units of measurement on altimeters
Old March 8th 04, 05:27 PM
Markus Kuhn
"S Green" writes:
What about the pieze = 1000 pascals?
http://www.unc.edu/~rowlett/units/dictP.html
pieze (pz)
a metric unit of pressure, part of the "metre-tonne-second" system
sometimes used by European engineers. The pieze is a pressure of
one sthene per square meter, or 1000 newtons per square meter,
or one kilopascal. [...]
The name of the unit comes from the Greek piezein, to press.
The unit, spelled pièze in French, is pronounced "pee-ezz" in English.
Interesting. I had never heard of a metre-tonne-second system
before. Where was it invented and in which fields was it used?
Markus
Old March 8th 04, 05:56 PM
Markus Kuhn
"G.R. Patterson III" writes:
Peter Hermann wrote:
As a european pilot I would prefer meters.
But how to rearrange separation standards, any ideas?
Use 300 meters for every 1,000'. That's a little less
separation, but it wouldn't be too hard for a pilot to
deal with the arithmetic.
If flight levels were named in meters and were all a multiple
of 300 m, this might even add an additional communications-safety
mechanism:
In all valid flight levels, the sum of all digits would
always be divisible by three.
This adds a bit of healthy redundancy to a figure that needs
to be communicated without ambiguity over noisy radio channels.
Getting a single digit wrong would be spotted with 60%
probability. Almost as good as adding a check digit.
Markus
Old March 8th 04, 06:27 PM
S Green
"Markus Kuhn" wrote in message
"S Green" writes:
pieze (pz)
Markus
Well as I said our aircraft has the manifold pressure in pieze
ie 27 inches = 90 pieze approx
Old March 8th 04, 08:08 PM
Julian Scarfe
"Julian Scarfe" wrote:
We already have trouble enough with pilots screwing up inHg to mbar
conversions.
"Jukka K. Korpela" wrote in message
So while you take the trouble, wouldn't it be best to move to something
that lasts, due to being part of a system that is meant to be applied
in all areas of life when expressing physical quantities? It's better
to move directly to the SI system as recommended in general, rather
than first moving, say, to a partly decimal-based variant of the Anglo-
Saxon system, or - to take an example about different quantities -
first move from the use of different gallons to a Unified Gallon, then
to hectoliters, later to what the SI system really recommends.
The SI is equally happy with hPa or kPa. You've pulled out a standard from
ISO, I think, that is designed to help you make a choice when there is no
reason to do differently. I agree that, if there were no other factors
influencing choice of unit, multiples of 1000 are a good default. But
you've picked on a case where there *are* clearly good reasons -- the size
of the unit, and the equivalence to mbar -- that make hPa a very sensible
and pragmatic choice.
Julian
Old March 8th 04, 08:27 PM
Julian Scarfe
I forgot to mention in my response, BTW, that the same number of
digits *is* required.
It depends on the quantities. I was referring to the most common
quantities that people see expressed. When tagging isobars in weather
maps, the trailing zero is just a nuisance. And when more accuracy is
needed, it is natural to accept that fractions might be needed.
But I think you forget where you came into this, Jukka. The thread is
entitled "units of measurement on altimeters". The quantities that need to
be expressed are in the approximate range of 970 to 1040 hPa, with a
precision of 1 hPa. The hPa is the right unit for that job.
Your choice is between 1013 hPa or
101.3 kPa.
You just gave one more reason to favor kPa. The numeric value 1013 is
not in the recommended range, and it raises the question of a thousands
separator, which is language dependent, so that some cultures would use
1 013 (and would need a no-break space to prevent undesired line
breaks, and an en space to avoid too wide a gap, and cannot get both)
while some would use 1'013 or 1.013 or 1,013. Situations where the
quantity will be taken as a thousand times too small would be quite
rare, but the damage could be serious, so why take the risk.
In context, the need for a thousands separator is not great, is it?
Julian
Old March 8th 04, 08:49 PM
Jukka K. Korpela
is entitled "units of measurement on altimeters".
It's part of the very idea of the SI system that a single unit is used
for each physical quantity, in a unified manner, not varying the system
by application, country, or phase of the moon. It is clear that the
system is not always optimal when judged from a narrow perspective of a
specialized field, but if we go that way, we'll end up with expressing
quantities in incompatible ways - there's _always_ at least some reason
to deviate from a system.
The pascal is a very small unit in many areas of everyday life,
technology, and science. This is handled, as usual in the SI system,
using a systematic set of multipliers that correspond to powers of
1000, so that the numeric values can be scaled to a reasonable range,
[0.1, 1000). In some situations it might be, at least due to historical
reasons, marginally more convenient to use 100 or 42 as a multiplier.
But that's not a good approach. (It is true that some additional
multipliers exist in the SI system. But this is due to historical
reasons and discouraged in many standards, and tends to create
confusion because prefixes like h or da are not widely known outside
some specific areas of application, like the hectare.)
The quantities
that need to be expressed are in the approximate range of 970 to
1040 hPa, with a precision of 1 hPa.
It's against the principles of the SI system to select units according
to the range and precision that you have in some special situation.
We don't invent new units every time we encounter a new situation.
That was the old way.
Quantities in the range 97 kPa to 104 kPa can easily be expressed to
any precision you need or the current technology permits. Surely people
who work with such things can be expected to be able to work with
numbers with a decimal part.
(If it becomes relevant to work with a precision of 50 Pa, would you
insist on inventing a unit that equals 50 Pa, so that you can keep
using integers only? What about 42 Pa?)
No, the hPa is not a unit in the SI system, any more than 100 Pa is.
Yucca, http://www.cs.tut.fi/~jkorpela/
Old March 8th 04, 09:16 PM
Teacherjh
This is fine and well while you're sitting in an armchair. But in the real
world there are sometimes compelling reasons to do something different from
the way a machine might handle things. In the case where
1: Not much interfacing with other units is involved
2: Rapid and accurate organic processing of the numbers is essential,
sometimes in adverse conditions.
3: Communications is suboptimal
4: A narrow range of values is involved
I'd say that it makes sense to use whatever units are most convenient in that
case, not whatever would make some world standards body twinkle its toes.
Altimeter settings are such a case.
Jose
Old March 9th 04, 09:44 AM
Peter Hermann
mechanism:
Subsequently I would like to have a similarly clever idea
how to define SemiCircular Flight Level Rules.
Unfortunately I did not succeed to ignite a contest of ideas
in www.avweb.com via the QuestionOfTheWeek (qotw).
Obviously, U.S.Americans resist international needs.
--Peter Hermann(49)0711-685-3611 fax3758
--Pfaffenwaldring 27 Raum 114, D-70569 Stuttgart Uni Computeranwendungen
--http://www.csv.ica.uni-stuttgart.de/homes/ph/
--Team Ada: "C'mon people let the world begin" (Paul McCartney)
  #29
Old March 9th 04, 06:12 PM
David CL Francis
On Mon, 8 Mar 2004 at 20:08:38 in message
, Julian Scarfe
I know little about this but isn't there a case for making the format of
digits used specific to the function as far as possible?
Call 101 decimal 5; altimeter 1015; Heading 101; altitude 1 thousand 1
hundred for example?
Just a thought.
David CL Francis
  #30
Old March 9th 04, 10:57 PM
G.R. Patterson III
Which means you're right back to hPa, as far as the altimeter goes.
George Patterson
Battle, n; A method of untying with the teeth a political knot that would
not yield to the tongue.
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 05:09 AM
GWB and the Air Guard JD Military Aviation 77 March 17th 04 10:52 AM
Crosswind components James L. Freeman Piloting 25 February 29th 04 01:21 AM
RV-7a baggage area David Smith Home Built 32 December 15th 03 04:08 AM
A-4 / A-7 Question Tank Fixer Military Aviation 135 October 25th 03 03:59 AM
