I have 3 Wing Riggers that I need to get shipped out today, but as
soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. If that plan works out, I will post back here. GW |
On May 18, 9:44*am, Steve Koerner wrote:
I have 3 Wing Riggers that I need to get shipped out today, but as soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. *Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. *If that plan works out, I will post back here. GW I'd be interested to hear how that works out. There is a least one spacer block inside the frame extrusion and it looks like it would have to be extracted, drilled, and replaced. There may be two each side. Given the limit access to the extrusion opening it could be a bit awkward to work the inner blocks. If I was going to larger bolts I think I'd relocate the handles and keep them on 5/16 socket cap bolts. They wouldn't need the spacer blocks as long as a moderate torque was used. Andy (GY) |
On May 18, 11:44*am, Steve Koerner wrote:
I have 3 Wing Riggers that I need to get shipped out today, but as soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. *Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. *If that plan works out, I will post back here. GW Why not use the proper metric size? Peter |
Like Eric’s, my trailer has “bridged” its way around the west, at
least until I got bigger tires and wheels (Eric, get bigger tires and wheels). And like Eric, I have the more flexible aluminum top and tight hinge bolts. Based on the table Bill provided the thermal expansion of aluminum is 2.5% higher than glass reinforced polyester. assuming the these 30 foot trailers were assembled at 80 F, left outside on a 0 F night and soon after dawn the top was 20 F hotter than the floor due to radiant heating; the fiberglass top would be about 0.095” longer than the bottom. I don’t know if the hinge and latch pins can take up that much play. This might explain the crushed fiberglass under the handles. Looking at a steel bolt going through 2 inches of aluminum on the frame, under the same 80 F to 0 F conditions, the bolt would only tighten by .001”; certainly within the elastic range of the the parts and at loads too low to damage anything. Another possibility is crosswind loads on the open trailer. Of course you usually park into the wind for assembly or disassembly, but dust devils are not too uncommon in Arizona this time of year. The air springs won’t provide much lateral support when extended. The cross wind loads, including those on the tail doghouse which act over the full length of the trailer, would create a substantial load couple across the 4-foot hinge spacing at the front of the trailer. The bolts on the downwind side would be in tension with the outside bolt seeing the highest load, perhaps enough to crush the fiberglass under the handle. This would cause this bolt to lose its clamping force and allowing the hinge to pivot around the inner bolt (if that is what you saw). In either case, the stronger bolts and the baseplate Steve put under the handle should solve the problem. Mike Koerner |
Thanks Mike. I think the open trailer in the wind theory is very
good. I know that Andy and I have had to disassemble in the wind many times and there is a tremendous lever arm working on the hinge plates in that situation as you point out. That could be what has fatigued the bolts in tension as well as caused the slight compression to the fiberglass and the base of the handles. In my case the broken bolt was discovered after a long drive back from Moriarity where my last disassembly at Moriarity was in pretty strong wind and the trailer was, in fact, not lined up to the wind as it should have been. So, it fits with the patients history. Steve Koerner (GW) |
On May 22, 10:11*pm, Steve Koerner wrote:
Thanks Mike. *I think the open trailer in the wind theory is very good. *I know that Andy and I have had to disassemble in the wind many times and there is a tremendous lever arm working on the hinge plates in that situation as you point out. *That could be what has fatigued the bolts in tension as well as caused the slight compression to the fiberglass and the base of the handles. *In my case the broken bolt was discovered after a long drive back from Moriarity where my last disassembly at Moriarity was in pretty strong wind and the trailer was, in fact, not lined up to the wind as it should have been. *So, it fits with the patients history. Steve Koerner (GW) What's more, the trailer was facing north in a west wind and it was the left side bolt that popped. That's the side that would have been under tension. I guess I should read my own Wing Rigger FAQ document which clearly states that the trailer should be pointed into the wind. I had asked where to assemble and I put the trailer in the particular spot that was recommended off the edge of the apron. I should have moved it when it was disassembly time and the wind was stronger but I didn't need to bother with the Wing Rigger since my son was standing by to assist. The wind was not so strong that we couldn't safely rotate the wing to slide into the trailer -- maybe around 10 or 12 knots. I think the bolt had already fatigued and that was its final straw. The fiberglass compression and handle damage was actually the same on both sides. GW |
On 5/22/2011 7:54 PM, MKoerner wrote:
Like Eric’s, my trailer has “bridged” its way around the west, at least until I got bigger tires and wheels (Eric, get bigger tires and wheels). That would make the rear of the trailer too high for convenient rigging with the trailer attached, something I commonly do when traveling with the motorhome (the trailer's primary motive force). Removing it to rig is a nuisance, especially since I need to reconnect it after rigging, so my wife can retrieve or follow me, as needed. A Cobra trailer dealer told me they are designed to be supported entirely by the tail and the tongue without damage, so I don't think the bridging causes the trailer any problems. I do have to replace the aluminum tail skids every 100,000 miles. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Cobra Trailer Spare Tire mount failure | Barny | Soaring | 29 | July 23rd 15 12:52 AM |
Cobra bottle jack failure | db_sonic | Soaring | 15 | October 30th 09 03:34 PM |
cobra trailer brake lever gas strut failure? | Frank[_1_] | Soaring | 11 | March 31st 09 08:59 PM |
Hanger Queen meets Cobra - Cobra Girl 07.jpg (1/1) | Alan Erskine[_3_] | Aviation Photos | 9 | September 20th 08 04:35 PM |
Hanger Queen meets Cobra - Cobra Girl 05.jpg (1/1) | Glenn[_2_] | Aviation Photos | 0 | September 19th 08 03:41 PM |
