New Nexus 7 with xc soar.
Old December 16th 12, 05:36 PM posted to rec.aviation.soaring
waremark
Default New Nexus 7 with xc soar.
On Friday, August 31, 2012 12:09:09 AM UTC+1, wrote:
On Wednesday, July 25, 2012 12:34:18 PM UTC-4, glider12321 wrote:
Any thoughts? Will the screen hold up in sunlight? It has GPS,
accelerometer and a gyro. Is the 16 GB enough?
Peter
Hi
Is the sreen better/worst than a Oudie?
S6
Any update on how well the Nexus 7 works with XC Soar? Screen in sunlight compared with original Oudie, or Oudie 2? Internal GPS - is it good enough, does it give good wind calculations? Will it be able to upload igc files from a PNA via Bluetooth?
Old December 16th 12, 06:54 PM posted to rec.aviation.soaring
Tobias Bieniek
The tablet is damn fast and works very well with XCSoar. The terrain maps in the background have a quite good resolution and it just looks pretty good on such a high-res screen.
Unfortunately I haven't had enough sunlight yet to be able to comment on that. I suspect it to be somewhere between the two Oudie versions.
Haven't used it in flight yet, so I can't comment on this either. I usually use my devices in connection with a Flarm via IOIO though, so this won't be relevant for me.
Not sure what you mean? If you have any kind of internet connection on the tablet you can upload the IGC files pretty much anywhere you want. If you choose the version with the mobile data antenna, you can even use live tracking via SkyLines for example.
Old December 16th 12, 08:29 PM posted to rec.aviation.soaring
waremark
Thanks for that info. It sounds very good. What I meant by the Bluetooth question - I should probably have said download, not upload. I want to be able to extract igc files from an approved logger, which will be connected to a GliderGuider PNA. Would I be able to use Bluetooth to transfer files into the Nexus from the PNA?
Old December 16th 12, 10:18 PM posted to rec.aviation.soaring
Tobias Bieniek
I don't know, to be honest... It could work but I won't promise anything
Why don't you just connect the logger to the Nexus 7?
Old December 15th 12, 09:22 PM posted to rec.aviation.soaring
Peter
grlgokgroiore0f9r0oef-sferpfoerofserpvpreofropfopfopforofrproopopddfpodp oopoofrdpofrdopfrd==
XC Soar map help needed Ken Latam Soaring 32 June 18th 11 12:36 PM
Fat boy wants to soar... toggles mcfarley Soaring 24 March 23rd 10 06:51 PM
XC-Soar [email protected] Soaring 4 January 26th 09 04:06 PM
Nexus program of any use flying? Paul kgyy Piloting 3 September 9th 08 06:47 PM
why do you soar? Mark James Boyd Soaring 27 October 21st 03 07:48 PM
