On Sep 9, 5:23*pm, ContestID67 wrote:
I was informed (and verified) that there is a way to easily test the 302 warning system while on the ground. - Power down the 302 - Unlock the airbrakes with the gear unlocked/up - Power up the 302 The alarm will then sound (euro siren) after the self test is complete. *A large upwards pointing arrow will appear in the display, different than the small speed up/down arrows, meaning I suppose that your gear is up. *You can silence the alarm by pushing the button. Yet another undocumented feature/sound from the Cambridge 302! - John The power up alarm sounds with brakes unlocked with the gear DOWN and locked. After power up test execution the gear warning is as expected - the gear alarm only sounds if the brakes are unlocked and the gear is not down locked. The alarm may also sound on power up with the brakes unlocked and the gear not down and locked but I can't be sure of that as my assembly routine has gear down and glider pushed back from trailer before the batteries are fitted. Andy |
What about the guys who routinely, and with knowledge, begin takeoff with
their spoliers partially opened. I do that when I'm flying the rented LS-4 as it feels to me like it improves aileron control early in the takeoff roll. I close and lock the spoilers as soon as control is assured. In my Mosquito, I begin takeoff roll with flaps full negative as I did in my previous LS-6. Would you deny me a hookup even after I announced to you that my spoilers are open and why? I'm talking about the (apparently) sleeping pilots who, at 200 feet fail to notice that the spoilers have just popped open without command. I've read of the tow pilot taking that glider pilot to safe altitude, releasing him within good landing position, and then watching him fail to reach the airport because he never recognized the problem. And, please, let's not start another radio discussion. "Martin Gregorie" wrote in message ... On Fri, 09 Sep 2011 09:00:53 -0600, Dan Marotta wrote: If your spoilers "suck open" and you don't recognize it, you shouldn't be flying. Maybe other outfits should adopt my club's new-for-2011 change in launch procedu the cable is NOT put on unless the pilot announces "Brakes locked" before asking for 'cable on'. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 9/9/11 3:56 PM, Martin Gregorie wrote:
the cable is NOT put on unless the pilot announces "Brakes locked" before asking for 'cable on'. And if the pilot uses spoilers to get better aileron control at the start of the takeoff? Or the wheel brake is on the spoilers and the pilot wants to prevent a rope overrun? -Tom |
On Sat, 10 Sep 2011 19:39:46 -0700, Tom Serkowski wrote:
On 9/9/11 3:56 PM, Martin Gregorie wrote: the cable is NOT put on unless the pilot announces "Brakes locked" before asking for 'cable on'. And if the pilot uses spoilers to get better aileron control at the start of the takeoff? Doing standard UK CBSIFTCBE preflight checks, accepting the cable before opening the brakes and keeping a hand on the brake lever allows the pilot to accept the cable with brakes locked, so the confirmation can be made correctly. Of course, if you are flying somewhere that doesn't teach a preflight check which includes opening, visually checking, and then locking the brakes, doesn't include the checks in every flight under instruction and which tolerates launches for pilots who skip the preflight check then you should expect launches with unlocked brakes as well as any consequent crashes. Or the wheel brake is on the spoilers and the pilot wants to prevent a rope overrun? Totally unlikely on our field, which is, if anything, always slightly uphill since it has a small hump (on a winch launch the wing runner can see the winch flashing but the pilot usually can't). I've only flown on one field where that was necessary, the Wasserkuppe, and again that's a bit special since you take off downwind and downhill on a hard runway which is steep enough to require a small wooden wedge in front of the main wheel to stop the glider running forward while the pilot (s) get in. In any case in the UK and other places where the CBSIFTCBE preflight check is taught the pilot will have cycled the brakes AND DONE A VISUAL CHECK before unlocking and opening them if the glider needs that for a successful launch, so the announcement "Brakes locked: cable on, please" should be redundant. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Sep 8, 12:09*pm, ContestID67 wrote:
*If so, how can I test this system on the ground? *Anyone else install this system and have any experience? * This weekend I will experiment to see if the 302 programming is smart enough to allow testing while I am standing still. Thanks, John DeRosa To test the warning just turn on the 302 with the brakes unlocked and the gear up. Mine sounds most times I rig the glider. To cancel it press the 302 knob, or lock the brakes, or lower the gear. The gear warning does not depend on either airspeed or ground speed, only the warning for unlocked brakes with gear down does. Andy |
Reading from the above it would seem that the alarm system is totally inactive until the GPS indicates I am moving 25+ knots. *If so, how can I test this system on the ground? *Anyone else install this system and have any experience? * This weekend I will experiment to see if the 302 programming is smart enough to allow testing while I am standing still. The 302 gear warning is fully functional on ground at zero airspeed and ground speed. It will also sound when the 302 is powered up with brakes unlocked even if the gear is down and locked. To cancel it press the knob or lock the brakes. My gear warning sounds nearly every time I apply power after rigging the glider as the brakes have to be unlocked for assembly. For standard class glider using airbrakes for roll control on takeoff the warning may sound briefly before it becomes time to lock the brakes. As has been mention by others, the brake switch should detect the difference between "closed and locked" and "closed". Unless the gear won't stay down if not locked, the gear switch should detect the difference between "down" and "down and locked". (28 gear floats halfway if not locked up or down so detecting full forward is sufficient) Andy |
I am in the midst of a project to install a gear/airbrake warning system on my glider based on the built-in capability of my Cambridge 302. *This system is better than the simple "airbrakes open, gear up" warning system (http://www.wingsandwheels.com/pdf/gear%20warning.pdf) as it also alerts the pilot to "airbrakes open on tow". My "sensors" will be strategically placed reed switches and associated magnets (and tefzel wire of course). * My primary question revolves around how to do a pre-flight test of the system. From the manual... "Warnings depend on presence or absence of airspeed as well as the switch contacts. Here is the logic: Unlocking the airbrakes connects pin 7 to ground. When airspeed rises above 25 knots, the alarm sounds. The alarm is cancelled when the airbrakes are locked. During flight with the landing gear retracted, unlocking the airbrakes connects pin 7 to ground and sounds the alarm. Lowering the landing gear opens the connection between pin 8 and ground and cancels the alarm." Reading from the above it would seem that the alarm system is totally inactive until the GPS indicates I am moving 25+ knots. *If so, how can I test this system on the ground? *Anyone else install this system and have any experience? * This weekend I will experiment to see if the 302 programming is smart enough to allow testing while I am standing still. Thanks, John DeRosa Launch, release from tow, open spoilers with gear up, listen for warning horn. |
On 9/9/2011 8:23 AM, glidergeek wrote:
Reading from the above it would seem that the alarm system is totally inactive until the GPS indicates I am moving 25+ knots. I believe the 302 uses airspeed, not GPS ground speed, to do the measurement. If so, how can I test this system on the ground? Anyone else install this system and have any experience? This weekend I will experiment to see if the 302 programming is smart enough to allow testing while I am standing still. Thanks, John DeRosa Launch, release from tow, open spoilers with gear up, listen for warning horn. That only tests the gear warning, which can also be done on the ground with the fuselage in the trailer dolly and the gear up. To test the "spoilers unlocked" warning, the airspeed must increase past 25 knots while the spoilers are unlocked, and once you have released from tow, the airspeed won't do that. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
On Sep 9, 2:50*pm, Eric Greenwell wrote:
On 9/9/2011 8:23 AM, glidergeek wrote: Reading from the above it would seem that the alarm system is totally inactive until the GPS indicates I am moving 25+ knots. I believe the 302 uses airspeed, not GPS ground speed, to do the measurement. *If so, how can I test this system on the ground? *Anyone else install this system and have any experience? * This weekend I will experiment to see if the 302 programming is smart enough to allow testing while I am standing still. Thanks, John DeRosa Launch, release from tow, open spoilers with gear up, listen for warning horn. That only tests the gear warning, which can also be done on the ground with the fuselage in the trailer dolly and the gear up. To test the "spoilers unlocked" warning, the airspeed must increase past 25 knots while the spoilers are unlocked, and once you have released from tow, the airspeed won't do that. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl Well, you could try the following at altitude. Theoretically it should work. Lower gear, pull up hard enough to stall with no airspeed showing, unlock brakes/spoilers at the stall break. Alarm should sound when gaining speed during the stall recovery. Although the OP wants to be able to test on the ground. That's the way I would test as well. I have a method for testing my pnuematic lines (static, pitot, te). Go to any pharmacy and get a syringe (without needle) in the smallest diameter they have. My local pharmacy gives them to me for free. The real small narrow ones allow for moderate plunger movement without fear of damaging your instruments. That's not to say you shouldn't be extremely careful. The point is the really small diameter syringes do not move much volume. I keep one in my field box with a piece of surgical tubing attached for testing. It would be perfect for connecting to the pitot and applying a small amount of pressure to test the 302 alarm. Not to mention the ease in which it allows one to test for leaks throughout the rest of the ship. |
ASW-20C Gear Warning Switch Placement | Jim Kellett | Soaring | 3 | May 16th 09 01:20 AM |
Gear Warning | Gadget Guy | Soaring | 118 | November 30th 05 10:43 PM |
Gear Warning | Gordon Schubert | Soaring | 11 | November 22nd 05 03:27 AM |
Gear Warning | Gordon Schubert | Soaring | 0 | November 18th 05 08:22 PM |
gear warning plus | K.P. Termaat | Soaring | 0 | September 8th 03 08:33 AM |
