FAA Plans to Change to Radios with 8.33 MHz spacing?
Old April 12th 13, 04:22 AM posted to rec.aviation.soaring
Frank Whiteley
Default FAA Plans to Change to Radios with 8.33 MHz spacing?
On Thursday, April 11, 2013 3:33:51 PM UTC-6, Paul Remde wrote:
Hi,
I imagine someone on this newsgroup can point me in the right direction on a
technical/FAA question.
Becker offers 2 versions of their AR6201 radio. The original version has
frequency spacing that can be set to either 25 mHz or 8.33 mHz. The new,
slightly lower cost option has frequency spacing fixed at 25 MHz It is my
understanding that the 8.33 MHz spacing is required in Europe, but not
currently in the USA. Customers are asking me whether the FAA has any plans
to go to the 8.33 MHz spacing in the near future - so they can be better
equipped to select the radio version that makes sense. At a recent soaring
seminar someone stated that they thought the FAA was going to require radios
with the 8.33 MHz spacing starting in 2020.
Can anyone help me?
Thank you in advance.
Paul Remde
Cumulus Soaring, Inc.
http://hraunfoss.fcc.gov/edocs_publi...-11-1403A1.pdf
http://www.uspa.org/Portals/0/Downlo...C-10-103A1.pdf
Don't know about the FAA, but the FCC permits some use under Part 87. Haven't found a mandate, yet.
Frank Whiteley
Old April 12th 13, 08:53 PM posted to rec.aviation.soaring
Pat Russell[_2_]
On Apr 11, 5:33*pm, "Paul Remde" wrote:
Hi,
[well-formed question here]
Can anyone help me?
Apparently not, Paul. But it's always fun to watch the responses
wander off in bizarre directions, don't you think?
Good luck.
-Pat
Old April 13th 13, 01:57 PM posted to rec.aviation.soaring
I'm already starting to see a trade in used radios from Europe finding their way to North America. You might want to get a European source and start importing quality radios that are being swapped out now.
Old April 13th 13, 04:53 PM posted to rec.aviation.soaring
Dan Marotta
It really amuses me how so many people talk about "antique" comm systems.
Why would you need to switch to whoop-de-doo G4, digital, frequency hopping,
DEQPSK (old stuff), wahoo, smart-i-phone thingies, when a VHF-AM 5 watt
transceiver will carry your voice over a hundred miles?
Yeah... I know - you just gotta have real-time satellite photos of the
clouds down to 3.141592 meter resolution so you can keep your $300K glider
in the air for more than 30 minutes.
I'll stick with my antiques, thank you.
And, yes, I understand spectrum congestion.
And, for those who don't get it, I'm yanking your chains. ;-p
Old April 23rd 13, 02:41 AM posted to rec.aviation.soaring
Darryl Ramm
On Thursday, April 11, 2013 2:33:51 PM UTC-7, Paul Remde wrote:
Hi,
Can anyone help me?
Paul Remde
Yes Google would answer all your questions. 8.3 kHz ain't happening in the USA anytime soon. And one issue there is the FAA in their "wisdom" have been playing with Nextcom, a VDL based future digital voice system. (VDL is one of the existing digital link technologies that was also a potential ADS-B carrier, but is effectively not used for ADS-B).
http://www.aviationtoday.com/av/comm...XCOM_1201.html
and see
http://www.roger-wilco.net/8-33-khz-...-what-is-this/
Presumably would be introduced in transport category and other high-flying aircraft. Yes the same folks that thought going dual-link ADS-B was a good idea... your tax dollars at work, sigh. It would not surprise me to eventually see 8.3 kHz spacing in the USA, and that would actually be a good think IMNSHO vs. trying to go digital.
Any mentions of cellular communication standard here are irrelevant, terrestrial type cellular systems don't work well with aircraft in the air and "spamming" multiple cells. For digital links there are technology (like VDL) that are already fairly well understood. FM based systems (like FRS, which is low-power and also irrelevant here) are also non-starters, being FM does not inherently solve bandwidth issues and FM suffers from capture effect/overtalk issues (why we use AM to start with).
Darryl
Old April 24th 13, 05:43 PM posted to rec.aviation.soaring
soartech[_2_]
Darryl
Darryl,
Please explain these terms. I always thought aviation used the
outdated AM because that's what they started with many years ago.
After having used 2 meter FM radios for many years I find them to be
vastly superior to aircraft band AM radios.
Old April 24th 13, 06:21 PM posted to rec.aviation.soaring
Sean F (F2)
This would be a great solution then to the team flying dilemma. Simply purchase a modern radio and fly on channels entirely unused on the USA.
Im ordering one today.
Sean
F2
Old April 25th 13, 12:31 AM posted to rec.aviation.soaring
Tony V
Darryl
Darryl,
The advantage of AM is that when two people talk at once you hear them
both. With FM, you get the strongest signal or, when both signals are
nearly equal in strength, you hear neither. I'll take AM for aviation
radio. For ham VHF/UHF, it's FM/SSB/digital. :-)
Tony "6N", W1DYS
Old April 25th 13, 03:10 AM posted to rec.aviation.soaring
Darryl Ramm
Darryl
Darryl,
Tony "6N", W1DYS
What he said...
Darryl
Old April 27th 13, 12:55 AM posted to rec.aviation.soaring
Bart[_4_]
Plus, for weak signals, AM offers better signal to noise ratio. In
less technical terms, if pilot A has to really struggle to hear and
understand pilot B using AM, then pilot A would not hear anything if
they were using FM.
Bart
Contest Grid Spacing? ContestID67[_2_] Soaring 3 June 1st 11 03:29 AM
Long EZ plans, Mini IMP plans, F4U Corsair plans, materials, instruments for sale reader Home Built 1 January 26th 11 01:40 AM
Duster Plans For Sale - BJ-1b fullsize sailplane plans WoodHawk Soaring 0 April 25th 05 04:37 AM
[igc-discuss] To change or not to change... rules ? Denis Soaring 0 February 16th 05 07:24 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
