Wing-support for Duo one-person assembly
Old September 4th 12, 03:33 PM posted to rec.aviation.soaring
Dave Nadler
Default Wing-support for Duo one-person assembly
On Tuesday, September 4, 2012 1:32:18 AM UTC-4, Morgan wrote:
Total weight is 215lbs I believe. I haven't ever stepped on a scale
while picking up either the wing tip or the root. I'd guess the split
is like 130lb/85lb or something like that between the root and the tip.
It's heavy, but mostly it is awkward.
There is a lot of weight on the trailing edge once you rotate flat.
That means the hinge-point for the wing-saddle is incorrectly
positioned. If the rigging aid is properly designed, there should
be almost no rotation force once the wing is ~level.
Which unit is this one ?
Then for the person at the tip, the height is very high given the dihedral.
When Julie and I rig, the tip is at about shoulder height for her.
Best Regards, Dave
Old September 4th 12, 05:35 PM posted to rec.aviation.soaring
Dave Nadler
On Thursday, August 30, 2012 12:10:53 PM UTC-4, RN wrote:
John Earlywine
I have similar issues with the DG-1000.
Mark Mocho where are you? Are you listening?
What brand rigging aid are you currently using ?
Best Regards, Dave
Old September 5th 12, 07:03 AM posted to rec.aviation.soaring
Morgan[_2_]
Sorry, conflated statements. I was purely speaking to the balance of the Duo wing when manually assembling the glider. The CG is aft of the spar a bit. I also have to make sure when you have extra helpers that they don't lift on the leading edge or on the leading edge side of the handle at the tip. Nothing like trying to manage the root of the wing and then have another 20lbs of torque applied.
The reason I would buy the XC version of the wing rigger was in order to ensure proper balance on the rigger. It doesn't meet your requirement for being able to easily adjust the height without going under the wing or crouching.
Old February 24th 14, 12:28 PM posted to rec.aviation.soaring
Hi!
Enstroj makes what you are looking for,
http://www.enstroj.si/Glider-product...-assembly.html
I have used this rigging aid and it great.
Old February 25th 14, 06:17 AM posted to rec.aviation.soaring
We've used an Udo rigger that was made for an ASW-20 on our DG-505 Orion quite successfully simply by making the trailing edge clamp longer to deal with the greater chord. I've got one for my 15b and like it better than the others I've seen. I actually prefer the mechanical jack to the gas spring setup on some riggers. I think what really makes the Udos work well though is how good a job he did making the wing saddle - very substantial and fits nice and snug to the contour of the wing.
Wing assembly dollies Udo Soaring 1 December 2nd 10 02:51 AM
USED One person assembly rig Tim Mara Soaring 0 May 1st 10 03:13 PM
assembly wing dolly Anoucement Udo Rumpf[_2_] Soaring 2 January 13th 09 06:53 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
USAFE commander: 86th Airlift Wing will divide for combat, support operations Otis Willie Military Aviation 0 November 27th 03 11:31 PM
