IFR rating?
Old April 29th 04, 08:48 PM
Journeyman
In article L6Bjc.54148$_L6.4226739@attbi_s53, Jay Honeck wrote:
I've flown for almost 10 years, and almost 900 hours, VFR. Throw in another
500 hours with Mary as PIC during that period. There have been some times
when I wished I had the rating, but -- more often than not -- when I've been
grounded due to weather, an IFR rating wouldn't have helped. My plane is
simply not capable of handling ice, snow or thunderstorms -- and that covers
95% of the times I've been on the ground, cursing the weather gods...
Okay. I think that's probably true for most places. When I decided to go
for my instrument rating, I was living on the Puget Sound, and all I needed
from the rating was to climb a few thousand feet to get above the marine layer
into clear and 1e6-mile visibility.
Here on the other Sound, coming home from FL last month (with my new plane!),
the trip was 95% VMC, but I couldn't have done it without the instrument rating.
That said, while the rating does have its utility, it definitely makes the
go/nogo decision harder, not easier.
Morris
Old May 1st 04, 09:32 AM
Roger Halstead
On Thu, 29 Apr 2004 14:48:17 -0500, Journeyman
It's certainly a longggg way from a blank check, but it adds greatly
to the utility of the plane and like you, it allows me to make quite a
few flights that I'd not otherwise be able to try.
I'd be a lot more comfortable with a nice big MFD with both a strike
finder output, weather RADAR displayed via satellite, AND GPS, but I
try to be careful and avoid those areas where "things" are happening.
As far as getting the rating it makes the applicant practice flying at
a precision not required for the PPL and it makes the pilot far more
conscious of the weather and what it will probably be doing well after
you reach the destination. It also reinforces the "have a way out"
type of thinking not normally present in VFR only flying.
To me it doesn't make the go/no go decision more difficult, but it may
require much more input that for VFR on many occasions.
www.rogerhalstead.com
Morris
Old May 1st 04, 10:28 AM
tony
another
been
covers
layer
plane!),
rating.
My personal experience is that IFR is better. I'm rated, and I had owned a
Mooney based in eastern MA, and used it mostly for business travel. About 10%
of my planned trips were cancelled because oof icing, thunder storms, no solid
gold alternate, things like that. The 90% of the trips I did make were a LOT
more comfortable under IFR, even though maybe only 20 to 30% involved actual
IMC. Some of those could have been done VFR, but who wants to fly VFR in 3 mile
vis, or less than 3000 feet for 3 or 4 hours. It's much nicer being in the
soup, having Center tell you about traffic, getting long straight in approaches
to major airports ("cleared ILS to runway 26" is so nice to hear when you're
westbound after 3 hours flight), not having to sweat termanl control zones and
the like. It makes the airplane a lot more efficient.
Then there's flying at night. Even if the weather guessers promise CAVU, flying
IFR at night is prudent adn I think much safer.
So, my experience in the northeast at least is that IFR increases the
likelihood of making a planned trip from the 60 to 70 percent range to the 90
percent range in a reasonably equipt SEL airplane. I also like to think it
increases safety quite a lot.
I just glanced through my pilot's log book -- looks like about 20% of the
flights I've logged show actual instrument conditions.
That's one SEL pilot's experience -- it may be typical for someone flying in
the Northeast.
Old May 1st 04, 01:28 PM
Journeyman
Different way of saying the same thing? On an obviously VFR day,
going is a no-brainer. On an obviously IFR day (without the rating),
nogo is a no-brainer (modulo those who *gasp* run the scud).
When it's IFR, you need to think about a lot more things.
It goes from (usually) an obvious yes/no to a continuum. At what
point do you decide it's a nogo?
Morris
Old May 2nd 04, 02:15 PM
tony
Morris
If you're current, if the forecast at your destination is well above your
personal minimums, if you have a solid gold alternate, no imbedded
thunderstorms, no icing, no unusual turbulence reported, why whouldn't you go?
IFR in those conditions is a lot easier IMO than VFR.
The undlying assumption is that the PIC is both current, competent, and
confident, of course. If you haven't shot an approach or two to minimums, even
under the hood, in the past few weeks, your personal minimums should be a lot
greater than the published ones.
Old May 2nd 04, 04:09 PM
Peter Duniho
"tony" wrote in message
go?
IMHO, the go/no-go decision is being made constantly, not just before
takeoff.
I agree with those who say that the instrument rating makes the
decision-making more complicated. I don't see this as necessarily a bad
thing, but it is the price of the increased utility. Basically, when flying
IFR there are more potential ways to run into flight hazards you can't see
or predict than when VFR, at least in a typically-equipped four-seater
piston airplane that most of us are flying.
Forecast above minimums? Great...forecasts can be wrong and you won't find
out until you get there and try to fly the approach. "Solid gold
alternate"? What's that? In flying, there are no guarantees. No imbedded
thunderstorms? Well, I guess if you have radar and/or a lightning detector,
you could know this. Most of us don't. No icing? Impossible to know for
sure until you fly through. No unusual turbulence reported? Past
performance is no guarantee of future returns and when flying IMC, you have
fewer clues to hint at the possibility, since you can't see visual signs of
wind conditions.
When flying day VFR, you can see outside the airplane and avoid most weather
conditions that would be a problem. Not all people do, of course, and you
still have wind to deal with. But even with wind, for the observant pilot
there are plenty of clues. Night VFR is harder, but with conservative
decision-making and proper planning, you can avoid flying into clouds, and
you can visually avoid the rest of the stuff that might cause a problem.
When flying IFR, real IFR that is, you are consistently in situations in
which it's impossible to know for sure what hazards are present until you
personally are in the area of the potential hazard. With extremely
conservative decision making it's possible to avoid these issues, but then
the utility of IFR rating becomes only slightly better than the VFR rating.
Hardly worth the effort. Some real work needs to be put into the decision
making to ensure you avoid these problems while still getting the usefulness
of the instrument rating it offers.
Bottom line: for VFR go/no-go the decision matrix is much simpler than that
found for IFR flights. To me, a more complicated decision matrix means more
complicated decision making.
Pete
Old May 2nd 04, 04:37 PM
tony
takeoff.
Of course -- most often the night before in my case, based on weather
expectations.
I fly an Mooney 201 that I keep in top condition, Even so I've had some in
flight failures -- vacuum pump in one case, alternator in the other, in actual
IMC conditions. Training has everything to do with handling such events, they
were hardly emergencies. As an aside, I like to keep my ADF tuned to a strong
station in the direction I'm flying, that works as a backup to the DG.
Oh come on. If the weather is slow moving and the forecast is for 1000 feet
ceiling 4 hours from now and there's an ILS with 200 feet minimums, you're
going to cancel the flight?
Solid gold alternate" What's that?
Yeah -- my bird has 6 comfortable hours of endurance -- 8 if I go high and
lean. If my destination is 2..5 hours west, and my home base is in good weather
and it's expected to stay that way for the next half day, that's pretty golden.
BTW, if conditons are changing faster than expected, well that's what flight
service is for, you should know that and change your plans as needed. I had
unplanned RONs more than once on multiday cross countries because a weather
system brewed up some unforecasted nasties a couple of hours into a 5 hour
flight.
I tend to depend on knowing where the freezing level is and pilot reports.
Mooneys don't carry ice all that well.
I have no problems with prudent pilots deciding the conditions are not to their
liking and staying on the ground. I consider myself prudent, but probably fly
in conditons you'd choose not to, and that's OK for both of us. I happen to
like hard IFR, love the feeling of looking up at minimums and seeing the runway
a half mile in front of me -- that's the happy surprise -- almost as much as I
like looking up and seeing nothing but black or grey -- that's what I expect
whenever I fly an approach, that way I know what the missed approach is going
to be and expect to fly it.
I will admit if the engine quits I'd rather be in VFR at 11,500 feet, but that
is a gamble I do take. I do everything I know how to to avoid that kind of
failure, and that's the single biggest worry about flying in hard IFR I have.
Having said all of that, I can tell you, even flying to advance my business as
I do, I probably about 5% of my flights after I get to the airport. (Equipment
problems, WX is worse than expected -- never leave if I can't get back in)
Would you agree, different strokes?
Old May 2nd 04, 08:00 PM
Richard Kaplan
go?
There are many variations on all these issues.
Are you current in the exact airplane? In that model? Is low IMC weather
forecast and if so is it forecast locally or over a wide range?
Is there a front causing the weather and if so what would be the consequence
if the front slowed down or sped up?
If an approach is required, will wind permit this to be straight-in or
circling? If circling, have you done that recently?
What if there is no solid-gold alternate and the weather is forecast to be
800-2 everywhere within your airplane's range -- would that be easier or
harder than if your alternate is forecast to 200 - 1/2 with a 3000-10
alternate?
The possibilities are endless.
Richard Kaplan, CFII
www.flyimc.com
  #29
Old May 2nd 04, 11:49 PM
Peter Duniho
takeoff.
expectations.
That's not what I meant. The go/no-go decision is constantly reevaluated
even after takeoff, all the way to landing.
[...] Would you agree, different strokes?
Honestly, I have no idea what most of your post was trying to say. I didn't
say anything about engine or equipment failures at all, yet you seemed to
think that was an important point in your response. As far as the forecast
goes, you say "I consider myself prudent, but probably fly in conditons
you'd choose not to, and that's OK for both of us", which clearly misses my
point. The more challenging the weather you choose to fly in, the MORE
difficult the decision making becomes. You seem to be claiming it makes it
easier, which is mind-boggling to me.
I have no idea how, given what you wrote in your post, how you come to the
conclusion that IFR decision making is easier than VFR.
Pete
  #30
Old May 3rd 04, 02:11 AM
Teacherjh
The difficulty of a go/no-go decision rests on a balance between pilot/plane
capabilities, and weather conditions. An experienced IFR pilot in a capable
plane will have a real easy time making a decision about flying in VFR, whereas
a newly minted pilot in a tomahawk might still be squirrely about some
conditions, though he may still choose to go. However, the experienced IFR
pilot can also find conditions which will squirrel him out.
It's not VFR vs IFR. It's "how close are these conditions to the ones you and
the plane are capable of", both in terms of handling the conditions themselves,
and the available outs.
Jose
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Get your Glider Rating - Texas Burt Compton Aviation Marketplace 0 December 1st 04 04:57 PM
51st Fighter Wing betters rating to ‘excellent’ with inspection Otis Willie Military Aviation 0 February 20th 04 11:29 PM
Enlisted pilots John Randolph Naval Aviation 41 July 21st 03 02:11 PM
