"Jim Weir" wrote in message
news ![]() That's how I seal food bags for freezing. Tellya what, put a little light machine oil in a bag and try sealing it with a straw. Damn near choked me to death. When I bag salmon for the freezer, I fill the small kitchen sink with water, then submerge the bag in the water up to the lip. A quick zip and the bag is closed. Not a big enough bubble left for a compass. You could use a Tupperware container instead of the sink. Rich S. |
Anybody mentioned a refrigerator compressor? I used it to vacuum bagging
composites. You shouldn't drain the fluid from a filled system (ozon killer) but if you get one from a bone yard that is already drained it would make a low noise, low cost solution. - Holger Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. ... |
Take the brake system vacuum pump from the back of the alternator on almost
any diesel light truck, 4wd, etc. For the level you are looking for you could probably hand crank it with a lawn mower zip starter and use it's return spring to set it for the next pull. Depends on how green you want to be, you're both recycling and people powering it! ;) Bushy |
Jim Weir wrote:
Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com If you have compressed air already available, there are small venturi vacuum generators you can use. They are just a tiny chunk of aluminum with three 1/8" pipe threaded ports, air in, air out, and vacuum. The one in my "solder sucker" pulls about a 26" vacuum and damn quick too! A "baggie" would be evacuated almost instantly. Tom Pappano, PP-ASEL-IA |
On Sat, 17 Jan 2004 19:03:40 GMT, Tom Pappano
wrote: Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com Those aquarium air pumps pull air from around the case. How about placing one inside a cheapo tupperware-type container with a "suck" port mounted on the container, you'd also need to run a "blow" port from the pump's normal output through the container wall. HTH Mike Patterson Please remove the spamtrap to email me. |
Now *that's* clever. I admire clever.
Jim Mike Patterson shared these priceless pearls of wisdom: - -Those aquarium air pumps pull air from around the case. - -How about placing one inside a cheapo tupperware-type container with a -"suck" port mounted on the container, you'd also need to run a "blow" -port from the pump's normal output through the container wall. - -HTH - - -Mike Patterson -Please remove the spamtrap to email me. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
On Mon, 19 Jan 2004 17:45:27 -0500, Mike Patterson
wrote: On Sat, 17 Jan 2004 19:03:40 GMT, Tom Pappano wrote: Jim Weir wrote: Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. Just get a little "mityVac" hand pump used for testing vac advance etc on cars. Or if you really need it mechanized, make an adapter for your vacuum cleaner with an adjustable bleed The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com Those aquarium air pumps pull air from around the case. How about placing one inside a cheapo tupperware-type container with a "suck" port mounted on the container, you'd also need to run a "blow" port from the pump's normal output through the container wall. HTH Mike Patterson Please remove the spamtrap to email me. |
Try using warm oil, not hot enough to melt through, roll the air out of
the baggie, seal it and as the oil cools, maybe it will pull it own vaccuum... |
Jimmy:
Use an old compressor from a freg. I have a high dollar Freon pump but use the old G.M. compressor more. Jim "Jim Weir" wrote in message ... Does anybody have an idea on how to make a tiny little vacuum pump on the order of an aquarium pump or so that will draw just a few inches of water? Preferably 110, but I can rig up a 12 volt supply if necessary. The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Try this: Put parts in bag, slowly lower bag into bucket of water until only
the top inch or so is above water (Don't get any water in the bag!) Zip bag closed while most of bag is under water. Remove. The water pressure should have forced 99% of the air out and you have a psuedo "sealed" part. The reason I say this is that I'm getting ready to pack a fairly large number of bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like to put each part in a "baggie" (sandwich bag or equivalent) along with a little preservative oil, and then suck the baggie down with a football needle stuck into the top closing mechanism just before sealing. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Thread Tools | |
| Display Modes | |
| Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 06:17 PM |
| Windmilling Prop & Vacuum Pump | Matt Young | Instrument Flight Rules | 14 | October 14th 04 09:08 PM |
| Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? | Ron | Home Built | 2 | February 24th 04 05:34 PM |
| Tiny vacuum pump | Jim Weir | Home Built | 41 | January 24th 04 06:42 AM |
| Battery and Vacuum pump | PaulaJay1 | Owning | 3 | January 16th 04 05:22 PM |
