#21
Cool. I thought I was the only one who thought that.
"Enefesdi Varspooli Bhootpalamdi" you, sir, are an idiot. |
I concur.
Newps wrote:
Again flawed reasoning. Nobody that is all alone in the pattern flies a 7 minute pattern. A Lieberman wrote: Actually, to me a 7 minute pattern sounds reasonable IF a person runs a 1000 foot AGL pattern in a typical Cessna [snip] Flying a Cessna 150, my patterns vary between 6 and 9 minutes -- 800' TPA, varying wind and weight, alone and/or with others in the pattern. Am I doing something wrong? --Shirley |
Newps wrote:
Again flawed reasoning. Nobody that is all alone in the pattern flies a 7 minute pattern. Actually, to me a 7 minute pattern sounds reasonable IF a person runs a 1000 foot AGL pattern in a typical Cessna as follows in a touch and go in a no wind situation. (numbers would be approximate based on my experiences) Climbout 1 1/2 minutes (climb to 800 AGL at 500 feet per minute) Crosswind 1/4 minute (climb to 900 AGL) Downwind (Climb to 1000 AGL, level off, pick up speed) 3/4 minute Abeam the numbers (throttle back start descent) 1/2 minute Base 1/4 minute Final 3/4 minute Touchdown to clearing the length of the runway and getting back to 800 AGL (assuming 4500 foot runway or so) 2 minutes. The above adds up to 6 minutes. Add in a little wind, and the headwind component would add time to the leg that is in the headwind (crosswind, base or final). Now throw in a 800 foot pattern, then maybe knock off a minute, but I don't run 800 foot patterns that I have seen others do. All airports I have been had 1000 TPA Looking at my log book, the above would consistent for when I did 10 touch and goes in 1.3 hours. Allen |
![]() Shirley wrote: Flying a Cessna 150, my patterns vary between 6 and 9 minutes -- 800' TPA, varying wind and weight, alone and/or with others in the pattern. Am I doing something wrong? Probably not. Looking at my first logbook, it appears that I was fairly consistently doing about 10 T&Ls in an hour in a rental 150. Our pattern altitude was 1,000' AGL, and I didn't usually do T&Gs. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
Shirley wrote:
Newps wrote: Again flawed reasoning. Nobody that is all alone in the pattern flies a 7 minute pattern. A Lieberman wrote: Actually, to me a 7 minute pattern sounds reasonable IF a person runs a 1000 foot AGL pattern in a typical Cessna [snip] Flying a Cessna 150, my patterns vary between 6 and 9 minutes -- 800' TPA, varying wind and weight, alone and/or with others in the pattern. Am I doing something wrong? Hi Shirley, Never flew a 150 or 152, but expecting the 150 to be slower then a 172 which I trained in, I would think you are dong it perfectly normal. Allen --Shirley |
"Newps" wrote in message
news:51GOb.81209$sv6.190650@attbi_s52... gatorcog wrote: I didn't hit the bonanza precisely because I did see and avoid him. I call all my positions and listen for others, too. Don't call every position, it's unnecessary and annoying. For example if you are alone in the pattern then one call per pattern, midfield downwind, is all you need. If the pattern is really busy and you are following the same guy then same deal, one call midfield. If somebody is nearing the airport and will be joining the pattern then more calls make sense. We have a college flight school that trains at an airport 11 SW of here and with three in the pattern you'd think it was O'Hare. It is a constant nonstop barrage of totally useless traffic calls. Fer Christ sakes they are making a call when they taxi from the ramp to the runway. Agree with the last part. When it's busy, there's not much advantage in calling every position. But, I've thought that I've been alone a couple times when I wasn't. So I tend to make more calls when I think I'm alone. le moo |
![]() wrote in message news ![]() So if the pilot uttering that request (despite it not being recommended by the Advisory Circular) receives no reply, is he to erroneously believe that he is alone in the pattern? I was very clear on that point. What of the NORDO aircraft that is incapable of radio communication, or the pilot who chooses not to respond to such a nonstandard radio broadcast? The former will not respond, though may have the ability to receive such transmissions; the latter need only provide the calls specified in the AIM to satisfy the request. I agree that the 10 mile announcement serves attention to the lonely pattern flyer that now would be a good time to start talking, so the extra "...please advise" words are unnecessary. Just make the self announced position report broadcasts as the AC suggests: or as set forth in the AIM, which "contains _the fundamentals required in order to fly in the United States NAS_. |
#29
![]() Paul Sengupta wrote: "Gerald Sylvester" wrote in message link.net... Also as they say, there is a reason why you have two ears (and two eyes) and one mouth. For flying? yes but only for flying. ![]() gerald |
#30
Allen
You guys are pussies G Used to pitch off the deck at 250+ MPH. Hard pull up in climbing turn with throttle going to idle and drop gear and flaps when airspeed below limit speed. Continue turn down to final and touch down under 30 seconds with that Merlin poppety popping all the way. G Big John Pilot ROCAF On Mon, 19 Jan 2004 12:04:06 -0800, A Lieberman wrote: Newps wrote: Again flawed reasoning. Nobody that is all alone in the pattern flies a 7 minute pattern. Actually, to me a 7 minute pattern sounds reasonable IF a person runs a 1000 foot AGL pattern in a typical Cessna as follows in a touch and go in a no wind situation. (numbers would be approximate based on my experiences) Climbout 1 1/2 minutes (climb to 800 AGL at 500 feet per minute) Crosswind 1/4 minute (climb to 900 AGL) Downwind (Climb to 1000 AGL, level off, pick up speed) 3/4 minute Abeam the numbers (throttle back start descent) 1/2 minute Base 1/4 minute Final 3/4 minute Touchdown to clearing the length of the runway and getting back to 800 AGL (assuming 4500 foot runway or so) 2 minutes. The above adds up to 6 minutes. Add in a little wind, and the headwind component would add time to the leg that is in the headwind (crosswind, base or final). Now throw in a 800 foot pattern, then maybe knock off a minute, but I don't run 800 foot patterns that I have seen others do. All airports I have been had 1000 TPA Looking at my log book, the above would consistent for when I did 10 touch and goes in 1.3 hours. Allen |
F-14 Ejector Seat fatality circa 1987 | rottenberg | Naval Aviation | 1 | November 16th 04 01:36 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Homebuilt down Friday, one fatality near, Santa Paula, CA | R. Hubbell | Home Built | 2 | November 9th 03 03:08 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
Quickie fatality | Sam Hoskins | Home Built | 3 | July 25th 03 05:55 AM |
