Audio Panel Recommendations
Old January 23rd 04, 02:03 PM
Doug
I would recommend that you get a unit with a music input. Not only can
you plug in CD players (something Jay already has), but you can plug
in a handheld radio, cell phones, anything with a standard RCA music
jack.
Old January 23rd 04, 03:20 PM
Brian Cox
Jay,
Based on my experience, I'd say there are two choices. Something
from PS Engineering or whatever is in second place. Yes, the King KMA
28 is provided to Honeywell (...Allied Signal...Bendix...King, yada
yada yada) as an OEM product designed and manufactured by PS
Engineering. Likewise the SL-10 and SL-15 from Garmin-AT (...UPS
AT...II Morrow...Apollo, yada yada yada) are also designed and
manufactured by PS Engineering. They may great audio panels and
intercoms. Their reputation for quality and support is a model of how
gen av folks should run their business.
I am flying behind the same stack that came with my plane when I
bought it four years ago. The whole stack is vintage 1980 King Siler
Crown, including a KMA-24. No complaints, and not a single need for
repair yet. The intercom is a six place PS Engineering. I bought my
previous plane without and intercom and installed a PS Engineering.
Eventually, I will be upgrading the KMA-24 to a PMA 7000B. I've
worked in aviation for the past 24 years, and have personally
integrated their products with air-to-ground cellular and satellite
systems.
Since you already have a PS-Engineering intercom, the most costly
part of your wiring has already been done, the wires from the panel to
the cabin audio jacks. The easy way to wire it is to have an
interface cable made up that can be put in place. That is, get a
mating connector that is the same as the one on the back of your
intercom. The PMA 7000B has two slide in connectors in the tray. The
top connector is the intercom, which is the what you want for this
harness.
The audio panel wiring that you want to remove from the existing
unit all wires to the lower connector. Slide the Narco intercom out,
remove the tray fasteners and pull the tray out as far as possible.
Then find out the pinout and get a one to one correspondence between
the power connections and other avionics. The key is that all of
these wires are already connected to your radios, and conveniently
located at the back of the audio panel tray. Here is what you will
likely need to re-connect:
1) Connection to the marker beacon receiver: 5 wires and one coax
2) Two VHF comm radios: 5 wires each, TX pair, RX pair, Gnd
3) Audio connections from two VORs: 2 wires each (might be the same
GND if you have a Nav/Comm)
4) Audio connection to the ADF: Two wires
5) Audio connection to DME if applicable: Two wires
6) Direct wired pilot mic/PTT and headphone: 6 wires
7) All of your other wiring to mic and headphones, which go from the
existing intercom to the top connector on the tray, and can be made on
the bench.
All in all, one harness that can be made on the bench for the
audio, and about 30 more wires and one coax that have to be done in
the plane - but they are already there. Remember to use twisted
shielded pairs on all audio lines, and only bond the shield to
airframe at one end, preferably the end that the audio comes from.
Even that may already be taken care of pretty well. All of the nav
radios are only RX at the audio panel, so should be bonded at the
radio end. All you need to deal with is bonding of the two VHF comm
TX pairs.
It may not be trivial to get to. Mine is not too bad because the
audio panel is at the top of the stack and I can remove a cooling
grate on the top of the glareshield. It's worth talking this over
with your radio shop to see if they agree. They could probably do the
pre-wiring on the bench in about an hour. Re-connecting the radio
wires to the new tray connector will depend on accessibility.
Good luck,
Brian Cox
Old January 24th 04, 04:16 AM
Jay Honeck
Wow. Brian, your response is a perfect example of why I hang out here so
much.
Thank you very much for the audio panel primer!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 24th 04, 04:17 AM
Jeff
I like the PS engineering 7000b audio panel. Mine is workign great for me plus
the have alot of additional attachments if you want them.
Jay Honeck wrote:
My Narco audio panel works just fine. However, the faceplate has been glued
back together twice by my avionics shop. (How it got broken in the first
place is anyone's guess...)
In the recent intense cold, the epoxy has let go again, so I think it's time
to replace the unit. Other than requiring the marker beacon lights/receiver
to be built-in, I have no prerequisites. Well, it would be nice if it fit
in the same hole without too much bother.
Any recommendations?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old January 26th 04, 05:44 PM
EDR
In article mCRPb.122933$8H.317848@attbi_s03, Jay Honeck
2. There is the obvious problem of me being clueless with regards to
building the thing. Make it out of wood, and I'll build it with dovetail
joints -- but electricity is a mystery to me.
Colonel Weir puts out one of the most complete, easy to read, easy to
understand manuals I have ever come across in an electronics kit. As I
understand the process, some of his Alpha- and Beta-testers/reviewers
have fresh minds, untainted by previous electronics experience. If they
come to him for clarification, the manual gets edited until there are
no more questions.
Jay, as long as you know which end of the soldering iron to hold, you
can follow Jim's instructions and build one of his kits and it will
work.
Old January 26th 04, 06:08 PM
Jay Honeck
work.
Ow! Ow! Ow!
Whoops, wrong end... ;-)
Ah, hell, I suppose if I can build a fuel truck (ain't never done THAT
before, neither!), I can build an audio panel, too.
Trouble is, all I *really* need is the stupid faceplate. Narco wants TWO
HUNDRED BUCKS for this stupid plastic faceplate! Augh!
Sometimes I hate aviation, God help me...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old January 26th 04, 06:40 PM
Jim Weir
Kenny Faeth (Faeth Aircraft Salvage) out in Sacramento specializes in
"previously owned avionics" as well as a lot of other used airplane parts. I'll
bet you can find one from him. If you need his phone number, I can look it up,
but I also think you can google him and find it.
Tell him Jim sent you and he will only charge double what it is worth rather
than the usual triple {;-)
"Jay Honeck"
-Trouble is, all I *really* need is the stupid faceplate. Narco wants TWO
-HUNDRED BUCKS for this stupid plastic faceplate! Augh!
http://www.rst-engr.com
Old January 26th 04, 07:51 PM
Dennis O'Connor
I'm not totally up to speed on this thread, but reading between the lines
of your post Jay - there are companies that advertise to the airplane
homebuilders to make custom panels, inserts, faceplates, engravings, etc.,
etc. Just look in the back of your EAA, Sport Flying you are a member, of
course
Ayund, your local sign shops may also offer such services... Look also to
trophy shops who make various plaques, etc... Jeez, too hunnert bucks
should get you one that lights up, blinks, and plays the Marseilles when you
transmit...
denny
"Jay Honeck" wrote in message
news:TIcRb.27547$U% Trouble is, all I *really* need is the stupid
  #29
Old January 26th 04, 07:59 PM
Paul Sengupta
$200 for a new faceplate! Mind you, compared to $1500 for a new
audio panel, plus $$$ rewiring everything, it may be a good investment!
Paul
news:TIcRb.27547$U%5.179540@attbi_s03...
  #30
Paul Sengupta
"EDR" wrote in message
I guess people learn this one rather quickly.
Paul
RST Audio Panel Legality [email protected] Home Built 13 January 16th 05 10:39 PM
FS KMA20 TSO Audio Panel with Marker Beacon Maik Aviation Marketplace 0 March 18th 04 04:59 PM
FS: KMA20 TSO Audio Panel Maik Aviation Marketplace 0 February 25th 04 07:52 PM
Air Force Academy Review Panel Releases Report Otis Willie Military Aviation 0 September 19th 03 03:45 AM
Garmin audio panel question Brinks Owning 1 September 10th 03 08:41 PM
