Don't sell your loran
Old April 26th 04, 02:26 PM
Michael
Jeff Saylor wrote
Unfortunately, I don't believe that Bendix-King/Allied-Signal/Honeywell has
manufactured the KNS-80 and related boxes in years.
No, but they're avaiable on the used market dirt cheap. I've got a
friend who will happily sell his for $300.
Michael
Old April 29th 04, 05:48 PM
Richard Kaplan
I've never used a LORAN either, so I don't have any personal experience
with how they behave overall. But if they can be compared to NDB/ADF
behavior in any way, count me out.
I have GPS, Loran, NDB, and also KNS-80 VOR/DME RNAV in my airplane.
If the chips go down, the Loran is much more reliable/accurate than the
VOR/DME RNAV.
VOR/DME RNAV relies on the accuracy of the VOR receiver and how well you
dial in a radial; it can easily be a mile or so off on a waypont.
Loran is much more reliable and accurate then VOR/DME RNAV. Loran got a bad
name simply because its signal tends to degrade in active precipitation,
especially snow... this can be reduced considerably however by placing
static wicks on the airplane.
Richard Kaplan, CFII
www.flyimc.com
Old April 30th 04, 03:15 AM
G.R. Patterson III
Richard Kaplan wrote:
Loran got a bad
especially snow...
Actually, I think most of the blame can be laid to the state of the art in computers
when the LORANs were developed. Mine takes several minutes to adjust to a change in
course, and I have seen it report a steady decrease in distance to an airport for
quite some time after one has turned directly away. It would not be useful for
maintaining distance from a controlled field.
Maybe with a faster CPU, LORAN would get more respect.
George Patterson
If you don't tell lies, you never have to remember what you said.
Old April 30th 04, 04:14 AM
Peter Duniho
"G.R. Patterson III" wrote in message
[...] Mine takes several minutes to adjust to a change in
airport for
for
\What LORAN receiver do you have? My Northstar M1 LORAN exhibits neither of
those problems.
What it *does* do is suffer significant errors in position on occasion,
which I haven't gotten a good explanation for. The errors are up to 20
miles off at times, and I have only noticed them when flying near home (but
of course, this is where I do most of my flying, so that may not indicate
anything). I do notice that when I fly long cross-country flights, I don't
have to go very far (50-100 miles) before the LORAN wants to change from one
GRI (or is that just my LORAN's way of saying "grid"? I can't remember) to
another. Maybe I'm right on the edge of reception for the one that the
LORAN unit wants to use (or on the edge of multiples, for all I know).
I doubt that this issue is a programming problem though. More likely a
fundamental limitation of the ground-based radio chain.
Pete
Old April 30th 04, 05:34 AM
Richard Kaplan
change in
airport for
for
If you didn't look at the name of my unit, you would be hard-pressed to tell
based on performance if I have a Northstar M1 Loran or a Northstar M3 GPS.
www.flyimc.com
Old April 30th 04, 05:46 AM
G.R. Patterson III
those problems.
I have the Foster LRN-501.
anything).
From the Foster manual. There are 6 LORAN chains in the U.S. (4 in the lower 48) and
more outside, and each is made up of a "master" transmitter and two or three "slave"
transmitters. These are synchronized and transmit timing info as part of the signals.
The receiver figures out where you are by calculating the difference between the
three transmitters and triangulating. Significant position errors can result when the
master and either of the slave stations are in line with your aircraft (you're
between them or they are both off to one side).
another.
GRI is "Group Repetition Interval', but basically it's saying it wants to change
chains.
Yep. Mine wants to change chains about the North Carolina/South Carolina border.
Reception sucks sometimes in Knoxville, and that's on a border as well. IIRC, you're
in Washington State? If so, you're at the boundary of the U.S and Canadian West Coast
chains. To make matters worse, the slave in your area (located in the middle of the
State) is shared by both chains.
Yep again. Programming would never enter into the situation. A faster CPU would,
however, result in the unit refreshing its idea of your position more rapidly after a
change of course (or your speed after leveling off, etc.).
George Patterson
Old April 30th 04, 07:00 AM
Peter Duniho
[...] Significant position errors can result when the
(you're
Interesting. My position errors always occur in the same geographical
location (just east of the Olympic Mountains)...I wonder if that location
happens to be in line with a master and a slave.
border.
IIRC, you're
West Coast
middle of the
You recall correctly. Based out of Paine Field, just north of Seattle. The
"zone of confusion" lies about 15-25 miles roughly southwest of Paine. I
have noticed that the receiver is marginally better when using the US West
Coast chain, but for whatever reason it always wants to use the Canadian
West Coast chain in the Puget Sound region. That's certainly a programming
issue: no way to override the chain in use. I can switch it manually, but
the LORAN unit immediately starts bugging me to switch back.
Back to the previous question of position errors... I found the locations
of the various LORAN chains, with the master and slaves. It doesn't appear
that the general area where I get the errors is in line with the master (in
Williams Lake, BC) and the slave (in George, WA). In fact, I'd have to be
over on the other side of the Cascades for that to happen.
However, I *am* flying near the Olympic Mountains, which might cause signal
reflections. I have seen some bizarre effects flying NDB approaches near
shorelines, where the ADF shows me right on course, but visually I can see
I'm well to the side (over a mile off in some cases). I wonder if similar
variations affect LORAN. The calculations must assume straight-line signal
propagation, so I suppose anything that caused the signal to not follow a
straight line would cause errors.
Though, now that I think about it, a reflection would make it appear I was
farther from the station, and the errors I'm getting are putting me closer
to it.
Ahh well...the mystery continues. Anyway, just wanted to mention that not
all units are afflicted with the same delay in position calculations your
unit appears to be.
Pete
LORAN antenna difference? JFLEISC Home Built 6 December 24th 04 10:10 PM
blujay - sell your airplanes online for free with 4 photos blujay.com Aviation Marketplace 0 December 21st 04 04:14 AM
Need Help with Northstar M1 Loran Jerald Malin Owning 4 December 8th 03 05:38 PM
Anybody Still Use Loran? Larry Smith Home Built 4 October 4th 03 05:06 AM
Flybuddy Loran Henry Kisor Owning 5 September 18th 03 10:47 PM
