GPS Models -- Pros and Cons
Old July 22nd 03, 04:08 PM
John T
"Ryan Ferguson" wrote in message
Another significant downside to the interface problem is your
head-down time. The amount you spend looking inside with the PDA vs.
the GPS will be greater.
Not necessarily.
Using just the moving map display on both units, for example, will not show
a difference in head-down time.
Depending on the type of activity you're doing, either unit can cause more
head-down time than the other.
The fact remains that the only way to truly evaluate the difference is to
take a flight with both units.
John T
http://tknowlogy.com/tknoFlyer
__________
Old July 22nd 03, 08:17 PM
Nosegear
Thanks, you're right. Does that also go for built-in aviation GPS's/Moving
Maps? I assume there is some sort of certification there?
Nosegear
"Dan Luke" c172rgATbellsouthDOTnet wrote in news:vhon26on7bqm72
@news.supernews.com:
"Nosegear" wrote:
Last advantage I can think of is also a disadvantage: you do not pay for
certification of the equipment (I'm sure Garmin and others have some
percentage for that in the price)
Nope. Portable GPS's aren't certified.
Old July 22nd 03, 10:35 PM
Dan Luke
GPS's/Moving
Yes. There are various levels of certification for units installed in
certified aircraft.
Dan
C172RG at BFM
Poll: best bird under $35K? psyshrike Owning 38 November 22nd 04 01:56 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
