#21
Tom Jackson wrote:
Waypoints along a route, towers, etc. (slightly out of date) http://131.238.38.204/~sarangan/avia...min/index.html More updated information, world-wide, no obstructions, GPX format, which may need to be converted to a format for your import/export software (see Topographix website): http://navaid.com/GPX/ FAA GeoTIFF sectionals: http://aviationtoolbox.org/raw_data/FAA_sectionals/ Oziexplorer: www.oziexplorer.com The DAFIF includes world-wide coverage for larger airports and virtually all navaids: https://164.214.2.62/products/digitalaero/index.cfm The information is available both in fixed-length field files and in tab-delimited files (suitable for importing into a spreadsheet). I've used the DAFIF to generate custom GPS Canadian aviation databases. The FAA database, which has more detail for the U.S. (but nothing for the rest of the world), is available on a CD-ROM, but people occasionally make online copies available. Here's a mirror of both the DAFIF and the FAA NASD: http://ftp.umr.edu/pub/faa/ All the best, David |
which website do you use? Do you happen to have a list of
websites that offer these waypoints? Gerald, Hot of the press, try my site with my low tech solution: www.cockpitgps.com John Bell |
I've read all the reponses available to date, ans I haven't seen any
recommendation for my favorite -- AnywhereMap. This software runs on a many PPCs, and works really very well. It is explicitly designed for aviation use, rather than being an auto/marine base with aviation overlays. Look at www.anywheremap.com On Fri, 5 Dec 2003 11:32:09 -0600, "RD" wrote: Good day, Can someone give me an opinion on what type of GPS unit is good enough for me. I'm a GA pilot, very low time, looking for a decent GPS to take along for some X/C flying in the rentals. Just need to see highways and cities etc. I'm not very worried about airspace as there isn't much around my local airport and the charts do a good enough job. 1. Are basic GPS modules such as the ones you take camping/fishing good enough? 2. What about PalmPilot/Windows CE based hand held units? 3. Is it worth buying a decent Garmin model? What are your experiences? Thanks, Ryan |
My first experience with a GPS was to use a small non-aviation
unit (same as the small Lowrance, but sold under the Eagle brand name). Propped it on the glareshield. It worked fine for a CAVU flight (which that one w as). Had to do my homework first, and program in appropriate waypoints before flying. Next I flew nearly all the way across the country and back, using a borrowed Garmin GPS90. Overall, it was a fantastic improvement in ease of navigation - but less than perfect. Lost signal once just after takeoff into marginal visibility (it quickly came back, and the visibility soon improved as well). Later on I noticed that some of the airport identifiers on the moving map didn't jibe with the Sectionals. This was to cause some consternation toward the end of the trip when I was forced to divert due to lowering clouds, rising terrain, and an SUA - all at once. The alternate I had in mind wasn't identified in the GPS Database by anything recognizable (and I didn't have time to solve the mystery at that point). Fortunately, another alternate was both identifiable and reachable. Afterwards I found out that the database was long out of date, and a number of identifiers had been changed. After that I had to have my own, and bought a Garmin GPS92. This unit, used with an external antenna, has performed nearly flawlessly for about four years. To me, having a database that allows instant selection of any airport or navaid is worth it's weight in gold. Almost all the homework has been done for you in advance. I do occasionally use it to drive a mapping program running on my laptop. Have only used this for ground navigation to date, since finding a place for even a small laptop is difficult in a cockpit. If I were starting again, I'd go for the Garmin 196. The pricetag (about double the 92) has kept me from upgrading. I haven't tried the PDA approach, so can't comment on it. David Johnson |
Dear Ryan,
like you, I am also flying and soaring with rented planes. So I always carry a handheld outdoor GPS with me. Now I am using a Garmin eTrex Vista, before this I used an eTrex Summit and a GPS 12Map. The Vista is very small and light, has a base map, and is able to store a long track log. Since I also use it for mountain hiking, I like the included compass and barometric altimeter. I store airports and navaids of my area as user waypoints with the program g7towin from Ron Henderson http://www.gpsinformation.org/ronh/. You will find a good descripion of how to do and where to get from John Bell http://www.cockpitgps.com/. In fact I do not use the GPS unit inflight very often, but I love to have it with me as a backup. Best regards Walter |
| Thread Tools | |
| Display Modes | |
| Paint Scheme Ideas | [email protected] | Owning | 0 | December 29th 04 05:57 PM |
| CO mystery - any ideas? | Andrew Gideon | Owning | 24 | November 20th 04 06:16 PM |
| Thanks for ideas on drilling a centered hole! | Scott | Home Built | 12 | October 25th 04 03:52 AM |
| Speech: Air Power: The Men, Machines and Ideas | Otis Willie | Military Aviation | 0 | May 8th 04 12:25 AM |
| request for ideas on decoding jet jock slang | Jeff Crowell | Military Aviation | 10 | March 15th 04 08:43 PM |
