"Steven Barnes" wrote in message om...
Doesn't leaving the tanks partially empty cause problems with condensation or something along those lines? The only time I've ever found water in my tanks was when an IA didn't properly adjust the caps after replacing the O-rings. As a general rule, my partner and I agree to never leave the plane with more than 15 gals per side. Sometimes we leave it will much less. My theory is that if your flight is so full of danger that you need to land with 3 hours of fuel, you probably should consider not going. We also have an on-board fuel computer. The performance of a Mooney with 30 gals of gas is WAY better than a Mooney with 64 gals. Putting 64 gals of gas in a Mooney is like using a Corvette to pull your boat. It just makes it slow. We use a stick to measure the tanks, I've never found the computer to be off by more than 0.2 gals. -Robert |
om... 4) Its crosswind performance is ugly, particularly for take-offs. The undercarriage uses rubber disks for its springs, and the wing is very low to the ground. Hence any bumps and you lose any side force from the wheels, and you have a lot of lift relatively early in the take-off roll. If you operate an M20J from a single runway airport in a windy part of the world, this may be an issue. If you only rarely have to deal with 20 knot crosswinds, no problem. I fly around the Southwest. Take off and landing with 25-30 knots of cross wind is no problem. That does surprise me. I'm coming to the conclusion that either: a) you measure knots differently :-) b) you accept different levels of risk or c) you have a technique that I will never master I'm quite happy to accept that it's (c), but would still offer the caution about xwind performance to a prospective M20J purchaser. While many manufacturers choose to demonstrate 20 or 25 kt for certification, Mooney gave the M20J the bare minimum 11 kt (0.2 Vso) max demonstrated crosswind component. That suggests to me that crosswind performance was not high on the list of selling features. Julian |
cross wind is no problem. That does surprise me. I'm coming to the conclusion that either: a) you measure knots differently :-) b) you accept different levels of risk or c) you have a technique that I will never master I'm quite happy to accept that it's (c), but would still offer the caution about xwind performance to a prospective M20J purchaser. While many manufacturers choose to demonstrate 20 or 25 kt for certification, Mooney gave the M20J the bare minimum 11 kt (0.2 Vso) max demonstrated crosswind component. That suggests to me that crosswind performance was not high on the list of selling features. Those numbers didn't sound right so I checked my 1965 M20C (short rudder) manual which lists a demonstrated crosswind of 15 kt (17 mph). I bet the M20J is higher than that. I have landed in up to 20 kt with not much rudder left. 25-30 kt, well, that's a lot. Could it be done, I bet. I'll be happy to try it in your airplane; I just don't like the thought of having to file an insurance claim for a prop strike and the associated downtime. Bob Miller |
"Bob Miller" wrote in message
m... Those numbers didn't sound right so I checked my 1965 M20C (short rudder) manual which lists a demonstrated crosswind of 15 kt (17 mph). I bet the M20J is higher than that. No I promise you, it's 11 knots (at least it was on our 1982 M20J). That doesn't necessarily mean that the M20J has less capability, just that Mooney didn't certify it to that capability. Julian Scarfe |
"Julian Scarfe" wrote in message ...
"Robert M. Gary" wrote in message om... 4) Its crosswind performance is ugly, particularly for take-offs. The undercarriage uses rubber disks for its springs, and the wing is very low to the ground. Hence any bumps and you lose any side force from the wheels, and you have a lot of lift relatively early in the take-off roll. If you operate an M20J from a single runway airport in a windy part of the world, this may be an issue. If you only rarely have to deal with 20 knot crosswinds, no problem. I fly around the Southwest. Take off and landing with 25-30 knots of cross wind is no problem. That does surprise me. I'm coming to the conclusion that either: a) you measure knots differently :-) b) you accept different levels of risk or c) you have a technique that I will never master I'm quite happy to accept that it's (c), but would still offer the caution about xwind performance to a prospective M20J purchaser. I tell you, once you get down into ground effect you just don't feel the cross wind in the Mooney at all. Of course, I started my life flying 800lbs Aeroncas so I'm used to really feeling wind. ![]() -Robert |
cross wind is no problem. The plane sit so low that you don't even feel the cross wind in the flare. I landed a C - Model Mooney in a 52 knot quartering headwind in Gage OK. It was not easy but didn't make palms sweat. A 40 knot wind in a Cessna is about the same. In the panhandle of TX - OK the windsock is made out of a log chain. This is the reason you need a Bellanca if you are going to fly a single in the wind. |
If you're in the market for a fast, fuel-efficient single-engined tourer, there are 4 reasons not to buy a Mooney: Actually, there is one you missed. Cabin room. If you're a stick (tall and thin) and you like the sportscar position (legs stretched out in front of you, stuck into a narrow channel) you may well enjoy a Mooney. If you are shaped more typically, like to sit upright, and want room between you and the front seat passenger - think again. The late model Mooneys are not so bad (the Ovation is almost comfortable - almost) but I have some time in a K model Mooney and it is by far the most tight and uncomfortable aircraft I have ever flown, not excluding the gliders. Of course I am what might be called gravitationally enhanced, so the best advice I can give is this - decide how long your longest trips are going to be, and sit in one for that long. Then make your decision. Michael |
I flew this yesterday and it was nice (but what the hell do I know) He
is asking 105k but Vref says it is worth $113k. That seemed high but again what do I know. Any Mooney owners out there want to give an opinion on the M20J? You've looked at two Mooneys now. If you are serious about getting one, you really must join the Mooney list. You'll get more good information there than anywhere else: http://www.aviating.com/mooney/subscribe.html At minimum, read Bob Kromer's flight test reports on the various Mooney models: http://www.mooneypilots.com/flight_test_reports.html The 'J' will have newer avionics than the 'C' you looked at previously, it also cruises faster and burns more fuel. Plan on 10-15 kts difference in cruise speed between the 'C' and 'J', one gallon per hour more in fuel burn in the 'J' and 50% or more in operating costs, considering both fixed and variable costs. Of course the purchase price of a 'J' is twice what a 'C' is. Personally, I chose to buy 100% of a 'C' model Mooney rather than 50% of a 'J'. You're looking at the same money up front and ongoing expenses either way. --- Ken Reed http://www.dentalzzz.com |
Ken,
I jsut subscribed to the Mooney list. Guess there is no turning back now... :-) Thanks. Jon Kraus PP-ASEL Student airplane owner Ken Reed wrote: I flew this yesterday and it was nice (but what the hell do I know) He is asking 105k but Vref says it is worth $113k. That seemed high but again what do I know. Any Mooney owners out there want to give an opinion on the M20J? You've looked at two Mooneys now. If you are serious about getting one, you really must join the Mooney list. You'll get more good information there than anywhere else: http://www.aviating.com/mooney/subscribe.html At minimum, read Bob Kromer's flight test reports on the various Mooney models: http://www.mooneypilots.com/flight_test_reports.html The 'J' will have newer avionics than the 'C' you looked at previously, it also cruises faster and burns more fuel. Plan on 10-15 kts difference in cruise speed between the 'C' and 'J', one gallon per hour more in fuel burn in the 'J' and 50% or more in operating costs, considering both fixed and variable costs. Of course the purchase price of a 'J' is twice what a 'C' is. Personally, I chose to buy 100% of a 'C' model Mooney rather than 50% of a 'J'. You're looking at the same money up front and ongoing expenses either way. --- Ken Reed http://www.dentalzzz.com |
Any opinions on the Garmin GNS 480 ! ! ! | RonLee | Instrument Flight Rules | 18 | January 18th 05 12:33 PM |
Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 09:08 PM |
Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 04:15 AM |
OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 10:43 PM |
Rallye/Koliber AD's and opinions | R. Wubben | Owning | 2 | October 16th 03 05:39 AM |
