Flying with fuel leak?
Old September 26th 03, 06:03 PM
Maule Driver
"G.R. Patterson III" wrote in message
I have proven empirically that keeping the tank switched to L or R helps.
Both
the local ramp by the fuel pumps and my tiedown are on slopes. If I fill
tanks to 1.5" below the filler tube (which is normally safe), park on my
tiedown, and leave the selector in the "off" position, the right tank (the
uphill one) will be down about 1/4 tank a week later. Leave the selector
on R,
and I'll still have full tanks. Similarly, if I leave the selector "off"
while
I'm fueling, frequently the downhill tank will overflow before I finish
paying
for the gas. I have developed the habit of leaving the selector on the
uphill
tank, but I cannot give you a good reason for doing that instead of the
downhill
one.
Thank you so much for the empirical results.
The newer maintenance manual (not my original one) references the
desirablity of leaving the fuel selector in "L" or "R" position when parked
to prevent tank to tank transfer. This implies that tank to tank transfer
can occur when the selector is either in the 'off' or 'both' position.
The bare spots are finally growing over in front of my hangar after 3 years
of the 'killing leaks'.
Old September 26th 03, 08:36 PM
Gene Seibel
You just need to fly faster. SR-71 Blackbirds leak until they get up
to about mach 3.5.
Gene Seibel
http://pad39a.com
I was looking over the web site of a flying club that posts the minutes of
their meetings. One item said that fuel was running out of the wing of
their 172 when the flaps were fully extended because the overflow drain was
broken. They asked that the tanks not be completely filled until this could
be fixed.
Am I just overly compulsive about maintenance or are these people nuts?
Northern NJ Flying Club Accepting New Members Andrew Gideon Aviation Marketplace 1 June 12th 04 04:03 AM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 06:56 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 01:07 AM
Flying with fuel leak? Roger Long Owning 21 September 26th 03 08:36 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 01:05 AM
