O. Sami Saydjari wrote: Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? If you lean aggressively during taxi and avoid full-rich descents you probably won't have any fouled plugs to worry about (we are talking about OWNED aircraft, right?). And then engine roughness on the mag check is probably NOT plugs, so why abuse the engine to try and fix it? -- Ben Jackson http://www.ben.com/ |
Ben, Yeah. Actually, this has not yet happened in the Piper Turbo
Arrow III that I just bought. It happened pretty frequently in the Skyhawk Millenium that I used to rent. I am asking because the TCM booklet seems to be pretty hard-over on NOT doing burn-out procedure. -Sami Ben Jackson wrote: In article , O. Sami Saydjari wrote: Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? If you lean aggressively during taxi and avoid full-rich descents you probably won't have any fouled plugs to worry about (we are talking about OWNED aircraft, right?). And then engine roughness on the mag check is probably NOT plugs, so why abuse the engine to try and fix it? |
BTW, since my FBO started using some fuel additive (sorry- I don't know
what it is offhand) they've experienced NO plug fouling. I can corraborate that based on 30+ hours of flying since then- not one plug fouling whereas it used to be quite common (and, yeah, we always burned it off). O. Sami Saydjari wrote: I just received a booklet from TCM called "Tips on Engine Care" (a very good book...available from TCM's website...http://www.tcmlink.com/). On page 12 it says "Never but never attempt to "burn out" a magneto drop with ground run-up. This 'time-honored' procedure succeeds only at the expense of the engine's mechanical health." Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? -Sami N2057M, Piper Turbo Arrow III |
Having to clear an occasional fouled plug is much different than doing
it on a regular basis. If it's a regular thing, I'd find out what the problem is. If it's once in a great while, I wouldn't worry a bit. Used to have fouled plugs in my TriPacer when I first bought it. I was flying in New Mexico where we flew at 9 to 10 thousand feet MSL and always leaned. I was going full rich when beginning my descent and at the next startup it'd be rough. Found that if I richened the mixture gradually as I decended, it never happened. -- Gene Seibel Hangar 131 - http://pad39a.com/gene/plane.html Because I fly, I envy no one. "O. Sami Saydjari" wrote in message ... I just received a booklet from TCM called "Tips on Engine Care" (a very good book...available from TCM's website...http://www.tcmlink.com/). On page 12 it says "Never but never attempt to "burn out" a magneto drop with ground run-up. This 'time-honored' procedure succeeds only at the expense of the engine's mechanical health." Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? -Sami N2057M, Piper Turbo Arrow III |
Burning out the pitot heat? | Mitty | Instrument Flight Rules | 3 | December 30th 04 05:04 AM |
Drop in and say hello | Gilan | Home Built | 0 | June 4th 04 05:12 PM |
Economist: Let the dollar drop | Luca Morandini | Military Aviation | 5 | February 14th 04 05:58 PM |
:-) let enola gay drop one more :-) | old hoodoo | Military Aviation | 3 | December 28th 03 05:39 PM |
Ellery Queen and the Case of the Missing Magneto Gear Teeth | MikeremlaP | Owning | 3 | July 26th 03 03:01 AM |
