Single-engine plane with the best range?
Old February 23rd 04, 01:48 PM
Stealth Pilot
On Sun, 22 Feb 2004 12:19:52 -0800, "Peter Duniho"
"Stealth Pilot" wrote in message
never hinted that it was immune from anything.
True, you didn't hint at it. You just came right out and claimed it. Bob
wrote "the range for any aircraft is dependent on power setting", and you
wrote "my experience doesnt [sic] support that". When in fact the range for
any aircraft IS dependent on power setting.
Bob's statement was somewhat inaccurate in that 50% power may or may not
produce best range, and may not even be better range than normal cruise.
But it's impossible that your experience would contradict that the range is
dependent on power setting, because range DOES depend on power setting.
peter
the time, the duration, that an aircraft can remain airborne is
dependent on power setting. not necessarily the range achieved.
what I posted were some factual observations. dispute them if you
will, they still remain what I observed.
ymmv
Stealth Pilot
Australia
Old February 23rd 04, 06:27 PM
Peter Duniho
It affects both.
I'm not disputing your observations. I'm disputing that they have any
bearing at the question in hand, and in particular, your claim that they
somehow disprove the fact that for any airplane, an increase in range can be
had by reducing the power setting below the normal cruise setting.
Pete
Old February 25th 04, 08:10 AM
Stealth Pilot
On Mon, 23 Feb 2004 10:27:19 -0800, "Peter Duniho"
It affects both.
Pete
ok my last post on this.
I had a think about your thought of different cooling drag being the
reason for the identical fuel burns at the different airspeeds. If you
ever get to fly a Tailwind take up the offer. You will experience an
aircraft with a significantly increased induced drag influence
compared to the higher aspect ratio Cessnas/commercial stuff that you
seem to be basing your comments on. It seems to me that induced drag
builds up quicker in the Tailwind at slower speeds than in the
commercial offerings.
I accept the cooling drag comment but think it is less significant
than induced drag as part of the answer.
"the fact that for any airplane, an increase in range can be
had by reducing the power setting below the normal cruise setting"
I will warn you that you are in for a surprise which may cost you the
aircraft in the right (wrong) conditions.
This was covered ad nauseum in my commercial pilot studies under
aircraft performance. I'll give a brief reiteration here.
If you have a look at the Cessna POH for the 150M you will find your
range profile graph on page 5-15. what you indicate is correct - for
the conditions that the graph was made for, which is for zero wind
conditions.
two pages over you will find a more useful graph which just gives just
endurance. you use this for calculating range in the more usual
condition of having a wind component.
CPL theory (and demonstrated calcs) says that for a tailwind or no
wind you fly slower to increase range.
for a headwind you fly faster!
I'll leave it for you to work out why.
Stealth Pilot
(...returning to my uni studies)
Old February 25th 04, 03:26 PM
TripFarmer
I can go about 900 in my 235 but my bladder wouldn't be able to make it nearly
that far.
Trip
says...
It affects both.
Pete
conditions.
Stealth Pilot
Old February 25th 04, 04:52 PM
Peter Duniho
You should've stopped a long time ago.
I never made any comment about cooling drag.
If you ever get to fly a Tailwind take up the offer. You will experience
an
You are talking gibberish.
"builds up quicker...at slower speeds"? What is that supposed to mean?
It is true that there is more induced drag at slower speeds, for any
aircraft. It is also true that the exact amount of induced drag will vary
from airplane to airplane, and indeed even from weight to weight for the
same aircraft. But the nature of the curves for induced drag and parasitic
drag are always the same, and they always result in a single L/Dmax
airspeed.
FOR ANY AIRPLANE.
Doubtful.
Something was covered. You should have paid better attention when it was.
conditions.
Yes. So?
Endurance and range are two completely different things. You cannot depend
on endurance numbers to provide range numbers, unless you also take into
account the differences in airspeed. Best endurance will NOT be the same
airspeed as best range.
Do you have a point? I said several posts ago this exact thing. Sounds to
me like you're just making my point for me. Or maybe you're just copying my
posts, trying to make it look like you have an original thought. I'm not
really sure which.
However, it also appears that you are misunderstanding the general truth
regarding how to deal with tailwinds and headwinds. For a given no-wind
power setting, it is true that you should fly faster (and with more power)
in a headwind and slower (and with less power) in a tailwind to compensate.
However, you will not achieve the same range as in no-wind conditions.
In a headwind in particular, your best range airspeed most likely will still
be less than the normal cruise airspeed. It all depends on the headwind,
but for typical, light headwinds the change due to wind does not overwhelm
the need to fly closer to the L/Dmax airspeed. Even in a headwind, best
range airspeed is usually found below normal cruise.
It is simply not true that even in a headwind, one needs to fly faster than
normal cruise to achieve best range, nor would that be relevant at all to
this discussion even if it were.
Pete
Should I consider this plane - weird engine history [email protected] Owning 12 February 3rd 05 12:18 AM
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! David Ross Aviation Marketplace 0 August 24th 04 07:13 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
The "Lightweight" Fighter is on the verge of overtaking the F-105 as the heaviest single engine fighter of all time. Talk about irony. Scott Ferrin Military Aviation 1 November 24th 03 03:12 PM
