Has a fixed-wing plane ever been made that could back up under its own
power? |
![]() wrote in message ... Has a fixed-wing plane ever been made that could back up under its own power? Many. All it takes is reverse pitch props or thrust attenuators. |
"Steven P. McNicoll" wrote in
ink.net: Has a fixed-wing plane ever been made that could back up under its own power? Many. All it takes is reverse pitch props or thrust attenuators. Not even that. Heck, many an old-timer B-17 pilot could back up into his parking place, with a little practice. ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
Most fixed wing aircraft with turbine engines and reversible pitch
propellers are the norm for backing.. ever watch a King Air do a "K-turn" on a taxi way that was too narrow to turn around on? some may be "limited" in it's reverse mode for blowing dirt and debris from the ground up into the engine intakes.. BT wrote in message ... Has a fixed-wing plane ever been made that could back up under its own power? |
"James M. Knox" wrote in message ...
I always figured if I was building a homebuilt I would investigate some relatively small motor/brake assemblies that are used on smaller electric automobiles. May be WAY too heavy, but they make great brakes that don't fade with heat ... *AND* you could just taxi out of the hangar (before starting the engine). My first thought when reading this was, "sounds cool!". And I started to think it through. The motor part is clear enough, you can taxi with electric power and not with the engine power. That'd lead to a real difference in taxiing of course. You can't use engine power to bring the rudder around for example. But this is workable, it just becomes part of this plane's checkout procedure. In the brake mode though, there's a problem. Either the motor/brakes now work as generators or as motors in reverse. If the first, where you put the power that's generated? Your battery's been charging off the engine, it's already full and not drawing current. Your braking power is directly related to the power you can cause to be used up on something else. I imagine you can make your landing light really bright or something... grin The generator mode makes more sense in a hybrid aircraft, like hybrid cars with regenerative brakes. But the problem with this is that lightweight high-capacity batteries are not yet available. If the brakes are operating as motors in reverse that solves the generator problem. But it creates a new one. What happens if your battery or electrical system dies? No brakes. But if you've got the power, you should be able to get more braking from reversed electric motors than current braking systems. Current braking systems convert momentum to heat. Their braking capacity is directly releated to their limit in heat capacity. Electrical reversed motors would have a heat limitation, but the initial limiting factor would be the power input. Fun idea! -Malcolm Teas |
(Malcolm Teas) wrote in
om: "James M. Knox" wrote in message I always figured if I was building a homebuilt I would investigate some relatively small motor/brake assemblies that are used on smaller electric automobiles. My first thought when reading this was, "sounds cool!". And I started to think it through. All true. Of course, I was thinking primarily in terms of taxiing only a short distance - into or out of a hangar, for example. I haven't done the brake calculations, but I *think* (back of the hand calculations) that the amount of power generated stopping the plane on the runway and taxiing in is small enough that even a "fully charged" battery can easily absorb it. Mostly just amusing and idle speculation... But I've seen some cold rainy days when it would sure be nice to preflight in the hangar, climb in, and just drive out. G ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- |
![]() "James M. Knox" wrote: Mostly just amusing and idle speculation... But I've seen some cold rainy days when it would sure be nice to preflight in the hangar, climb in, and just drive out. G So, build a steel frame which supports the wheels of the plane. Put that frame on wheels. Use a garage door opener to move it in and out of the hangar. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
![]() Mostly just amusing and idle speculation... But I've seen some cold rainy days when it would sure be nice to preflight in the hangar, climb in, and just drive out. G ----------------------------------------------- James M. Knox TriSoft ph 512-385-0316 1109-A Shady Lane fax 512-366-4331 Austin, Tx 78721 ----------------------------------------------- Two things: 1. Some hangars have slightly slanted floors such that when the chocks are removed, the airplane wants to roll out. They have to be winched in of course but lots of hangars have winches to reel the airplane in without a slanted floor. 2. If it's cold and rainy, you're flying? ;-) Corky Scott |
Reverse scoop | Paul Lee | Home Built | 9 | April 13th 04 01:58 AM |
taxi in reverse? | Malcolm Teas | Home Built | 10 | February 21st 04 12:26 AM |
Pilot log book and taxi testing | Bob Olds | Home Built | 1 | February 11th 04 03:32 PM |
Reverse NACA duct | Chris W | Home Built | 22 | October 28th 03 10:59 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
