Engine Analyzers
Old June 7th 04, 04:53 AM
Tom Sixkiller
"Ray Andraka" wrote in message
I'm very happy with my Reiff System. I've had it on my Six since 1997.
Made it
easy to add the JPI EDM700 last summer...all the CHT wells were still
open. The
heaters will get teh engine up to around 50 deg in a few hours with just
cowl
plugs on.
Tom Sixkiller wrote:
reason I have a Reiff system (bands, no probes)
How's that Reiff system worked for you? I'm about to go from needing
extra
cooling baffles (Arizona) to a engine heater (Colo. Springs). My F33A
already has an JPI-700.
What are your temperatures like during winter? Though the plane will be
hangared (non-heated, but with 120V power), the Springs can get down well
below zero.
I was wondering if a thermal blanket of soe sort would help (ie, what kind?
I'm sure one of my wife quilts would not be appropriate, for various
reasons).
Tom
Old June 7th 04, 03:06 PM
Ray Andraka
Typically it goes down to the mid teens. An insulated cover improves things (I
have an insulated cowl cover, but usually don't use it). The prop is a huge
heat sink too, and should also be insulated if you are leaving the heater
plugged in all the time.
Made it
open. The
cowl
plugs on.
extra
below zero.
reasons).
Tom
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old June 6th 04, 04:02 AM
Victor J. Osborne, Jr.
Ditto the voltage and fuel flow. FF works great with a GPS although you may
have to bump the fuel flow (pressure) because of the restriction of the
transducer. My fuel flow when from 25+ at sea level to 22. After adjusting
the pressure, we were back to good flow at takeoff and climb.
The voltage is redundant with a panel gauge but the alarm feature lets you
know if the alternator drops off. You will quickly add the JPI to your
normal scan.
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
take off my shoes to reply
Old June 8th 04, 07:06 PM
Robert M. Gary
"Victor J. Osborne, Jr." wrote in message ...
normal scan.
I plugged my EDM into my voice annunicator. That way if the EDM thinks
anything is wrong the annunicator says, "Check engine monitor". I
didn't have any noticable change in pressure with the transducer but I
fly a Mooney and sip my gas slowly.
-Robert
Old June 6th 04, 04:35 PM
Jerry Kurata
"M.E. Borner" wrote in message
om...
I am seriously thinking about installing an Engine Analyzer in my
plane and am looking at options. I think I have narrowed the choice to
J.P. Instruments or Electronics International. My mechanic has more
experience with JPI and feels their probes have a longer life. My
research has me leaning slightly towards EI for price, function and
design features.
I have an EDM-760 and am quite happy with the unit. When you do your brand
comparision be sure you are comparing apples to apples. Ensure both units
have memory and the same probe sets. Also, shopping at a show such as
Oshkosh can save a lot of money. I got my unit for 60% of the list price by
going between vendors and seeing if they could beat the other guy's price.
I ended up buy from Pacific Coast Avionics, whom I highly recommend. At
Oshkosh, JPI was also throwing in free additional probes. I got sets for
oil, TIT, and a second TIT readings.
When you get the unit make a habit of dumping and analyzing the memory. If
you know what you are doing you can see things like exhaust valves and plugs
going bad many hours (and dollars) before they make their appearance known.
jerry
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Engine... Overhaul? / Replace? advice please text news Owning 11 February 17th 04 04:44 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
