Tach Vs. Hobbs Time
Old December 23rd 03, 04:42 AM
Dan Raneri
All those posts, and no one answered the question...
"John Roncallo" wrote
I guess this is the question I'm asking. Where does 1:1 occur. On the
particular trip I was running 65% which at that altitude was 2425 RPM.
John Roncallo
It depends on the tach. Typically, you can buy one that's designed for 1:1
at 2300 or 2500... If it's not marked on the faceplate, check the model
number or s/n of the tach, and go to the manufacturer. That's the best way
to tell how the tach is calibrated.
If the tach is calibrated to run at 2300 and you're cruising at 2425, that's
a 5.4% increase, so a trip that took 3.9 would read 4.1, assuming no
takeoff and climb...
"John Roncallo" wrote in message
news
Hello
Im trying to figure out the Tach on our clubs Archer is screwing us. I
just flew down to the Centenial of Flight FFA from Planville CT. Round
trip with all diversions and ATC rerouts was 975nm. The tach said 12.4
hr. I never checked the Hobbs but I do know that for this plane the Tach
usually runs faster than the hobbs on cross countries. Is this normal. I
also did another flight previously at 65% power from Meriden MMK to
Williamsburg W94 in 4.6 Tach time. My watch said 3.9. Also based on the
4.6 my fuel burn was only 8 GPH.
Is there any text book way to check this. Our FBO seems to feel that
calibrating the Tach is a big deal. I'm currently thinking of just
replacing the Tach without tring to calibrate. Right now it looks to me
as if we just replaced and engine at 1700 hr thinking it had 2000 hr.
Thoughts ideas?
Old December 23rd 03, 02:45 PM
Ron Natalie
"John Roncallo" wrote in message . com...
I guess you are saying the street light flickers at 60Hz.
It flickers at 120 Hz.
Old December 24th 03, 01:13 AM
John Roncallo
I guess this is due to voltage passing through zero 2 time per cycle?
using 60 Hz. AC. Looks like I will only pick up the blade looking like a
4 bladed prop at 1800 RPM.
John Roncallo
Old December 24th 03, 01:16 AM
John Roncallo
John Roncallo
news
Hello
Thoughts ideas?
Thanks, this makes sense. Is there anyway I can tell what is supposed to
be installed in this particular aircraft?
John Roncallo
Old December 29th 03, 03:32 PM
Dylan Smith
In article , John Roncallo
Why? Do the Archer's engine components wear less at high RPM than an
engine on an Arrow?
Yes they probably do wear less. They are under less load for the given
circumstance. Cylinder pressures are much higher in an engine at 65%
power 2300 RPM than they are at 65% 2480 RPM.
But a far greater effect will be the additional wear from friction of
running at 2480 RPM instead of 2300 RPM - a significant increase in the
number of friction cycles per hour. I'd say the Archer's engine
will wear more quickly.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old December 29th 03, 03:39 PM
Ron Natalie
"Dylan Smith" wrote in message ...
The number of revolutions acquired isn't the driving factor in engine
life. Flight school aircraft that are flown frequently and full throttle
tend to far exceed TBO where as babied, infrequently flown single
owner birds tend not to get anywhere near TBO.
Old January 4th 04, 10:34 PM
Paul Sengupta
Or 50 here in Europe.
Paul
"G.R. Patterson III" wrote in message
Any multiple of 60.
  #29
Old January 4th 04, 10:54 PM
Paul Sengupta
To check, you can get one of these:
http://www.aircraftspruce.com/catalo...es/trutach.php
As pointed out, can get get various 1:1 tach RPM settings.
You specify it when you buy one.
Go to http://www.gulf-coast-avionics.com/
and type "tachometer" in the search box. You'll see the
1:1 RPM listed. Maybe a number in the model number
gives it away (like the 3 or 5 at the end in the ones listed).
Paul
om...
  #30
Old January 6th 04, 05:38 AM
John Roncallo
Paul
om...
Thanks
Our annual is comming up. I will be looking into this.
John Roncallo
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 10:46 PM
Logging time on a PCATD [email protected] Instrument Flight Rules 3 December 18th 04 05:25 PM
FAA Application -- kinds of time Gary Drescher Instrument Flight Rules 5 November 23rd 04 02:33 PM
It's that time of year again. Capt. Doug Home Built 19 September 3rd 03 10:53 PM
