Is the ASW-27B still being made?
Old May 15th 13, 03:45 PM posted to rec.aviation.soaring
Bill D
Default Is the ASW-27B still being made?
On Tuesday, May 14, 2013 10:35:52 AM UTC-6, wrote:
It strikes me the right answer for sailplanes is a front electric sustainer powered by a very small battery and fuel cell.
Gliders need light weight. Batteries are all sorts of things but they are not light weight.
It depends on the energy density of the chemistry (in Mega Joules/kg.)
Lead-acid: .17 mJ/kg.
Lithium Ion: 0.72-0.875 mJ/kg
lithium-Air: 9.0 mJ/kg.
Hydrogen-air fuel cell: 97 mJ/kg
IC engine w/fuel: Typically 9 mJ/kg
Lithium-air looks promising. Hydrogen-air fuel cells have proven to have long endurance in aircraft propulsion systems. Lithium batteries can deliver a huge surge of power for takeoff. A "range-extender" fuel cell/lithium battery hybrid looks interesting for electric vehicles but in a glider...?
Old May 15th 13, 04:11 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Wallace Berry wrote, On 5/15/2013 6:18 AM:
Eric Greenwell wrote:
small fuel cell.
I've wondered if a gas-electric hybrid would be practical. A gas motor
powerful enough to supply half the energy of a 2000' climb at 500 fpm
would be about 20 hp, a fair sized motor. So again, maybe the solution
is a big enough Li battery to do the whole 2000', then use 4 hp motor to
recharge the battery over the next 30 minutes or so.
Apparently there was a gas-electric hybrid glider at the AERO
Friedrichshafen show, or at least a poster about one. SoaringCafe has
pictures from the show. One pic is of a diagram of an Albastar 18m
glider with internal gasoline engine driving a generator linked to a FES.
I like the idea of starting the motor before you have to commit to using
it. There is a glider with an enclosed, internal gasoline engine - the
Stemme - but it can't be started independently of propeller operation,
and the drive shaft is a difficult technical problem requiring the side
by side seating. The Albastar has a substantial engine of 65 hp, and the
use of using a generator/electric motor for power transmission to the
propeller gives it a lot of flexibility in design the Stemme did not have.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old May 15th 13, 10:26 PM posted to rec.aviation.soaring
Jet engines are cool, light, and start easily (I gather)
Unless you have a wet start.
Old May 16th 13, 09:52 PM posted to rec.aviation.soaring
plantain
small fuel cell.
email me)
The original LS8-t did just that - engine could be started before the prop extended.
Old May 17th 13, 06:42 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
plantain wrote, On 5/16/2013 1:52 PM:
How did the exhaust get out of the glider? Was the engine fixed in
place, and only the propeller and mast went up?
email me)
How Its Made - Ventus 2cx [email protected] Soaring 2 December 22nd 11 06:50 PM
How it's Made - Gliders Craig[_2_] Soaring 15 March 10th 09 12:45 PM
2, People know that Swiss made watches are best, while the Asia madeare worst but cheapest, but Some of Asia made Oyster Perpetual Air King - AllStainless Steel are also close to a real thing that is in fact almostimpossible to tell the difference. [email protected] Piloting 0 April 26th 08 07:49 PM
Made in the USA Lou Home Built 37 August 3rd 06 02:10 PM
The ME 262 is the best plane ever made Rick Stoll Owning 1 May 24th 04 08:23 AM
