entertainment turn off when in ISO mode for the pilot than the
other way around."
Are we talking about two different modes?
"The bleed through of ENT2 and back passengers to the pilot position"
Now this is an anomoly, because the isolation of Ent 2 and passengers is
even greater than the mute level of Ent 1. There may be some wiring issue
here. I'll need to speak to your installer if this level is annoying.
Actually I was going to forward my original post and your reply to my
installer to let him know how it's going so far. He'll be happy to see what
you wrote ..."it is most certainly one of the most high tech ones I have
read about."
We emailed and phoned back and forth alot before this work was done to
really iron out what I needed. They did a thorough job on time and on
budget, really happy with their work so far. (AvWest - Ft. Collins, CO).
As far as the level of annoyance, my son had to have his mouth right on the
mic and going at it pretty loud, or it had to be a really loud scene in the
DVD. When I asked the wife why I wasn't hearing it all the time, she said
much of the time the kids unplugged the mic portion of their headset. I'm
pretty sure when their mic wasnt plugged in, no sound bled through. Like I
said, those are cheapo headsets they have, but able to jump the intercom
while in CREW mode?
After I wrote my report I got a KidREP on the setup. I was wondering why
the kids would get upset at my wife when she'd go into ISO mode to talk to
them. It'd cut out their ENT2 input, so another reason to get that Karaoke
mode switch for the back of the airplane. At first didn't think it was that
big a deal, I was advised differently.
Actually, the PAV80 is different, it has two seperate outputs and does
working in a multifunction fashion. What I mean is that the crew could
listen to say your external music device (through the PAV80) while the
kids could what their favorite DVD. Or, maybe mom and dad want to play
their favorite MP3 songs in the PAV80, and the kids could plug in their
video game into the PAV80 and use the PAV80's display.
Uh oh. We'd just decided to get a portable DVD player, but it doesnt let
them play video games on it (just when I convinced them they could live
without it every now and then). I like how the PAV80 separates the outputs,
that's slick. May have to rethink that. And if the kids find out I can
hook up more than one display, and if the wife finds out she can have her
own display, too.... Now if only it can be like the airlines and have a
moving map of the flight, etc. If theyre quiet and happy, we're very happy.
This is mostly a cross country machine, 3 hour legs are the norm. Otherwise
alot of this wouldn't matter so much. 7 & 10 year olds aren't always the
easiest to keep patient that long, this setup sure helped.
Let me know if I can be of any service.
Sincerely,
Mark Scheuer
Already have, thanks for your response and your product. I'd been looking
into the options for a couple years. Went back and forth between the
GMA340, the Apollo unit (that you make apparently) and the PMA6000M.
Luckily I waited. A few avionics shops I talked to directly steered me
towards PSE, glad I took their advice.
Chris
Old December 3rd 03, 11:00 AM
W9MV
Hi Chris:
OK, I'm glad the red is not top on your list because we try not to use red in
the cockpit unless it is for a warning indication.
Black would look the best, IMHO, but I think it would also make the two
switches blend in too much and would be easy to miss.
I think the best for night viewing and probably would look OK cosmetically
would be white.
So, that's what I'll get. You can send me your mailing address off line if
you'd like. Expect this to take a week or two.
Thanks
Mark Scheuer
  #29
Old December 3rd 03, 02:11 PM
Jay Honeck
would be white.
Me too, me too?!
You're talking about the pilot-isolate/all/crew switch, right? It would be
great to have a little rubber extender on that switch!
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #30
Old December 3rd 03, 03:29 PM
Thomas Borchert
Mark,
would be white.
What you really need is white fluorescent (or whatever the word is for
material that has an afterglow in the dark after being exposed to other
light sources) ;-)
Report: Pentagon needs to justify new fighter jet Otis Willie Military Aviation 0 March 16th 04 03:51 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
Report: Sedatives found in pilot's blood Otis Willie Military Aviation 0 November 15th 03 11:55 PM
Senator asks Navy for report on pilot Otis Willie Naval Aviation 0 July 17th 03 10:08 PM
