Lack of power in Cessna 172-R
Old February 13th 04, 05:58 PM
Paul Sengupta
"G.R. Patterson III" wrote in message
Chuck wrote:
Also, there was a "burbling" sound from the exhaust.
Fuel spilling in. It's running way too rich.
http://www.sumpthis.com/docketno2001...617rin2120aa64
..htm
or
http://makeashorterlink.com/?K66442667
Paul
Old February 13th 04, 06:12 PM
Paul Sengupta
"Nathan Young" wrote in message
On Thu, 12 Feb 2004 19:02:46 GMT, Chuck
The prop was removed, inspected and put back on (with plenty of
scratch marks which weren't there before.
if you have
a 160hp it is possible they swapped props with a 180hp 172.
Hah! Different prop! I'd have never have thought of that, I
can't imagine props having been swapped between aircraft!
Sounds like a good explanation given the symptoms or lack
thereof...and given that the prop came back looking different!
This should be easy to trace with the serial numbers shouldn't it?
Paul
Old February 13th 04, 06:40 PM
Russell Kent
Chuck wrote:
Thanks again for your help. I'm going to ask my AME to check the fuel injection
system.
You can do what you want, but I suspect that your mechanic (A&P: Airframe and
Powerplant) would know more about the fuel injection system than your physician
(AME: Aviation Medical Examiner). :-)
Russell Kent
Old February 13th 04, 09:15 PM
Mark Bailey
I think Roger Long could be on to something. I had a like experience
with my Hawk XP. Although it has a different engine than the "R", I
too had a power loss. Airplane would not get off the ground well and
climbed poorly. Flew a little slower, but not seemingly much. Had
the fuel system overhauled as well as the governor. No change.
Leaning had no effect. Compressions were no lower than 73. After a
couple shops, the mechanic found same issue Roger mentioned. Mechanic
replaced a few parts and the old plane was back. Good luck!
Mark
Old February 14th 04, 12:21 AM
Dan Thomas
Russell Kent wrote in message ...
system.
Russell Kent
He'll be a Canadian. An AME here is an Aircraft Maintenance
Engineer, roughly equivalent to an A&P-IA.
Dan (Canadian AME)
Old February 14th 04, 02:27 PM
Jay Honeck
I leaned the mixture for the static runup and consequently got good
results. I did NOT lean before takeoff. Perhaps that is significant.
That can be very significant on a hot day.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 16th 04, 08:53 PM
Russell Kent
Ah so. Apologies Chuck.
Russell Kent
system.
Russell Kent
Dan (Canadian AME)
Old February 19th 04, 03:26 PM
Jay Smith
Nathan Young wrote:
Are you sure they put the correct prop on the plane? I know some of
the new 172 series were produced with 160hp and others with 180hp.
Although you have to hope the mechanics did a better job - if you have
A cruise prop would drag down both the static RPM and climb
performance. On the other hand, you should notice a few mph
improvement in cruise (unless the prop is grossly wrong).
You will definitely feel the difference when you bring the power up for
takeoff.
The club I am in has three C172N's. One has a cruise prop. The first
time I flew it, I thought something was wrong when it took what seemed
(and actually was) a longer takeoff roll. I looked at the tach to see if
the RPM was low, but it was fine. Once leveled off in cruise, I noticed
the higher cruise airspeed and realized the prop difference.
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 04:40 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 01:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 01:57 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Cessna 150 lost power with AD 96-12-06? Ozzy Countin Owning 3 August 17th 03 06:41 AM
