Of clocks and learning curves...
Old May 23rd 04, 01:13 AM
Jay Masino
Jim Weir wrote:
snip
the terminal strip somewhere between the firewall and the instrument panel in an
easily accessable spot. Wire one lead of the terminal strip to airframe ground
and the other lead of the terminal strip to a wire going back to the
aforementioned keep-alive breaker on the battery box. Then wire the clock to
the terminal strip. Trust me, you will some day need to connect a radio or
other device to the keep-alive breaker and it is a hell of a lot easier to run
two wires to a terminal strip than another wire all the way back to the
tailfeathers battery.
Exactly! I don't understand why Jay or Jay's A&P is fooling with the
master switch or anything presently under the panel (unless he has an
existing memory keep-alive). If he doesn't take your advice and use the
terminal strip, he should atleast go directly to the battery (thru a fuse
or circuit breaker.
--- Jay
__!__
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old May 23rd 04, 01:39 AM
Newps
"Aaron Coolidge" wrote in message
I think Piper did it this way because the battery is in the tailcone, not
just on the other side of the firewall,
Many Cessna's, including my 182, have the battery behind the baggage
compartment.
As other have pointed out, Cessna airplanes have a small fuse right next
to
the battery to run the clock and the hobbs meter
I found this out the hard way. I had a leak in the rear window. It rained
and the water ran down and onto the master contactor, shorting it out and
turning it on, rendering the master switch on the panel useless. I learned
from this that my battery will run the turn coordinator and some instrument
lights for about 19 hours before it goes dead.
Old May 23rd 04, 01:45 AM
Ray Andraka
The piper master connects the low side of the master solenoid winding to
ground. If you wired the clock to the 'high' side of the master switch, you
are powering the clock thorugh the master solenoid winding when the master
switch is off, and turning off the power to the clock (grounding the V+ clock
input) when the master is 'pn'. The clock must have a capacitor that keeps
it alive for about 15 sec after power is gone. Try hooking it up to a 12
battery, then removing power. I bet it stays on for 15 sec.
Jon Woellhaf wrote:
Jay wrote, "Apparently the Piper master switch -- on the hot side only --
"powers down" after 15 seconds! Some solenoid somewhere gets thrown,
grounding the circuit and killing power to the hot side of the master
switch."
What?! I'd love to see a diagram of that circuit.
Jon
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old May 23rd 04, 01:51 AM
Ray Andraka
The purpose of that circuit is to turn on the master solenoid. That is
that way so that there is only one wire needed to control the master
solenoid. Otherwise, you'd need an always hot wire going to the panel
throught the master switch and then back to the solenoid (which needs two
wires). It also has an advantage of restricting battery voltage to the
battery box area when the master is in the off position so that there is
less chance of an electrical short that can't be isolated by turning off
the master.
Jay Honeck wrote:
ASCII schematic:
(+ Battery)---(solenoid)-----(master switch)-----(- battery)
Thanks, Aaron.
For us electrical dimwits, can you explain the purpose of this circuit?
Also, why is there a 7-second delay after turning the master switch on?
Here's how it works:
1. The clock is connected to the "hot" side of the master.
2. It works fine with master "off"
3. Turn Master Switch "on" -- works fine for seven seconds.
4. At seven seconds, the clock goes out.
5. Turn Master Switch "off" and the clock comes back on.
What's going on? Why is this circuit set up to do this?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
--Ray Andraka, P.E.
email
Old May 23rd 04, 01:55 AM
Ray Andraka
The master solenoid is right next to the battery box. Running that extra wire is a pain
in a PA-28, it involves pulling off the left interior sidewall. Piper didn't put it in
there originally because the airplane did not have anything outside of the battery box
that needed always on power (the clock was a mechanical clock).
"G.R. Patterson III" wrote:
Newps wrote:
So why dis Piper wire it that way?
Well, if you re-read Jay's original post, you'll see that Piper didn't wire the clock
that way. Jay's mechanic did. Jay's A&P could hook things up the way keep-alives are
wired on my Maule and my old 150, but that would require running the wire through the
firewall to the starter solenoid. Some A&Ps are reluctant to run new wiring through
the firewall.
So. Jay. Your mech is reluctant to run a wire all the way back to the battery.
Where's this master solenoid? That will be hooked directly to the battery. Maybe it's
convenient to hook up to that.
George Patterson
I childproofed my house, but they *still* get in.
--Ray Andraka, P.E.
email
Old May 23rd 04, 01:56 AM
Ray Andraka
No, it is under the back seat right next to the battery box
Judah wrote:
FIs the Master solenoid closer to the front of the panel than the Battery?
--Ray Andraka, P.E.
email
Old May 23rd 04, 03:13 PM
Judah
Oh. At that point he may as well wire it up properly then...
Ray Andraka wrote in
Battery?
--Ray Andraka, P.E.
email
Old May 24th 04, 02:35 AM
EDR
Jim Weir wrote:
snip
in an
ground
to
run
Do you also want some sort of current limiting resistor in line with
the clock wire?
When the solenoid is activated, doesn't it draw a slug of current?
I would hate to destroy the clock electronics as a result of current
spikes.
  #29
Old May 24th 04, 05:16 PM
Jim Weir
EDR
-Do you also want some sort of current limiting resistor in line with
-the clock wire?
Not unless the manufacturer of the clock put such a device in the installation
instructions. I can't tell you how many hours I've spent troubleshooting
problems that people "engineered" into their own systems by "making it better"
than the designer intended.
If a company manufactures aircraft clocks (or radios, or other electrical
devices) it is understood that there are going to be times when a spike comes
down the path. We all design in protective circuitry or some sort of spike
limiter/crowbar to limit the nasties. There are tens of thousands of articles
written on surge/spike suppression and there are tens of thousands of ways of
designing in that protection. What we CANNOT design in is protection from
somebody putting in a resistor or some other device that honks up something that
we did not contemplate.
-When the solenoid is activated, doesn't it draw a slug of current?
Not really. It is just another relay, albeit a pretty good sized one. And, it
is VERY close to the battery and wired with VERY heavy wire. Close and heavy
minimizes the inductance, and since the induced voltage is equal to L * di/dt,
and with that huge spike suppression capacitor called a battery on the line, the
spike should be relatively benign. NOTHING to compare to a starter motor firing
up.
-I would hate to destroy the clock electronics as a result of current
-spikes.
And the clock manufacturer would LONG since have been out of business if his
devices didn't take spikes into account.
http://www.rst-engr.com
  #30
Old May 24th 04, 06:07 PM
ShawnD2112
Jay,
what's wrong with a $20 Timex?
Shawn
"Jay Honeck" wrote in message
news:lEurc.36031$gr.3583857@attbi_s52...
So I picked up this nifty Davtron digital electric clock/timer at Sun N
Fun.
It's exactly the same model I had in my Warrior (Model 800), and I found a
good price for it. (Roughly 4 times what it's really worth -- a bargain
in
aviation!) Our wind-up clock had become sporadic in cold weather, and I
kept forgetting to wind it anyway...
My A&P took one look at the box and said "This will be a snap to install!"
This should have set off warning alarms right away, but it didn't. We
decided to do it at the annual, when everything was already ripped apart
anyway.
So, after most of the annual was complete, Darryl (the junior A&P in our
2-man shop) dug into it. As expected, it turned out to be a real
son-of-a-bitch getting at the backside of the panel. I ended up standing
on
my head under the panel, holding the clock in place with the very tips of
my
fingers, while Darryl carefully dropped the tiny little retaining screws
onto my belly, over and over again. It was fun! Really!
Eventually, through sheer persistence, he got the damned screws threaded
in.
Then the real fun began -- wiring! The directions clearly called for the
dimmer control wire to be connected to one of the panel lights, and the
hot
lead to go directly to the battery. Unfortunately the battery was in the
way back of the plane -- not exactly handy -- so Darryl decided to wire it
into the hot side of the master switch.
This made sense to me -- which, again, should have set off warning bells
in
my head, but didn't -- as the master switch was a heckuva lot closer than
the battery.
So I picked the plane up today, after reassembling the last little bits
and
pieces. Everything looked great, the engine fired up easily, I taxied
about
40 yards -- and the clock blinked out and died....
Immediately spinning the plane around, I shut the engine and master
down --
and the clock came back to life! So, I turned the master switch back on,
and *poof* -- 15 seconds later, the clock went blank.
What the hell!?
Darryl was completely stumped, and a huddle of wise old airport bums
immediately assembled. It was obvious that hooking up to the "hot" side
of
the master switch was NOT giving us continuous power -- but why?
No one knew, and I had to get back to the hotel. I took the plane back to
my hangar, and left the wise men standing there scratching their heads.
As soon as I got back to the inn, I called Davtron. Describing the
symptoms
to them, they immediately knew the problem. Apparently the Piper master
switch -- on the hot side only -- "powers down" after 15 seconds! Some
solenoid somewhere gets thrown, grounding the circuit and killing power to
They said I had two choices: 1) Run the power directly to the battery,
clear in the back of the plane, or 2) send the clock into Davtron, for
free
installation of a battery back up. This battery allows the clock to be
connected to the avionics master, rather than a "hot" wire.
I immediately called Darryl, and gave him the options. He has agreed to
fix the problem on Monday, whatever it takes, free of charge. Rather
than
take the thing out, send it to California, and reinstall it -- he's opted
to
run the wire to the battery...
Live and learn -- who'd ever think that installing a gol-danged CLOCK
would
be so hard?
Jay Honeck
Iowa City, IA
Pathfinder N56993
