"Jean-Paul Roy" wrote in message m...
How can you get a 40 ft garage style door to work properly. Can you imagine one track holding each end. Wouldn't the midlle colapse when in the up position? J.P. "Musky" wrote in message ... Rollers, folders.... all asking for trouble. Why not a garage-door style door, single piece and folding upward with help from low-tech springs? That's what we recommend for county hangars. Very low maintenance, can be automated, and don't flop around in the wind. My opinion only, of course. Mine is a single piece 50 ft "garage-type" steel door with a residential door and six residential windows in it. It is suspended on cables and guided by two parabolic curved tubes. Every time there's an earthquake slight alignment problems delvelop and the side rollers take huge stresses and snap apart the sides of the building. The side rollers attract dust and are high mtc. But it allows me to have windows and a man-door which is nice. But for dependability I'd have gone with an electric bi-fold if I had to do it over again. pac |
I've seen multiple overhead doors side by side that each runs on its own set of tracks. Once all the doors are open, the
vertical track portions of the doors that get in the way of the clear opening are removed via a couple of clips. The open doors are fully supported by the overhead tracks still in place. You then re-install the vertical tracks when ready to close the door. -- Dan D. .. "Jean-Paul Roy" wrote in message ... How can you get a 40 ft garage style door to work properly. Can you imagine one track holding each end. Wouldn't the midlle colapse when in the up position? J.P. "Musky" wrote in message ... Rollers, folders.... all asking for trouble. Why not a garage-door style door, single piece and folding upward with help from low-tech springs? That's what we recommend for county hangars. Very low maintenance, can be automated, and don't flop around in the wind. My opinion only, of course. |
Ron Rosenfeld wrote in message . ..
It came with an electric bifold door. In spite of winter ice and snow, the door has never given any trouble whatsoever. No tracks in the ground to freeze up or buckle. The only time I couldn't open the door was when the airport had a power failure. I would do it again. Biggest problem with a bifold is tail height. For my aircraft, it makes the door framing a heck of a lot bigger than I really want. For a tail height of 15' on one of mine, it makes the bifold opening a minimum of 20' tall. When you couple that with a required span of 60', it makes for a very expensive door that has to be power operated, along with some significant structural needs. For my purposes, a biflod would end up costing nearly as much as the rest of the hangar itself. Craig C. |
Not these doors, which is what I have. They have the aux arms on the sides which allow them to open further with a given
opening... http://www.hi-fold.com/ -- Dan D. .. "Craig" wrote in message om... Ron Rosenfeld wrote in message . .. It came with an electric bifold door. In spite of winter ice and snow, the door has never given any trouble whatsoever. No tracks in the ground to freeze up or buckle. The only time I couldn't open the door was when the airport had a power failure. I would do it again. Biggest problem with a bifold is tail height. For my aircraft, it makes the door framing a heck of a lot bigger than I really want. For a tail height of 15' on one of mine, it makes the bifold opening a minimum of 20' tall. When you couple that with a required span of 60', it makes for a very expensive door that has to be power operated, along with some significant structural needs. For my purposes, a biflod would end up costing nearly as much as the rest of the hangar itself. Craig C. |
On Sat, 17 Apr 2004 01:52:50 GMT, "Blueskies" wrote:
http://www.hi-fold.com/ Dig the photo of the hangar-house on the right, on the "Applications" page! all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
Thanks for the link. Very helpfull
Jean-Paul "Blueskies" wrote in message m... Not these doors, which is what I have. They have the aux arms on the sides which allow them to open further with a given opening... http://www.hi-fold.com/ -- Dan D. . "Craig" wrote in message om... Ron Rosenfeld wrote in message . .. It came with an electric bifold door. In spite of winter ice and snow, the door has never given any trouble whatsoever. No tracks in the ground to freeze up or buckle. The only time I couldn't open the door was when the airport had a power failure. I would do it again. Biggest problem with a bifold is tail height. For my aircraft, it makes the door framing a heck of a lot bigger than I really want. For a tail height of 15' on one of mine, it makes the bifold opening a minimum of 20' tall. When you couple that with a required span of 60', it makes for a very expensive door that has to be power operated, along with some significant structural needs. For my purposes, a biflod would end up costing nearly as much as the rest of the hangar itself. Craig C. |
"Blueskies" wrote in message om...
Not these doors, which is what I have. They have the aux arms on the sides which allow them to open further with a given opening... http://www.hi-fold.com/ They don't gain as much headroom as you think. By their own spec's, the vertical height of the door opening will need to be nearly 30" over the height that I would need. Besides, here in the summer time heat and wind, a bifold is a PITA. It's too hard to regulate airflow through the hangar. Craig C. |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Instrument Flight Rules | 10 | April 19th 04 12:37 AM |
wanted: hangar door tips | Joa | Home Built | 35 | April 18th 04 02:19 PM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Naval Aviation | 0 | April 6th 04 12:58 AM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Military Aviation | 0 | April 6th 04 12:58 AM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Instrument Flight Rules | 0 | April 6th 04 12:57 AM |
