Tiny vacuum pump
Old January 17th 04, 08:07 AM
David Pincus
Does anybody have an idea on how to make a tiny little vacuum pump on the order
of an aquarium pump or so that will draw just a few inches of water? Preferably
110, but I can rig up a 12 volt supply if necessary.
The reason I say this is that I'm getting ready to pack a fairly large number of
bags with used but serviceable engine parts (valves, pistons, etc.) and I'd like
to put each part in a "baggie" (sandwich bag or equivalent) along with a little
preservative oil, and then suck the baggie down with a football needle stuck
into the top closing mechanism just before sealing.
Thoughts?
Jim Weir
-Ben Jackson wrote:
-You just need a surplus dental spit sucker. Perfect for removing air
-from the corner of a plastic bag.
PERFECT. Where do I find one? Are there boneyards for dental equipment?
Jim,
What you want is a Gomco. They make most all the dental/medical suction
equipment. Any of them will consist of the vacuum pump and a glass bell
jar to pull the fluid into. We used these in our portable dental clinics
in the Army.
I did a quick search on Google for "gomco suction used" and the first
hit was for a used machine for $109:
http://websites.medmatrix.com/detail.CFM?LineItemID=630.
The whole list is at:
http://www.google.com/search?hl=en&l...o+suction+used
There is another solution to your problem. You said it yourself,
baggies, but not the old kind. They make new ones with a plastic zipper
and they seal absolutely air and water tight, and you can get them in
any size up to 3 ft in size, what are called "game bags" for deer meat,
etc. for your larger engine parts.
With whatever size you put in your part, as much preservative oil as you
want, seal it up, shake the bag to coat the part, then vent the zipper a
bit and flatten the bag out as much as possible and zip the last bit
shut. What little oxygen is in there shouldn't harm your oil-coated
parts. If you really want to got all the O2 out, rent a tank of CO2 or
Nitrogen and crack the valve just enough to blow low-pressure gas into
the bag as you seal it to drive out any room air. Then whatever air is
left inside is inert.
Regards,
David Pincus, DDS
Major, USAR (RET)
Old January 17th 04, 09:30 AM
Mark Mallory
mikem wrote:
My wife bought a vacuum bagging freezer food storage system. It sucks
Mike: ask Ron Jones about how we made a vacuum pump out of an old Briggs and
Stratton lawnmower engine (we were trying to make our own freeze-dried food...)
Probably not the most time/cost-effective solution, but we sure had fun!
Mark/C182L
Old January 17th 04, 10:56 AM
B
Take the brake system vacuum pump from the back of the alternator on almost
any diesel light truck, 4wd, etc. For the level you are looking for you
could probably hand crank it with a lawn mower zip starter and use it's
return spring to set it for the next pull.
Depends on how green you want to be, you're both recycling and people
powering it!
Bushy
Old January 17th 04, 06:21 PM
Big John
How well do you expect a system to evacuate whatever you use around
the parts and how long do you want the bagged item to stay pristine?
You can kludge a system but may or may not work in the short or long
term for your objectives.
If you bite the bullet and spring for a food saver, their bags can be
reused - we normally make them bigger than required for initial
bagging and then just cut the sealed tip end off and the bags can then
be reused for the next item.
The food saver is debugged and is plug and play without spending any
time designing some kludge. What is your time worth?
And the best
Big John
Pilot ROCAF
Using the food saver you can buy plastic and cut size you want (that
will fit food saver) and make bags (using the food saver to seal each
side before evacuating and sealing the last side.
Start thinking off the wall Jim G
50% Scotch and look for the best and cheapest to do the job.
On Fri, 16 Jan 2004 09:26:50 -0800, Jim Weir wrote:
Because Foodsaver requires you to use their special bags. Besides being WAY
overpriced, the bags ain't cheap either. Yeah I knew about pump'n'seal, but
that seems to be a kluge way of doing it. I was looking for elegant.
"Ron Natalie"
-Why don't you just get a foodsaver? (www.foodsaver.com). It will do the
-vacuum pack as well as sealing the bag (and you can make arbitrary sized bag
-as long as it's narrower than the roll of "bag stock." I've got one in the
kitchen.
-If that's too pricey for you, then there's always this one $14.94, not sold in
stores....
-http://www.pump-n-seal.com/
http://www.rst-engr.com
Old January 17th 04, 07:03 PM
Tom Pappano
Thoughts?
If you have compressed air already available, there are small venturi
vacuum generators you can use. They are just a tiny chunk of
aluminum with three 1/8" pipe threaded ports, air in, air out,
and vacuum. The one in my "solder sucker" pulls about a
26" vacuum and damn quick too! A "baggie" would be evacuated
almost instantly.
Tom Pappano, PP-ASEL-IA
Old January 18th 04, 07:54 AM
Phil Sisson, Litchfield Aerobatic Club
Try using warm oil, not hot enough to melt through, roll the air out of
the baggie, seal it and as the oil cools, maybe it will pull it own
vaccuum...
Old January 18th 04, 12:24 PM
James R. Freeman
Jimmy:
Use an old compressor from a freg. I have a high dollar Freon pump but
use the old G.M. compressor more.
"Jim Weir" wrote in message
order
Preferably
number of
I'd like
little
stuck
Thoughts?
Old January 18th 04, 05:30 PM
In rec.aviation.owning Mark Mallory wrote:
: Mike: ask Ron Jones about how we made a vacuum pump out of an old Briggs and
: Stratton lawnmower engine (we were trying to make our own freeze-dried food...)
: Probably not the most time/cost-effective solution, but we sure had fun!
: Mark/C182L
Probably like my dad's 1939 Oliver 60 tractor. It has a stopcock
on the intake manifold for milking one cow at a time if the electricity
went out. Probably too big to fit on your desk though...
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
  #29
Old January 18th 04, 05:36 PM
In rec.aviation.owning Jim Weir wrote:
: Does anybody have an idea on how to make a tiny little vacuum pump on the order
: of an aquarium pump or so that will draw just a few inches of water? Preferably
: 110, but I can rig up a 12 volt supply if necessary.
I've actually got one of these at home. I found it from a pile of
surplus equipment. It doesn't pull much vacuum, but it basically is an
aquarium pump. I'll try to find a model number on it and report back.
-Cory
* The prime directive of Linux: * * - learn what you don't know, * * -
teach what you do. * * (Just my 20 USm$) *
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 05:53 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 04:11 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Fiberglass Vacuum Bagging Technique...Resin Infusion Steve Home Built 5 August 8th 03 06:10 PM
