The near mid-air at the Region 9 contest
Old June 22nd 13, 05:10 PM posted to rec.aviation.soaring
Dan Marotta
Default The near mid-air at the Region 9 contest
To be accurate, it's Mode A (reply code) you're talking about, not Mode C
(pressure altitude). And why would Flarm users filter out signals from
possible threat aircraft? Or did I misunderstand the statement about
turning warnings down/off?
Most of the US air space is covered by ATC radar and so my transponder is
pinging away in reply so I expect Flarm equipped aircraft would see me if
they came into my area. Flying out of Moriarty yesterday, I was one of only
two gliders to stay up and, in 2.1 hours did not get a single blip on my
PCAS. I verified that it was reading my transponder replies by changing my
code and testgin again. I don't think Flarm could have improved my
situation any.
I know I should have simply stayed out of this but... Fire away.
Doesn't having a transponder also alert the Flarm unit/user?
Mode S will tell every flarm in miles where you are. Mode C is next to
useless for flarm, and many flarm people will have turned mode c warnings
down/off.
John Cochrane
Old June 22nd 13, 06:14 PM posted to rec.aviation.soaring
Darryl Ramm
Mode S will tell every flarm in miles where you are. Mode C is next to useless for flarm, and many flarm people will have turned mode c warnings down/off.
John Cochrane
Uh? I am willing to listen to economic advice anytime from John but I suspect there is some confusion here and he likely means 1090ES ADS-B. Which is an option on most modern Mode-S transponders but just having "Mode S" does not imply that aircraft transmits 1090ES.. and few especially GA aircraft will today. A threat aircraft with 1090ES data-out will show up with precise location/altitude data on your PowerFLARM, its no longer a PCAS threat with altitude only info. A Mode S (or Mode C) alone transponder in a threat aircraft will only ever present as an altitude only PCAS threat.
There are other compilations with Mode S vs. Mode C. With Mode S a PowerFLARM receiver could in principle do better de-duplciation of threats if that threat aircraft has both Flarm and Mode-S and the Flarm is properly set up to transmit the same unique ICAO address as the Mode S. (then your Flarm receiver can see both the Flarm and Mode-S signals come from the same aircraft). How well PowerFLARM does this in practice I can't comment on.
Old June 22nd 13, 07:29 PM posted to rec.aviation.soaring
Darryl Ramm
situation any.
There seems to be some confusion here.
To be accurate and correct :-O ...
PCAS typically has *nothing* to do with Mode A replies and is all about Mode C replies. Mode A encodes the squawk code and Mode C encodes the altitude.. A traditional Mode A/C transponder when being interrogated by an SSR system responds to interleaved Mode A and Mode C interrogation pulses (the targets are interrogated multiple times in both Mode A and C each rotation as the SSR interrogator beam sweeps past the aircraft) and responds with whatever its being asked for. PCAS systems, including in the PowerFLARM just listen to those replies and try to guess which ones are mode A or Mode C (the replies don't explicitly say what type they are, traditionally the interrogating SSR knows what it asked for). The PCAS first job is to typically discard any replies it things are mode A and then only using the Mode C replies, work out the altitude of the threat and whether it should display that/issue an alert etc. How well PCAS systems work given they are effectively blind and are have very little data, have to make guesses about Mode C replies and have to infer range from the RF power etc. With Mode S threats PCAS systems can be smarter, e.g. they can absolutely know that a squawk code and altitude transmission comes from the same aircraft etc. There was one older PCAS system that did display threat aircraft squawk codes (e.g. it decoded both Mode A and C) with the claim that its nice to know if a threat is VFR or under ATC control etc. But to me that is all just more info you have to display/let users understand etc. and likely not worth it.
One of the benefits of lots of the special Mode A codes like 1200, 1202, 7700, 7600 is that they do not encode as valid Mode C altitudes but lots of other altitude and squawk codes can alias with each other. This is not an issue when dealing with Mode S transponders being interrogated by a Mode S interrogator.
PCAS clearly cares about Mode C replies because it wants to know the altitude of any threat so it can work out what to do with it, including just ignore it. Mode A does not help much, and with pure Mode A and C transmission in dense traffic environments the PCAS cannot ever tell how to match up Mode C and A replies from the same threat aircraft.
And to complicate things further TCAS and TCAD systems never issue a Mode A interrogation, another reason PCAS never want to rely on anything Mode A, if they just listen to mode A and you were in a TCAS interrogator only environment you would just never ever see the threat. There are some complex second order things that PCAS systems could try to do with Mode A transmissions, but I suspect none of them do.
And to be clear on products here... Flarm equipped aircraft never see any PCAS threats. *PowerFLARM* does see Flarm and PCAS, at least in the USA where all PowerFLARM come with this capability, in other geographies things may be different, for example in Europe "PowerFLARM Pure" does not include PCAS reception capability.
Lots of USA airspace where gliders fly, especially close to terrain/mountains etc. is not covered by SSR and so transponders will not be interrogated by SSR. the obvious pointer here is that controlled airspace has SSR ground interrogator coverage and uncontrolled airspace may not. That will change to some extent as ADS-B rolls out, but hats a who other hairy topic. The savior there frequently is airborne TCAS interrogators, there are lots of airline, private jet and military aircraft flying around issuing mode C (and Mode S, but not Mode A) interrogations and that can be an important factor here to make out PCAS systems work.
Especially in mountainous regions you have to be cautious about PCAS, it might appear to work fine and then suddenly not work as you fly behind an obstruction that shields an SSR ground interrogator or as the overhead TCAS interrogator flies away. Or it might appear to work fine and then as you descent down to pattern altitude you can lose the interrogator yet be exposed to the more dangerous traffic density around an airport.
I'm not sure exactly what point you are making on you PCAS observation out of Moriarty. Assumption about whether you would see other gliders depends firstly on if those other gliders are Mode C or Mode S transponder equipped. And what the local interrogator coverage is, at Moriarty especially when low near the airport, which I assume does rely on TCAS interrogators. Or if you wanted to compare seeing them with PowerFLARM then you need to know if they are PowerFLARM equipped. What exactly was your point here and what are all the other gliders in the area equipped with?
PowerFLARM is clearly superior to PCAS in high-density glider on glider scenarios like contests because of the much more accurate threat information, because more gliders in the fleet are likely to be PowerFLARM equipped than transponder equipped and because there is no issues with needing the Flarm system to be interrogated. Transponders and PCAS have huge benefit when mixing with other traffic (especially gliders carrying transponders where there are high density TCAS equipped fast/commercial jet traffic) and working with ATC etc. Its simply a false paradox to make forced comparisons between transponders vs. PowerFLARM. Owners/pilots should be evaluating what is best for their needs, and that may be to get both.
Old June 22nd 13, 08:18 PM posted to rec.aviation.soaring
situation any.
PCAS typically has *nothing* to do with Mode A replies and is all about Mode C replies. Mode A encodes the squawk code and Mode C encodes the altitude. A traditional Mode A/C transponder when being interrogated by an SSR system responds to interleaved Mode A and Mode C interrogation pulses (the targets are interrogated multiple times in both Mode A and C each rotation as the SSR interrogator beam sweeps past the aircraft) and responds with whatever its being asked for. PCAS systems, including in the PowerFLARM just listen to those replies and try to guess which ones are mode A or Mode C (the replies don't explicitly say what type they are, traditionally the interrogating SSR knows what it asked for). The PCAS first job is to typically discard any replies it things are mode A and then only using the Mode C replies, work out the altitude of the threat and whether it should display that/issue an alert etc. How well PCAS systems work given they are effectively blind and are have very little data, have to make guesses about Mode C replies and have to infer range from the RF power etc. With Mode S threats PCAS systems can be smarter, e.g. they can absolutely know that a squawk code and altitude transmission comes from the same aircraft etc. There was one older PCAS system that did display threat aircraft squawk codes (e.g. it decoded both Mode A and C) with the claim that its nice to know if a threat is VFR or under ATC control etc. But to me that is all just more info you have to display/let users understand etc. and likely not worth it.
Yup - what Darryl said.
I got a transponder because I frequently fly at Minden. But of the last two glider friends I lost to midairs neither collided with a commercial aircraft and I believe both were outside or below airspace where PCAS could help you. One was a high density glider contest situation and the other hit the only other airplane in the vicinity - in the pattern. That doesn't even consider all the non-fatal collisions and near misses. Even at Minden before getting a transponder I was never surprised by an airliner, but frequently by gliders. In both cases I'm sure there were threats I missed, but given that jets and props make noise and glider don't I'm pretty sure that I missed more glider threats than powered ones.
I also find the lack of PCAS bearing and reliable range info particularly debilitating, though I'll take what I can get if it's the only game in town in high density commercial areas. If I knew how would turn off the PCAS warnings in a situation where I was flying a contest located outside of powered traffic areas simply because I would not want all the useless warnings distracting me from the useful ones.
Of course, that's just my situation.
9B
Old June 23rd 13, 12:16 AM posted to rec.aviation.soaring
Dan Marotta
Wow! That was an education on how the system works and I certainly need to
study some more.
Regarding PCAS and how I use it in *my* environment, it's not so much a
bearing/distance/height pointer showing me where to look, as it is watching
the distance/delta height and noting whether it's closing, matching, or
diverging from my flight path.
I think you nailed it in your last sentence: "Owners/pilots should be
evaluating what is best for their needs, and that may be to get both."
"Darryl Ramm" wrote in message
only
my
situation any.
it.
interrogator.
Old June 23rd 13, 03:54 AM posted to rec.aviation.soaring
jfitch
Question: is there pressure to equip towplanes at contests and for that matter generally with Flarm? The only recent midair in our area between light aircraft was glider and towplane. If the towplane didn't have a Flarm then it would not have helped. Where I fly I am much more likely to be close to a towplane than any other light aircraft (except other gliders), and I don't take tows.
Old June 23rd 13, 04:12 AM posted to rec.aviation.soaring
Darryl Ramm
Yes. And I believe that contest organizers can also use the PowerFLARM rental program for towplanes (see http://www.williamssoaring.com/powerflarm/rent.html). And some clubs/FBOs are already there with PowerFLARM equipped towplanes. Ask the operation where you fly and if they don't then it sounds like a great local education and financial issue you can work on with the owners/operator/club
Region V So Contest, USA Hartley Falbaum[_2_] Soaring 0 April 16th 12 02:12 AM
NEW REGION 2 CONTEST J9 Soaring 0 May 15th 11 02:35 PM
Region 3 contestants Welcome-Region Six North Contest Ionia November Bravo Soaring 0 August 13th 09 12:53 PM
Region 12 contest g l i d e r s t u d Soaring 0 December 17th 07 06:35 PM
(US) Region 11 Contest Pat Russell Soaring 2 July 13th 06 09:29 PM
