#21
On Thursday, June 13, 2013 3:12:14 PM UTC-7, noel.wade wrote:
P7 has the best answer... But Let's step back to facts, shall we? Polarized lenses literally block light, unless the light-waves are oriented at a specific angle to the lens. Almost all LCDs (including PDAs, cell-phones, iPads, and even simple displays like Cambridge *-NAV devices or digial variometers) have 1 or 2 polarized screens, as part of how they work. See he http://en.wikipedia.org/wiki/Liquid-crystal_display Stacking multiple polarizing filters in the proper orientation lets light pass through. But stacking them in the wrong orientation causes the light passing through the first filter to be BLOCKED by the second. Your polarized sunglasses _are_ a "second filter", sitting between your eyeballs and the LCD screens in your cockpit. Ergo, if the orientation of your sunglasses' polarized surface is not near the same angle of your electronic displays, the visibility of your instruments will be negatively impacted. Here are two video demonstrations of this: http://www.youtube.com/watch?v=GkLBMAY406Q http://www.youtube.com/watch?v=HcQWAqL2JUw Polarized sunglasses are not all manufactured the same; and even different batches of the same sunglasses may not always have the orientation to the polarized lenses - don't assume that because your glasses work for you, that you can recommend them to others or that you can simply buy another pair of the same, and have them work identically. Additionally, just because you find glasses that may work with _your_ cockpit instruments and canopy, do _not_ assume that it will work with _all_ instruments or canopies. Finally, don't assume that all of your instrument displays have the same polarization on their screens. I have polarized lenses that work fine when viewing some of my instruments, but not with others (unless you rotate the glasses 90-degrees). Also, these polarized sunglasses worked fine with my DG-300 canopy, but created horrible moire & checkerboard patterns on a couple of Diamond DA-20 rental aircraft canopies. If you're going to fly with a lot of cockpit electronics, I strongly recommend against polarized lenses because you don't want to be distracted or fumbling with your instruments because of this effect. There are plenty of effective non-polarized sunglasses out there that give you good visibility and protection. Lastly, if you're going to be flying in a club or rental environment, where you switch ships with any regularity, do NOT assume that polarized sunglasses which work in one cockpit will work in another. --Noel Good points. I guess it all boils down to "it depends". Polarized glasses always worked for me in the gliders I flew, but I agree this is not always going to be the case. So the solution is to have a spare non polarized glasses with you in case there is an issue. Ramy |
At 22:20 12 June 2013, wrote:
I'm getting new sun glasses, should I get Polarized or not, what works best for flying gliders??? The ones I'm looking at are also anti-glare lenses. Thanks Glen When I was in to gliding I always flew on a sunny day with Oakley wiretap fire iridium polarized sunglassed, to be specific. (http://www.oakley.com/products/1252/2794). No colour loss, no glare and on a blue day you can see 'haze caps' of thermals which would otherwise be invisible - I would recommend them. |
At 00:11 14 June 2013, Ramy wrote:
On Thursday, June 13, 2013 3:12:14 PM UTC-7, noel.wade wrote: P7 has the best answer... But Let's step back to facts, shall we? Polarized lenses literally block light, unless the light-waves are oriented at a specific angle to the lens. Almost all LCDs (including PDAs, cell-phones, iPads, and even simple displays like Cambridge *-NAV devices or digial variometers) have 1 or 2 polarized screens, as part of how they work. See he http://en.wikipedia.org/wiki/Liquid-crystal_display Stacking multiple polarizing filters in the proper orientation lets light pass through. But stacking them in the wrong orientation causes the light passing through the first filter to be BLOCKED by the second. Your polarized sunglasses _are_ a "second filter", sitting between your eyeballs and the LCD screens in your cockpit. Ergo, if the orientation of your sunglasses' polarized surface is not near the same angle of your electronic displays, the visibility of your instruments will be negatively impacted. Here are two video demonstrations of this: http://www.youtube.com/watch?v=GkLBMAY406Q http://www.youtube.com/watch?v=HcQWAqL2JUw Polarized sunglasses are not all manufactured the same; and even different batches of the same sunglasses may not always have the orientation to the polarized lenses - don't assume that because your glasses work for you, that you can recommend them to others or that you can simply buy another pair of the same, and have them work identically. Additionally, just because you find glasses that may work with _your_ cockpit instruments and canopy, do _not_ assume that it will work with _all_ instruments or canopies. Finally, don't assume that all of your instrument displays have the same polarization on their screens. I have polarized lenses that work fine when viewing some of my instruments, but not with others (unless you rotate the glasses 90-degrees). Also, these polarized sunglasses worked fine with my DG-300 canopy, but created horrible moire & checkerboard patterns on a couple of Diamond DA-20 rental aircraft canopies. If you're going to fly with a lot of cockpit electronics, I strongly recommend against polarized lenses because you don't want to be distracted or fumbling with your instruments because of this effect. There are plenty of effective non-polarized sunglasses out there that give you good visibility and protection. Lastly, if you're going to be flying in a club or rental environment, where you switch ships with any regularity, do NOT assume that polarized sunglasses which work in one cockpit will work in another. --Noel Good points. I guess it all boils down to "it depends". Polarized glasses always worked for me in the gliders I flew, but I agree this is not always going to be the case. So the solution is to have a spare non polarized glasses with you in case there is an issue. Ramy Polarised sunglasses should genarally be expected to have vertical polarization because the whole point about reducing glare from water surfaces etc is that the light reflected of the surface to the eye tends to be polarised horizontally. On another topic - genuine question - do polarised lenses made without a UV absorbing tint, and without a UV absorbing lens material such as polycarbonate, reduce UV transmission more than in proportion to the reduction in general light transmission? John Galloway |
At 14:08 14 June 2013, John Galloway wrote:
At 00:11 14 June 2013, Ramy wrote: On Thursday, June 13, 2013 3:12:14 PM UTC-7, noel.wade wrote: P7 has the best answer... But Let's step back to facts, shall we? Polarized lenses literally block light, unless the light-waves are oriented at a specific angle to the lens. Almost all LCDs (including PDAs, cell-phones, iPads, and even simple displays like Cambridge *-NAV devices or digial variometers) have 1 or 2 polarized screens, as part of how they work. See he http://en.wikipedia.org/wiki/Liquid-crystal_display Stacking multiple polarizing filters in the proper orientation lets light pass through. But stacking them in the wrong orientation causes the light passing through the first filter to be BLOCKED by the second. Your polarized sunglasses _are_ a "second filter", sitting between your eyeballs and the LCD screens in your cockpit. Ergo, if the orientation of your sunglasses' polarized surface is not near the same angle of your electronic displays, the visibility of your instruments will be negatively impacted. Here are two video demonstrations of this: http://www.youtube.com/watch?v=GkLBMAY406Q http://www.youtube.com/watch?v=HcQWAqL2JUw Polarized sunglasses are not all manufactured the same; and even different batches of the same sunglasses may not always have the orientation to the polarized lenses - don't assume that because your glasses work for you, that you can recommend them to others or that you can simply buy another pair of the same, and have them work identically. Additionally, just because you find glasses that may work with _your_ cockpit instruments and canopy, do _not_ assume that it will work with _all_ instruments or canopies. Finally, don't assume that all of your instrument displays have the same polarization on their screens. I have polarized lenses that work fine when viewing some of my instruments, but not with others (unless you rotate the glasses 90-degrees). Also, these polarized sunglasses worked fine with my DG-300 canopy, but created horrible moire & checkerboard patterns on a couple of Diamond DA-20 rental aircraft canopies. If you're going to fly with a lot of cockpit electronics, I strongly recommend against polarized lenses because you don't want to be distracted or fumbling with your instruments because of this effect. There are plenty of effective non-polarized sunglasses out there that give you good visibility and protection. Lastly, if you're going to be flying in a club or rental environment, where you switch ships with any regularity, do NOT assume that polarized sunglasses which work in one cockpit will work in another. --Noel Good points. I guess it all boils down to "it depends". Polarized glasses always worked for me in the gliders I flew, but I agree this is not always going to be the case. So the solution is to have a spare non polarized glasses with you in case there is an issue. Ramy Polarised sunglasses should genarally be expected to have vertical polarization because the whole point about reducing glare from water surfaces etc is that the light reflected of the surface to the eye tends to be polarised horizontally. On another topic - genuine question - do polarised lenses made without a UV absorbing tint, and without a UV absorbing lens material such as polycarbonate, reduce UV transmission more than in proportion to the reduction in general light transmission? John Galloway re uv absorption by sunglasses with no uv absorbing lens. I have no idea, but according to the page about my oakleys "...combines patented optics and PLUTONITEĀ® lens material that provides 100% UV filtering and unsurpassed impact protection...". Which is probably of no use to you whatsoever. All the best. |
John Galloway wrote, On 6/14/2013 7:08 AM:
Polarised sunglasses should genarally be expected to have vertical polarization because the whole point about reducing glare from water surfaces etc is that the light reflected of the surface to the eye tends to be polarised horizontally. On another topic - genuine question - do polarised lenses made without a UV absorbing tint, and without a UV absorbing lens material such as polycarbonate, reduce UV transmission more than in proportion to the reduction in general light transmission? Your canopy filters out most of the UVB, as will almost every pair of sunglasses, regardless of their tint or polarization. Plastic or glass that passes significant amounts of UVB is "special" stuff that costs more. UVA transmission is more variable, as it takes some effort to filter it out, so if you want to block it, look for a pair that specifically claims to do so. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
After trying a friend's Eagle Eyes (As seen on TV!!!), I found them to
improve detailed vision, especially spotting very thin dust devils. So I bought a pair with built in readers. They're great! I used them to take my wife for a ride in a friend's DG-500m-22 and they were flawless. Yesterday, when I pulled down the canopy of my LAK-17a, I found the screen of my CAI-302 to be totally black. At first I thought it was due to the heat but, raising the glasses, I saw the problem was with the misaligned polarization of the 302 screen with the glasses. I wonder if the glass in the 302 can be rotated 40-90 degrees... "Eric Greenwell" wrote in message ... John Galloway wrote, On 6/14/2013 7:08 AM: Polarised sunglasses should genarally be expected to have vertical polarization because the whole point about reducing glare from water surfaces etc is that the light reflected of the surface to the eye tends to be polarised horizontally. On another topic - genuine question - do polarised lenses made without a UV absorbing tint, and without a UV absorbing lens material such as polycarbonate, reduce UV transmission more than in proportion to the reduction in general light transmission? Your canopy filters out most of the UVB, as will almost every pair of sunglasses, regardless of their tint or polarization. Plastic or glass that passes significant amounts of UVB is "special" stuff that costs more. UVA transmission is more variable, as it takes some effort to filter it out, so if you want to block it, look for a pair that specifically claims to do so. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
On Sunday, June 16, 2013 9:42:52 AM UTC-7, Dan Marotta wrote:
After trying a friend's Eagle Eyes (As seen on TV!!!), I found them to improve detailed vision, especially spotting very thin dust devils. So I bought a pair with built in readers. They're great! I used them to take my wife for a ride in a friend's DG-500m-22 and they were flawless. Yesterday, when I pulled down the canopy of my LAK-17a, I found the screen of my CAI-302 to be totally black. At first I thought it was due to the heat but, raising the glasses, I saw the problem was with the misaligned polarization of the 302 screen with the glasses. I wonder if the glass in the 302 can be rotated 40-90 degrees... "Eric Greenwell" wrote in message ... John Galloway wrote, On 6/14/2013 7:08 AM: Polarised sunglasses should genarally be expected to have vertical polarization because the whole point about reducing glare from water surfaces etc is that the light reflected of the surface to the eye tends to be polarised horizontally. On another topic - genuine question - do polarised lenses made without a UV absorbing tint, and without a UV absorbing lens material such as polycarbonate, reduce UV transmission more than in proportion to the reduction in general light transmission? Your canopy filters out most of the UVB, as will almost every pair of sunglasses, regardless of their tint or polarization. Plastic or glass that passes significant amounts of UVB is "special" stuff that costs more. UVA transmission is more variable, as it takes some effort to filter it out, so if you want to block it, look for a pair that specifically claims to do so. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl No problem with my 302 with all polarized glasses I used. Either your glasses or your 302 polarized wrong. Ramy |
I always fly with my "Zoomies" binocular glasses (as seen on TV) https://www.buyzoomies.com/
Other gliders look 300% closer, so does the ground . . . it's a truly terrifying experience. I have no idea why a wear them but everyone else should as well. bumper |
#29
On Monday, June 17, 2013 1:51:13 PM UTC-7, Ramy wrote:
No problem with my 302 with all polarized glasses I used. Either your glasses or your 302 polarized wrong. Ramy Some 302's had their polarization off by 90 degrees (I think they got a bad batch IIRC). When I bought my 302 in '03 screen blacked out with polarized glasses. Sent it in and they replaced the glass to fix this at no charge. bumper |
#30
I don't know of any where to send mine now... I'll just use my older
non-polarized glasses and swap the Eagle Eyes to my car, hiking, and kayaking. "bumper" wrote in message ... On Monday, June 17, 2013 1:51:13 PM UTC-7, Ramy wrote: No problem with my 302 with all polarized glasses I used. Either your glasses or your 302 polarized wrong. Ramy Some 302's had their polarization off by 90 degrees (I think they got a bad batch IIRC). When I bought my 302 in '03 screen blacked out with polarized glasses. Sent it in and they replaced the glass to fix this at no charge. bumper |
| Thread Tools | |
| Display Modes | |
| Polarized Sun Glasses | Richard[_9_] | Soaring | 13 | May 29th 12 06:38 PM |
| Polarized Sun Glasses and PDAs | Michael Reid | Soaring | 12 | April 11th 10 03:36 PM |
| Carrying glasses? | Emily | Piloting | 58 | September 13th 06 01:27 AM |
| INFLIGHT IFR Training glasses,,,, anyone try them before | Cecil E. Chapman | Instrument Flight Rules | 0 | October 18th 03 01:24 AM |
| More on Sunreader glasses | Eric Greenwell | Soaring | 0 | September 23rd 03 12:38 AM |
