PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported
Old January 21st 12, 02:48 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default PowerFLARM Portable - Firmware Update Available - Mode C TrafficNow Supported
this
triggers the transmission of an identification impulse
JJ
Probably something got lost in translation........... I remember the
SN-10 manual that stated; "With a sharp knife, pry the 3 knobs off the
face of the instrument", when it should have said; "With a sharp
knife, pry the caps off the 3 knobs located on the face of the
instrumrent".
Dave was flabbergasted when he heard what I had done! Nothing is more
dangerous than a misinformed individual trying to do it right!
:) JJ
Old January 22nd 12, 12:57 AM posted to rec.aviation.soaring
Dave Nadler
On Saturday, January 21, 2012 9:48:22 AM UTC-5, JJ Sinclair wrote:
... Nothing is more dangerous than a misinformed individual
Especially if he has a knife.
And/or has been watching Fox "News".
Old January 22nd 12, 01:22 AM posted to rec.aviation.soaring
Dan Marotta
Default PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported
Well, since I never heard back from Trig, here's what they told me about
pressing the IDENT button:
Pressing the "IDENT" button sets a flag in the transponders Mode A and
Mode S replies for 18 seconds to allow ATC to identify you quickly
(*Note: not Mode C replies, as this is just altitude data). It does not
force the transponder to transmit and it will still need to be
interrogated in some way either by TCAS or a ground SSR. However, the
Trig TT22 also sends out Mode S Squitter transmissions independent of
any interrogation. The squitter contains acquisition data and is
broadcast approximately twice a second, this acquisition data also
includes the IDENT flag.
"JJ Sinclair" wrote in message
On Jan 20, 7:43 am, "Dan Marotta" wrote:
Having installed a Trig TT22 in my LAK-17a, I've noted that, when I press
the IDENT button, the reply indicator turns on for some finite time which
is
longer than a normal reply to an interrogation. Since I know absolutely
nothing about transponder protocol, I sent a message to Trig's tech
support
and got a very detailed reply about how it works.
Not wanting to step on any toes (unusual for me, huh?), I replied to Andy
at
Trig thanking him for the information and requesting permission to post
his
reply. If he says, "Yes", I'll post it here.
In the mean time, Steve's info sounds correct to me.
"Steve Leonard" wrote in message
On Jan 20, 3:15 am, GC wrote:
I'd be interested to know how pressing IDENT causes a flag to be set on
the controller's display 100 miles away without any transmission from
the transponder. Telepathy?
GC
As my education continues to rise, allow me to pass along what I think
I have learned. When you press the IDENT button, you tell your
transponder "If I get interrogated in the next X seconds, reply with
this extra bit of information as well." And X seconds is the amount
of time your "reply" light is on after you push the IDENT button.
This additional information that is sent will be received by the
ground station and set a flag to highlight you on the display for the
controller.
Have not personally verified this, but have gotten the same info from
what I consider to be a couple of VERY good sources. So, it is not
done via telepathy, but anticipation. You are asked to IDENT, you do,
and you prepare your transponder for the next interrogation.
See how much we learned this week? :-)
From my Becker 4401-3 manual.
Pressing Ident button (will)............. In mode A and Mode A+C this
triggers the transmission of an identification impulse additional to
the Mode A reply code for approx 18 seconds. During this time "idt"
appears in the bottom line of the LC display.
It says, "triggers the tranmission"
I'm just say'n,
JJ
Old January 22nd 12, 01:28 AM posted to rec.aviation.soaring
Dan Marotta
BTW, in my original post I said that the REPLY indicator displayed in
response to pressing the IDENT button. I checked that today and I was
wrong. There's a separate IDENT indicator in addition to the REPLY
indicator on the Trig transponder.
"Dan Marotta" wrote in message
is
support
at
his
GC
controller.
I'm just say'n,
JJ
Old January 22nd 12, 01:50 AM posted to rec.aviation.soaring
Darryl Ramm
On 1/20/12 9:28 AM, Marc wrote:
On Jan 20, 8:42 am, JJ wrote:
[snip]
My vague understanding of how SSR (Secondary Surveillance Radar) works
will probably help make sense of the Ident function. The classic SSR
setups use a highly directional transmit/receive antenna that rotates
at either 6 or 15 RPM (if I remember correctly). The transmitter
emits inquiry pulses as it rotates, when a reply is received, the
rotational position is used to determine azimuth, the delay between
the last transmission and the reply determines distance. Pushing
Ident simply sets a flag within the transponder that results in a
specific bit being set (in addition to the selected code) in the reply
when the next inquiry is received. The flag remains set for 18
seconds to ensure that at least one Ident reply is transmitted. Note,
though, that if the antenna isn't pointing at you, it can't see the
reply, so (at least for Mode C transponders) when you press Ident,
nothing is transmitted unless an SSR inquiry is received within the
next 18 seconds...
Marc
Marc has it pretty nailed here.
Some extra comments...
In classic Mode A/C interrogations the ident (SPI) bit is set in Mode A
transmissions only. All the "Mode C" transponders out there reply to
both Mode A (any transponder receiving this interrogation reply with
your squawk code) or Mode C (any transponder receiving this
interrogation reply with your altitude) interrogations. Ground based SSR
systems will interrogate with an interleaved pattern of Mode A and Mode
C interrogations, with typically several (few to tens) of interrogations
of the transponder as the rotating beam sweeps past the aircraft (all
this happens very fast, you only see one blink of the interrogation
light). Other interrogators like TCAS and TCAD systems only issue Mode C
interrogations so never see your squawk ID and never know if you are
pressing Ident etc. (and would not know/care what to do with it anyhow).
Just to confuse things technically that extra ident pulse in Mode A
replies is called the SPI for "Special Position indicator" but it adds
no position information, its just telling the interrogator that there is
something "special" about this reply and ground based SSR systems just
highlight that corresponding aircraft symbol on the controller's display.
Mode S (e.g. in the case of the Trig transponder that started this) is a
bit more complex but the idea is basically the same. A Mode S
transponder will reply to a Mode S interrogator with a digital data
packet, not a simple pulse train that Mode A and Mode C signals use,
and within that digital packet reply is a single SPI bit that has
exactly the same meaning as the SPI pulse in a Mode A reply. Mode S
transponders will reply using conventional Mode A/C signals to non-Mode
S capable interrogators, and will transmit a SPI pulse in their Mode A
replies.
The reason for singling out Mode S is that it invites some extra
confusion. All Mode S transponders transmit a 24 bit ICAO aircraft
identifier that uniquely identifies your aircraft (a unique 24 bit
pattern tied to your callsign/registration, but not directly encoding
your callsign). This ICAO ID is totally separate from the squawk code
and SPI bits that are also transmitted within the digital packets (I'm
simplifying here as there are multiple different Mode S messages types).
I've seen some confusion where people think pressing ident with a Mode S
transponder causes the transponder to send, or to reply to
interrogations with either one or more of your ICAO ID, callsign etc.
All it does is set that SPI bit. ATC gets to see your aircraft's ICAO ID
at all times you are within Mode S SSR radar coverage (basically all ATC
radar coverage).
Mode S transponders are also different from "Mode C" transponders in
that they are capable of transmitting in cases when they are not
interrogated. The common examples being acquisition squitters that are
short messages to advertise their presence to TCAS equipped aircraft--to
help cutdown in unnecessary TCAS interrogations. And the extended
quitter used by ADS-B 1090ES data-out (if the extra ADS-B data-out
equipment is installed/configured/turned on). The extended squitter will
tranmsit ADS-B GPS derived position data etc. about once per second
within a Mode S digital packet. Pressing the ident button on a Mode S
transponder has nothing to do with acquisition or extended squitters and
does *not* cause ADS-B or any other data packet to be transmitted (its
dumb as nails and just sets that SPI bit/pulse in Mode S or Mode A
replies for the next 18 seconds).
Please don't go pressing the ident whenever you feel like it. Only press
ident when instructed to by ATC, you may well **** off a controller
and/or have them think you are in trouble/signalling a problem. The
especially annoying thing that happens is when a controller asks one
aircraft to ident and somebody else does it by mistake. If you are not
sure the controller is asking you to ident ask them. Another point of
confusion I have heard is pilots thinking they should press ident on
first contact with ATC, or you should press it after changing squawk
code. Please don't do either automatically--press ident only if you are
asked to (and you may not be) - e.g. only press it if you hear a request
to your callsign to "squawk ident".
Can't wait for winter be over...
Cheers
Darryl
FS - Powerflarm Portable Westbender Soaring 0 January 9th 12 09:21 PM
PowerFLARM Portable Units in Stock Paul Remde Soaring 0 December 16th 11 02:54 AM
PowerFLARM Mode S question kirk.stant Soaring 54 October 26th 10 02:51 PM
PowerFLARM Portable mount option DaleKramer Soaring 11 October 20th 10 03:45 PM
Garmin GPS496 Firmware Update John Smith Piloting 0 July 23rd 08 02:38 AM
