On May 31, 7:05*pm, "noel.wade" wrote:
To add to the chorus: Any of the more-modern ships I've flown (70's glass/metal and newer) seem to fly just fine on Aerotow with a CG hook. *There are three points to consider during the launch, in this order: 1) Wing position and cross-wind corrections. *This has been covered by others in the thread well-enough; but I'd like to emphasize that starting with full downwind rudder helps a lot, at least in my experience. *And, as others have said: The best thing to do is watch your first 50 feet of ground-roll. *If it is going from bad to worse yank the release and come to a controlled stop. *In my experience with auto-racing and flying, the worst situations always seem to happen when something starts to go wrong and a person tries to "save it" (by leaving their foot on the gas, or over-correcting, or whatever). Don't try that - just call it off and try again. 2) On liftoff - as you get rolling try to use forward-stick and stick- trim to get the tailwheel off the ground as soon as your rudder is effective. *That'll give you better steering control on the remainder of takeoff *and* put the wing at a lower angle of attack (so you won't jump/kite as quickly). *Be prepared to add forward stick as you come off the ground, and don't be shy about changing your trim multiple times on the takeoff and aerotow. *I'm not yet a CFIG but I've been flying with a lot of new-to-XC pilots recently and I've noticed that a LOT of them don't trim on aerotow, during thermalling, or in many other phases of flight. *Trim is your friend - the less you're pulling or pushing on the stick, the better control-inputs you can provide for roll & pitch excursions and the more relaxed you'll fly (making you better able to feel and focus on other things). 3) Throughout the launch and aerotow - USE YOUR FEET! *Aerotowing with a CG hook means that you can pretty-much point the nose in any direction you want. *I actually view it as a nice "bonus" and prefer towing with a CG hook for this reason (excepting the crosswind difficulties during the beginning of the ground-roll). *But I again have found many newbies recently that don't think to use their feet on aerotow. *Its far easier to make small corrections with a bit of rudder and slipping, than with big bank-angles on tow. *Keep your feet active and don't be shy about using some rudder (within reason) to keep the glider behind the towplane and pointed in the direction you want. Just my $0.02, --Noel P.S. *The back-release of the rope is a tricky thing on the ground in my DG-300; like others I find a bit of wheelbrake while taking up slack and just at the beginning of the roll is an effective "cure". I like your analytical approach. You'll make a great instructor. |
I'm not sure that the advice to keep hold of the release on tow would be advisable in more turbulent environments (like Arizona) where unexpected glider movement could cause an unintended release.
Mike |
On Jun 1, 8:59*am, Mike the Strike wrote:
I'm not sure that the advice to keep hold of the release on tow would be advisable in more turbulent environments (like Arizona) where unexpected glider movement could cause an unintended release. Mike I've had the same thought, Mike. When I take friends up for rides, I tell them to put their hand(s) on their thigh(s). That way if they make any kind of reactionary grab, they grip their leg and not an important control. I find that for myself this technique works in turbulent conditions pretty well - keep a hand on the thigh, preferrably near the release-handle. As part of my pre-takeoff checklist, I practice reaching from my thigh to the release a couple of times; so that I'm prepared in an emergency. Then I put my hand back on my thigh. (Of course, my DG-300 makes this easy by having the release-handle at the base of the panel, and I don't have any flaps to deal with - so your mileage may vary). --Noel P.S. Bill - Thanks for the compliments! I appreciate the feedback and comments that you and others have given on my various recent postings. I'm still relatively new in the sport (just hit the 5 year mark), and its nice to be able to pitch all these theories and ideas and see everyone's different opinions and points of view. Its all good food for thought. |
On Jun 1, 1:04*pm, "noel.wade" wrote:
On Jun 1, 8:59*am, Mike the Strike wrote: I'm not sure that the advice to keep hold of the release on tow would be advisable in more turbulent environments (like Arizona) where unexpected glider movement could cause an unintended release. Mike I've had the same thought, Mike. When I take friends up for rides, I tell them to put their hand(s) on their thigh(s). *That way if they make any kind of reactionary grab, they grip their leg and not an important control. *I find that for myself this technique works in turbulent conditions pretty well - keep a hand on the thigh, preferrably near the release-handle. *As part of my pre-takeoff checklist, I practice reaching from my thigh to the release a couple of times; so that I'm prepared in an emergency. *Then I put my hand back on my thigh. *(Of course, my DG-300 makes this easy by having the release-handle at the base of the panel, and I don't have any flaps to deal with - so your mileage may vary). --Noel P.S. *Bill - Thanks for the compliments! *I appreciate the feedback and comments that you and others have given on my various recent postings. *I'm still relatively new in the sport (just hit the 5 year mark), and its nice to be able to pitch all these theories and ideas and see everyone's different opinions and points of view. *Its all good food for thought. I teach the heel of the left hand guarding the airbrake lever. That's usually very close to the release knob. This covers two bases - open spoiler on tow and quick release. |
At 15:59 01 June 2012, Mike the Strike wrote:
I'm not sure that the advice to keep hold of the release on tow would be advisable in more turbulent environments (like Arizona) where unexpected glider movement could cause an unintended release. Mike Should have made it clear, it is only necessary to have your hand on the release during the ground run and take off for both aerotow and winch launch, once airborne and stable you can just keep your hand near the release as normal. I use the looped paracord so I have some slack in the sytem anyway. |
On Thu, 31 May 2012 18:05:10 -0700 (PDT), "noel.wade"
wrote: 2) On liftoff - as you get rolling try to use forward-stick and stick- trim to get the tailwheel off the ground as soon as your rudder is effective. That'll give you better steering control on the remainder of takeoff *and* put the wing at a lower angle of attack (so you won't jump/kite as quickly). Hi Noel, I have to admit that I regard this technique as bad airmanship. Really bad airmanship (for example, an LS-6 will not lift off at all with that technique). ![]() Let me explain: I've often seen gliders roll behind the towplane for ages, balancing on the main wheel, creating lots of rolling drag and bouncing all over the place with each bump they hit. Usually lots of control deflections to balance crosswind (a tail wheel in the air doesn't really help to stabilize against a crosswind...), and often multiple touchdowns after the first lift off due to PIO. Sometimes I even see gliders with a pith attitude, effectively creating negative lift until the pilot decides it's time to lift off. Scary. In my opinion it's so much easier to simply lift off with tail and main wheel at the same time and let the glider float behind the tow plane - once in the air, any glider is a lot easier to control, and in my experience on grass strips the acceleration of the tow plane is significantly better. I fly from a 2000 ft grass strip where one really can see the difference in the length of the takeoff run. It doesn't make a huge difference with a light DG-300, but flying a fully ballasted open class ship or a Duo Discus the correct technique (liftoff at minimum speed) is usually the difference between the tow plane being able to lift off or not (don't ask...). One additional benefit: If the glider lifts off close to its minimum speed, control authority of the elevator is less agressive, therefore it's far less likely to overcontrol the glider and enter a PIO. Be prepared to add forward stick as you come off the ground, and don't be shy about changing your trim multiple times on the takeoff and aerotow. I'm a little bit puzzled why one should mess with the trim during aerotow. By setting the elevator trim to the recommended position for aerotow before launch (trim forward) you get a slight nose-down stick pressure on all the (German built) gliders I've flown, which in my opinion is extremely effective to prevent ballooning: The glider is a lot more likely to descent behind the tow plane if you don't pay attention for a moment. Better be too low behind the tow plane than too high. In my opinion messing with the trim during aerotow is not a good idea for an inexperienced pilot - gliders with modern trim systems like the DG-300 cannot be trimmed nose-down at all (as you have probably noticed in your 300, it needs a significant stick push which isn't the best idea if you want to keep your position behind the towplane). Make one mistake, and you have a neutrally or even nose-up trimmed glider - one further mistake and you might create brown pants in that tow plane in front of you that is just disappearing under the nose of your glider. 3) Throughout the launch and aerotow - USE YOUR FEET! Indeed. Always. And ignore that yaw string. But I again have found many newbies recently that don't think to use their feet on aerotow. Clear case of bad training. One needs to learn to actively fly the glider during an aerotow, otherwise problems are pre-programmed. Best wishes Andreas |
All the concern about nose vs. CG release and the correcting force of the
nose release indicates, to me, poorly trained or lazy pilots. If you will simply fly the aircraft and pay attention to your flight path, you'll find that it makes no difference what type of release you have (unless you're doing a ground launch). Do some of you actually rely on the nose release to keep the nose aligned rather than flying the aircraft? "Andreas Maurer" wrote in message ... On Thu, 31 May 2012 18:05:10 -0700 (PDT), "noel.wade" wrote: 2) On liftoff - as you get rolling try to use forward-stick and stick- trim to get the tailwheel off the ground as soon as your rudder is effective. That'll give you better steering control on the remainder of takeoff *and* put the wing at a lower angle of attack (so you won't jump/kite as quickly). Hi Noel, I have to admit that I regard this technique as bad airmanship. Really bad airmanship (for example, an LS-6 will not lift off at all with that technique). ![]() Let me explain: I've often seen gliders roll behind the towplane for ages, balancing on the main wheel, creating lots of rolling drag and bouncing all over the place with each bump they hit. Usually lots of control deflections to balance crosswind (a tail wheel in the air doesn't really help to stabilize against a crosswind...), and often multiple touchdowns after the first lift off due to PIO. Sometimes I even see gliders with a pith attitude, effectively creating negative lift until the pilot decides it's time to lift off. Scary. In my opinion it's so much easier to simply lift off with tail and main wheel at the same time and let the glider float behind the tow plane - once in the air, any glider is a lot easier to control, and in my experience on grass strips the acceleration of the tow plane is significantly better. I fly from a 2000 ft grass strip where one really can see the difference in the length of the takeoff run. It doesn't make a huge difference with a light DG-300, but flying a fully ballasted open class ship or a Duo Discus the correct technique (liftoff at minimum speed) is usually the difference between the tow plane being able to lift off or not (don't ask...). One additional benefit: If the glider lifts off close to its minimum speed, control authority of the elevator is less agressive, therefore it's far less likely to overcontrol the glider and enter a PIO. Be prepared to add forward stick as you come off the ground, and don't be shy about changing your trim multiple times on the takeoff and aerotow. I'm a little bit puzzled why one should mess with the trim during aerotow. By setting the elevator trim to the recommended position for aerotow before launch (trim forward) you get a slight nose-down stick pressure on all the (German built) gliders I've flown, which in my opinion is extremely effective to prevent ballooning: The glider is a lot more likely to descent behind the tow plane if you don't pay attention for a moment. Better be too low behind the tow plane than too high. In my opinion messing with the trim during aerotow is not a good idea for an inexperienced pilot - gliders with modern trim systems like the DG-300 cannot be trimmed nose-down at all (as you have probably noticed in your 300, it needs a significant stick push which isn't the best idea if you want to keep your position behind the towplane). Make one mistake, and you have a neutrally or even nose-up trimmed glider - one further mistake and you might create brown pants in that tow plane in front of you that is just disappearing under the nose of your glider. 3) Throughout the launch and aerotow - USE YOUR FEET! Indeed. Always. And ignore that yaw string. But I again have found many newbies recently that don't think to use their feet on aerotow. Clear case of bad training. One needs to learn to actively fly the glider during an aerotow, otherwise problems are pre-programmed. Best wishes Andreas |
At 16:12 02 June 2012, Dan Marotta wrote:
All the concern about nose vs. CG release and the correcting force of the nose release indicates, to me, poorly trained or lazy pilots. If you will simply fly the aircraft and pay attention to your flight path, you'll find that it makes no difference what type of release you have (unless you're doing a ground launch). [snip] The concern in the UK about towing on CG hook when a nose hook is available came from tug pilot fatalities. The first, and most of the other, such accidents happened with CG hooks, and one or more of the other factors, which led to kiting, tug upset, and tug hitting the deck. As a result, the BGA issued a poster listing the 6 factors most closely associated with upsets, and advised having not more that two (IIRC) such factors on any one launch. More recently we started to have upsets again, so far fortunately without fatality. Unable to find the original poster, we issued another which had the following: ------------------- Tug Upsets These happen when the glider suddenly zooms above the tug, putting it into a steep dive requiring considerable height to recover. The BGA ran a successful campaign to end these fatalities to tug pilots, but several years without incident now appear to have ended. This year there have been two reported upsets and at least one other not reported. Fortunately none resulted in crashes. Six factors make upsets more likely: ï‚§ Lightweight, low wing-loading ï‚§ C of G hooks intended for winch launching ï‚§ Short ropes ï‚§ Inexperienced pilots ï‚§ Near aft C of G. ï‚§ Turbulent conditions If two of these are present the danger becomes significant. More than two should be considered unacceptable. ----------------- Chris N |
On 6/2/2012 9:12 AM, Dan Marotta wrote:
All the concern about nose vs. CG release and the correcting force of the nose release indicates, to me, poorly trained or lazy pilots. If you will simply fly the aircraft and pay attention to your flight path, you'll find that it makes no difference what type of release you have (unless you're doing a ground launch). Do some of you actually rely on the nose release to keep the nose aligned rather than flying the aircraft? I did in some conditions, such as cross winds and unassisted (no wing runner) takeoffs. When the glider is moving slowly at the beginning of the launch, there is no "flying" the glider - you are ballistic for a length of time that depends on the wind and towplane acceleration. Once aerodynamic control is available, then the differences between CG and nose hooks are reduced, but in all the gliders I've flown, it was still noticeable. How noticeable did depend on the glider type. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
CG Hook for 1-26? | [email protected] | Soaring | 1 | October 29th 06 01:21 AM |
Tow hook | [email protected] | Soaring | 2 | September 27th 06 02:16 AM |
Elfe S4 Winch hook | Derek Wilson | Soaring | 0 | July 21st 05 11:07 AM |
Tow Hook 337 for a 150-150 | 1JH | Soaring | 3 | July 19th 05 06:35 PM |
CG hook & Low Tow | Ray Lovinggood | Soaring | 2 | July 25th 03 06:20 AM |
