Hangar dolly for heavy glider
Old May 29th 13, 05:49 PM posted to rec.aviation.soaring
Bill D
Default Hangar dolly for heavy glider
On Wednesday, May 29, 2013 9:47:00 AM UTC-6, JohnDeRosa wrote:
About the automotive units in general and Harbor Freight cheapie unit
in particular. http://www.harborfreight.com/1250-lb...lly-67287.html
I looked at the HF unit and here are some comments;
1) It can be adjusted fore/aft for some pretty small tires including
the common 350x135 glider tires. I don't think that it will "pinch"
tires (as mentioned by Dave Springford). YMMV.
2) If the width needs to be narrowed, the HF unit could "easily" be
changed (cough...with a hacksaw and muscle). However, the wider
stance may be good for stability and dealing with #3.
3) The jack handle may need to be bent or adjusted to get out of the
way of the fuselage (as Steve Leonard mentions) while still retain
functionally. The other brands mentioned above tilt the entire lift
mechanism, not just bend the handle. This may be the trickiest thing
to correct but may be unneeded due to #2.
4) Sure is cheaper than the alternatives! Allows for low cost
experimentation!
- John
The Gojack or this one will probably work - with modifications. However, there's an opportunity to do better by using the jack-able fuselage trailer dollies used with some fixed-gear twins as a model. By lifting the fuselage instead of the wheel, the tire and gear doors are accessable for maintenance
Glider Main Wheel Dolly Jim[_18_] Soaring 0 March 9th 11 04:19 PM
ETA glider landing with heavy front wind in Rieti, videoclip PCool Soaring 2 October 1st 09 03:10 PM
Glider Hangar Tie-Downs V1 Soaring 0 March 19th 09 02:09 PM
Club Glider Hangar? noel.wade Soaring 33 January 14th 08 10:47 PM
Ideal Glider Hangar Dimensions SGS135 Soaring 3 November 27th 04 11:04 PM
