BTW: As a CFI I find the biggest obstacle to spin training is finding
a plane that the owner will let you spin. Most FBOs do instrument training in their 172s (and everything else) and therefor prohibit CFIs from spining the crap out of the gyros. -Robert, CFI |
![]() Most FBOs do instrument training in their 172s (and everything else) and therefor prohibit CFIs from spining the crap out of the gyros. I discovered this to be the case at Chandler. One of the reasons I went out there was to fly a Super Cub, and naturally I wanted to do the spin training in the PA-18 as well. But they don't allow the Super Cub to be spun, for just the reason you advance. At home, we're not permitted to spin the J-3 Cubs, either, but not because of the gyros ![]() (However, my first CFI learned in the Marine Corps, and he taught from the same book that taught him. He spun the Cub with me in the back seat after just a few lessons. It's a very different experience, being in a closed airplane in the back seat, than to be in the front cockpit of a Great Lakes with double seat belts and a parachute ![]() all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
In article , Cub Driver
wrote: Most FBOs do instrument training in their 172s (and everything else) and therefor prohibit CFIs from spining the crap out of the gyros. I discovered this to be the case at Chandler. One of the reasons I went out there was to fly a Super Cub, and naturally I wanted to do the spin training in the PA-18 as well. But they don't allow the Super Cub to be spun, for just the reason you advance. At home, we're not permitted to spin the J-3 Cubs, either, but not because of the gyros ![]() It's not the spin that will damage the airplane, it is poor pilot technique in the recovery that allows the airspeed to increase an pull too hard in the level off. If you haven't recovered an airframe in 20 years, you probably don't want to spin it until you have stripped the airframe and examined it carefully. Fabric hides lots of corrosion and cracks or breaks. |
On Fri, 9 Apr 2004, Robert M. Gary wrote:
BTW: As a CFI I find the biggest obstacle to spin training is finding a plane that the owner will let you spin. Most FBOs do instrument training in their 172s (and everything else) and therefor prohibit CFIs from spining the crap out of the gyros. Is wrecking the gyros really a problem with 'modern' gyros, though? (By modern I mean anything from the 1970s on...) At my flight school/club, all the planes are used for IFR training, AND they're all spinnable, except for the one 172 w/ Horton STOL tips & fences. Tell our Chief Flying Instructor that you're taking a 152 or 172 up for airwork including spins, and he'll just tell you to have a good flight... I almost get the impression that 'spinning wrecks gyros' is one of those old, old stories that's still hanging around, based perhaps on 1940-50s era gyros, which really would tumble/get damanged if spun. Is this the instrument equivilent of the 'downwind turn' OWT? Brian. |
(Captain Wubba) wrote
We could not get the airplane to enter a fully developed spin. It would enter the incipient stage just fine, but would not remain in the spin for even one complete rotation. What exactly are the definitions of 'spin training' that the FAA requires for CFI logbook endorsement? I am having trouble locating specific definitions. First off, I think you have probably not met the requirements. I will accept that the FAR's are vague on this matter. 61.183(i) Accomplish the following for a flight instructor certificate with an airplane or a glider rating: (1) Receive a logbook endorsement from an authorized instructor indicating that the applicant is competent and possesses instructional proficiency in stall awareness, spin entry, spins, and spin recovery procedures after providing the applicant with flight training in those training areas in an airplane or glider, as appropriate, that is certificated for spins; and (2) Demonstrate instructional proficiency in stall awareness, spin entry, spins, and spin recovery procedures. There is nothing in there about the spins needing to be fully developed, one turn, three turns, or anything of the sort. However, I think it is reasonable to expect that the minimum standard would be performing the maneuver as described in the CFI-Airplane PTS (FAA-S-8081-6B), Area of Operation XI, Task G (page 1-56, available from the FAA web site http://av-info.faa.gov/). Note especially Objective 3 - To determine that the applicant demonstrates and simultaneously explains a spin (one turn) from an instructional standpoint. If you have not done a spin that was at least one turn, I can't see how you can be endorsed as proficient. Here are some options I would consider: Find a lightweight instructor and do the spins in a C-150. With a tiny instructor (120 lbs or so) and minimum fuel, you should be within limits. Force the 172 into a spin. Here's how: Accelerate to about 130 kts (this will require a power-on dive). Smoothly pull up into a climbing left turn, about 25 degrees nose up and about 10 degrees left bank. Smoothly close the throttle, and maintain pitch and bank with elevator and ailerons until you hit the aft stop on the yoke. As you hit the aft stop, go hard over to the right on the ailerons while maintaining full aft elevator, and slam the left rudder to the floor as you give a short (1-2 seconds) burst of power with the throttle. Maintain all control inputs - full aft yoke, full right aileron, full left rudder. It should stay in a spin for one turn - long enough for you to get your endorsement. Be warned - the entry is a bit of a wild ride. Michael |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
