Poll: best bird under $35K?
Old October 31st 04, 09:55 PM
psyshrike
Default Poll: best bird under $35K?
Howdy,
My Requirements:
3 Humans, 4 hours, VFR, ~ 100 knots.
Put these in order of preference:
Piper Tri Pacer:
Pros: Low acquisition Cost, Tri gear
Cons: Often neglected. Ground Handling, old panel, parts support.
Stinson 108-x:
Pros: Most beautifull of the bunch, good performance.
Cons: Conventional gear, old panel, parts support.
Cessna 175 GO-300
Pros: Aluminum, tri-gear, it's a Cessna.
Cons: Short engine lifespan, parts support, old panel.
Square Tailed Cessna 172 (as in 58-59 models)
Cons: Probably more AD's than a 737, old panel
Piper Cherokee 140
Pros: Aluminum, Modern plane, modern panel.
Cons: Doesn't meet weight requirements.
As you can tell, I don't mind old birds. In any case, a well
maintained example will be a personal requirement. A good example of
the worst type is probably better than bad example of the best.
I've got about 250 hours + complex endorsement. I haven't been flying
for a while, but am starting to convince myself that getting another
aircraft is justifiable.
I don't have any time in any of these. I'm asking because I'd like to
narrow up the field before I start running around bugging sellers.
All comments welcomed.
Thanks!
Matt
Dream Airplane poll Bob Babcock Home Built 39 December 24th 04 02:20 AM
T Bird - ZackGSD Home Built 1 December 15th 03 01:47 PM
Tying down the bird david whitley Owning 17 September 23rd 03 03:57 AM
Bird control David Naugler Aviation Marketplace 7 September 22nd 03 03:40 PM
