What engine would you like?
Old January 22nd 05, 01:10 PM
Doug
Go up in a small GA single engine. Turn the radios off. Turn the
alternator off. Turn the Master off. Turn one magneto off. Note that
the engine keeps running. THAT's why they use magnetos.
I do agree that electronic ignition would be a good idea. The one's I
have seen revert to a mechanical system if electrical is lost. But you
cannot handprop them. And they add complexity and weight. There are
tradeoffs.
Old January 25th 05, 03:07 PM
Mike Rapoport
What I want is a turbo diesel. I would like around 400hp for short periods
to facilitate short takeoffs. 300hp would be fine after that. The engine
(installed) should not weigh significantly more than current six cylinder
designs. The improved fuel efficiency of a diesel would mean less fuel
weight for even better performance. The lack of magnetos means that only
fuel is needed to run once started. Air cooling would be nice for
simplicity.
MU-2
Old January 25th 05, 03:34 PM
Dan Luke
"Mike Rapoport" wrote:
What I want is a turbo diesel. ...Air cooling would be nice for
simplicity.
Do you know of successful air cooled turbo diesel applications? Would'nt you
be asking for thermal distribution problems in such an engine, along with the
large mechanical tolerances required to deal with them?
Dan
C-172RG at BFM
Old January 25th 05, 05:42 PM
Mike Rapoport
"Dan Luke" wrote in message
simplicity.
you
Dan
C-172RG at BFM
There are air cooled diesels made by Lombardini for use in tractors and
stationary applications. Diesels tend to run cooler than gasoline engines.
Air cooling should work better with a diesel than with a gasoline engine.
MU-2
Old January 25th 05, 06:20 PM
Aaron Coolidge
Dan Luke wrote:
: "Mike Rapoport" wrote:
: What I want is a turbo diesel. ...Air cooling would be nice for
: simplicity.
: Do you know of successful air cooled turbo diesel applications? Would'nt you
: be asking for thermal distribution problems in such an engine, along with the
: large mechanical tolerances required to deal with them?
Deutz makes large aircooled turbo diesels for the marine industry. 1500HP
and up. They don't have the greatest reputation because of lack of
appreciation of the necessity of keeping the air moving over them, and
the lack of skilled maintenance folks to keep them running. They're
available, though.
Aaron C.
Old January 25th 05, 10:27 PM
Matt Whiting
simplicity.
I don't know of any in aircraft, but I believe at least one Ag company
had an air cooled diesel (I want to say Deutz, but am not 100% sure).
The biggest problem is making a diesel that is both robust and the same
weight as an equivalent power gasoline engine. The high compression
required for auto ignition comes at a significant penalty in either
weight or reliability ... and most of us want our airplane engines to be
reliable so you pay in weight.
Matt
Old January 25th 05, 04:51 PM
Thomas Borchert
Mike,
designs.
Well, the Thielert Centurion 4.0 will be (almost) that engine, depending on
your definition of "not significantly" and your ability to forget about the
400 hp. IMHO, that requirement doesn't really make sense anyway: Why design
something for 400 hp and then run it at only 300?
Not necessarily, with a modern diesel.
simplicity.
Depends on your view of "simplicity".
Thomas Borchert (EDDH)
Old January 25th 05, 05:32 PM
Markus Voget
Thomas Borchert wrote:
Mike,
periods to facilitate short takeoffs. 300hp would be fine after
that. The engine (installed) should not weigh significantly more
than current six cylinder designs.
FYI, you can see (and hear) it running at
http://www.hp-aircraft.de/img/27-09-04-3.MOV
If you prefer two of them in a taxiing aircaft, try
http://www.hp-aircraft.de/img/TT62%2...%2003dez04.AVI
Greetings,
Markus
Old January 25th 05, 05:50 PM
Mike Rapoport
"Thomas Borchert" wrote in message
Mike,
periods
engine
designs.
on
design
simplicity.
Every geared engine that I know of allows higher rpm and hence horsepower
for takeoff and then requires a rpm reduction. I think that radials are
rated for take-off and then have a METO (maximium except take off) rating
which is less. Come to think of it every normally aspirated engine has more
power for take-off than for cruise because of air density.. Seaplanes also
need a lot of power for adequate takeoff performance but not thereafter. I
flew a Murphy Moose with a 360hp engine. We used full power for takeoff but
once at cruise we were back to 50% power. The Moose would do 145mph on
under 14gph but only 155 on 23gph so it only needed the big engine for
takeoff.
MU-2
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
