Va and negative g's & fun non-acrobatic maneuvers
Old December 1st 03, 11:07 AM
Koopas Ly
Default Va and negative g's & fun non-acrobatic maneuvers
Me again,
Va seems to be only intended to protect against excessive positive
load factors. What about negative g's?
Can I find a Va for negative design load factors (-1.52 g) for the
C172SP anywhere?
Reason I am asking is that I want to try the "floating pencil" trick
next time I fly but I don't want to shove the stick fully forward for
fear of breaking something. I am not looking to induce negative g's,
only zero g's and zero lift. Any pointers on entry speed and power
settings? Is it easier to perform if you induce a gradual +1 g steep
climb similar to a departure stall maneuver, then upon hearing the
stall horn, give it good nudge forward on the stick? I've heard that
your airspeed may indicate well below stall, but again, your stall
speed does approach zero as your load factor goes to zero.
Likewise, would you prefer to pull 2 positive g's in a pull-up
maneuver or a, say, 60 deg. bank? Frankly, I am not too familiar with
the former so I might do something undesirable. Aside from my stall
speed going up to something like 68 kts. clean (Va ~ 100 kts), you'd
see your airspeed quickly dwindling while pulling up. I think it'd be
fruitless to add in power since heck, you're not maintaining altitude
and besides, you probably don't have any excess power anyway to do
that. Neither am I familiar with the mechanics of loops so it'd be
wiser to leave that alone. Perhaps the 60 deg. bank is more
reasonable to have some fun. Would you try to hold altitude with
backpressure and power or just leave the plane to dive and speed up in
the spiral, with a recovery before Vne? I think the maneuver would be
more innocuous with power-off a-la-emergency-descent style. Again,
I've never done a 60 deg. bank...so I should probably leave that alone
too until I try it with a passenger...oops..i mean CFI.
Seriously, if someone has something to suggest that's fun and safe,
within normal operating range and category, please suggest. It's a
buddy's bday soon and he wants to go up. Again, I am not looking for
doing anything aerobatic.
Alright, I can see the flames and derision coming from the mainland
May you have a peaceful week with no stress,
Alex
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 05 07:29 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 04 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
