VOR and reverse sensing
Old August 15th 03, 07:18 AM
Koopas Ly
Default VOR and reverse sensing
Hi all,
What is meant by reverse sensing?
Say I am southeast of the VOR station, and want to head straight to
that station in a northwest direction, at a heading of 300. I tune
and identify, and currently track the 300 radial (300 on the OBS),
with a "TO" indication, and the needle centered. If I wander to the
right of my course, the needle will swing to the left, so I'll turn a
few degrees to the left and rejoin the 300 radial.
First, am I tracking the 300 inbound radial or the 300 outbound
radial? What is the proper terminology?
Second, what if, instead of heading 300, I was heading 120. In other
words, what if I was heading in the exact reciprocal direction with
the OBS still at 300 and a "TO" indication? I assert that the needle
would still be centered; however, how would someone know that he's
indeed headed TOWARDS the station and not away from it?
Thanks!
Alex
Old August 15th 03, 09:05 AM
Hilton
Koopas wrote:
Hi all,
You are tracking the 120 degree radial inbound. You don't have inbound or
outbound radials. You have radials, and you can be inbound or outbound on
one of them. You are on the 120 radial, not the 300 radial.
Because you'd have reverse sensing! Seriously, VORs have no idea which
way you're headed. Once you remember that, then things become easier. Now,
you are on the 120 radial headed AWAY from the VOR with 300 dialed in on the
OBS and you have a TO flag - because as far as the VOR receiver is
concerned, a 300 degree course would take you TO the VOR (remember, it
doesn't know which way you're going). Now, if you deviate to the right, the
needle will move to the RIGHT (reverse) because it thinks you're flying TO
the VOR and have deviated to the LEFT. That is reverse sensing. I don't
like the name cause it somehow implies the VOR is doing something
different - it isn't. It should be called "The pilot screwed up and dialed
in the wrong radial".
Hilton
Old August 15th 03, 11:21 AM
Thomas Lembessis
(Koopas Ly) wrote in message . com...
Hi all,
If you're Southeast of the station, and are flying toward the station,
it is the 120 degree radial you are flying, not the 300. The 300
radial only exists northwest of the VOR; the 120 exists southeast of
the VOR.
You are tracking the 120 degree radial; there is no
inbound/outbound distinction. VOR is a position instrument. The fact
that you are tracking the 120, with your OBS set at 300 is what
produces the "TO" flag on your omni head display.
If your OBS is set at 300, and you have a "TO" indication, and your
heading is 120, you are flying AWAY from the station.
This would be where the "Reverse sensing" you describe would take
place.
To track the radial, you would fly away from the needle.
Thanks!
Alex
Hope this Helps
Thomas Lembessis
ATP, F/E (B-727)
Old August 15th 03, 02:21 PM
Tim Bengtson
Here's a site that may just change your life:
http://www.campbells.org/Airplanes/VOR/vor.html
Tim
Old August 15th 03, 09:01 PM
flyer
The concept that changed my way of thinking about VORs was that of the
"Poor man's HSI" published in IFR Refresher. Basically, superimpose
an imaginary airplane centered on the VOR dial with the nose pointed
at the OBS bearing that corresponds to your current heading. The
needle of the CDI now represents the location of the selected radial
with respect to the airplane flying that heading. It is easy to do
intercepts this way. Think of an OBS set at 090 degrees and you have
a right needle and a TO flag, for example. How would you intercept?
Put an imaginary airplane in the center of the dial with the nose
pointed at 120, for instance. That would intercept because the
airplane is flying toward the right deflected needle. This works out
best graphically with a VOR indicator that uses has a lateral
displacement needle rather than one that pivots from the top or
bottom, but both work. Would the intercept be TO or FROM the station?
If the TO indicator is showing at the top you would be intercepting
TO the station since your airplane is pointing toward the top of the
dial. If you put the imaginary airplane at a heading 210 you would
also intercept but heading is taking you away from the station. If
you put the imaginary airplane at a heading of 070 you would clearly
be flying away from the selected radial and would not intercept.
Tim Bengtson wrote in message .. .
Tim
Old August 15th 03, 05:18 PM
Jon Kraus
Read this and then get back to us. It helped me tremendously. Good Luck.
Jon Kraus
PP-ASEL
Student-IA
Koopas Ly wrote:
Hi all,
Thanks!
Alex
Old August 16th 03, 04:20 AM
Andrew Sarangan
Here is an article I wrote, similar to the one cited below, on how to
avoid reverse sensing altogether.
http://131.238.38.204/~sarangan/avia...or-article.pdf
Jon Kraus wrote in message ...
Jon Kraus
PP-ASEL
Student-IA
Koopas Ly wrote:
Hi all,
Thanks!
Alex
Old August 15th 03, 07:20 PM
Mike Rapoport
"Koopas Ly" wrote in message
om...
Hi all,
If you are SE of the VOR then you are not on the 300 radial. Think of
radials as "radiating" out from the VOR. In your case you are on the 120
radial inbound
If the needle was centered and you turn left and the needle goes left then
you would know that you are headed away from the VOR.
Thanks!
Alex
Old August 15th 03, 08:10 PM
Ross Oliver
I think the main thing that confuses people about VORs is
differentiating between location and course guidance. So let's
remove the couse guidance aspect for a moment:
Imagine you are in a helicopter in a stationary hover pointed
at 360 magnetic. You tune in a VOR and set the OBS to 360. The needle
deflects full left. What does this mean? It means that the imaginary
line starting a the VOR and radiating out (hence "radial") toward the
magentic north pole is located somewhere to your left. Now you do a
180-degree pedal turn so your helicopter is pointed at 180 degrees.
What will happen to the CDI needle? Nothing, because you are stationary.
It will still be deflected full left. However, because you have turned
180 degrees, the radial is now actually to your right. THAT is reverse
sensing.
Another way to think of it is the CDI needle tells you which
direction you need to turn the OBS in order to center the needle.
So now you push the cyclic forward and start your helicopter moving.
You now want to use your CDI for course guidance. If your current
heading is within +/- 90 degrees of your OBS setting, the CDI needle
will be a "command instrument", i.e. it will tell you which direction
to turn in order to intercept the selected radial. If your current
heading is MORE than +/- 90 degrees from your current OBS setting,
then you must turn in the opposite direction of the needle to intercept.
So what about the TO/FROM flag? Your OBS is still set to 360. Now
draw a line perpendicular to 360 passing through the VOR. The TO/FROM
flag can tell you on which side of this perpendicular line you are
located. Like the OBS setting, the TO/FROM flag is NOT related to
what direction your aircraft is pointed. If the flag is indicating
FROM, then you are on the same side of the perpendicular line as the
360 radial. An indication of TO means you are on the opposite side
of the line.
Happy landings,
Ross Oliver
