Sheriff Responds to AOPA
Old January 22nd 13, 11:06 PM posted to rec.aviation.soaring
folken
Default Sheriff Responds to AOPA
On Tuesday, January 22, 2013 9:47:48 PM UTC+1, sisu1a wrote:
The thermal is extremely narrow.. so banks of 90 Degrees are not uncommon.
False.
http://www.rainierflightservice.com/...ctor-chart.gif
Thermaling is not a coordinated turn.
Old January 23rd 13, 01:40 AM posted to rec.aviation.soaring
kirk.stant
90 degree bank is a lot steeper than most pilots imagine. Unless you are current in acro anything over 60 degrees will feel like 90. And unless its a transient condition caused by turbulence any intentional 90 degree bank for more than a few seconds would result in an impressive sink rate regardless of the strength of the thermal. But it makes for a good hangar story: "There I was at 300 ft over the nuke cooling tower, banked to 90 degrees and barely climbing..."
Kirk
66
Old January 23rd 13, 11:35 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
It stands to reason that you can't climb in a 90 degree bank because
there's no vertical lift vector unless, of course, you so much top rudder
fed in that you're climbing on lift generated by the fin and fuselage
sides.
However, a couple of times I've certainly been using around 70 degrees
bank and still going up like the clappers:
- once on a Pegase 90 when I was climbing in the chimney plume from the
Stewartby Brick works just west of Bedford. That was odd: there was
nothing (not even sink) outside the plume and in it you could center
nicely by maximising the smell of furnace oil fumes. It was very narrow:
I had the stick almost fully back to turn tightly enough and needed to
extreme bank to turn that tight, bit I got 6-7 kts out of it
- a similarly tight thermal with no apparent reason for it being too
tight, over our airfield. This time solo in the club's Puchacz and again
cranked over at least at least 70 degrees and with the stick well back to
turn as tight as possible. Any wider turn left me out in the surrounding
turbulence and sink. Again I got a strong climb to cloud base directly
under a nice street.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
USS Liberty Survivor Phil Tourney responds to Cindy McCain NOMOREWARS_FORISRAEL Naval Aviation 0 September 24th 11 11:22 AM
A Fine Day at BFI - part 2 - Bell 407 N407KS King County Sheriff BFI 6-20-09 29.jpg Bob (not my real pseudonym) Aviation Photos 0 June 28th 09 09:32 AM
A Fine Day at BFI - part 2 - Bell 407 N407KS King County Sheriff BFI 6-20-09 23.jpg Bob (not my real pseudonym) Aviation Photos 0 June 28th 09 09:32 AM
AS responds to the latest Ventus 2cxa KevinFinke Soaring 3 March 18th 09 03:45 AM
County Sheriff Arrests Pilot After Botched Landing Larry Dighera Piloting 16 May 16th 08 09:58 PM
