Don't you just hate it when the propeller departs the aircraft?
Old December 29th 13, 03:17 AM posted to rec.aviation.soaring
Default Don't you just hate it when the propeller departs the aircraft?
See this link
http://www.flickr.com/photos/titanet/3923711894/
So the prop extends to the open position as the RPM increases when starting.
Dan
On Tuesday, December 24, 2013 9:26:36 AM UTC-5, firsys wrote:
What kind of asymmetry?
At least you can retract the engine; not so if the belt breaks.
John F
At 22:54 22 December 2013, wrote:
Check this out
http://ad.easa.europa.eu/ad/2013-0217-E.
Yes The Ventus CM has an asymmetrical prop that probably reduces the
torsional vibrations.
Dan G (Ventus CM Owner)
On Wednesday, December 18, 2013 11:54:38 AM UTC-5, Dave Nadler wrote:
A prospect was checking out the nifty Antares 18T
sustainer system somewhere over the forest west of ZWB,
when to his great surprise, the propeller departed.
Hell of a way to impress a prospect.
The problem is with the Solo propeller shaft with the
belt reduction system as used on, IIRC:
- Ventus CM (not V2)
- Duo T
- DG-100T
- Antares 18T
Apparently there have also been recent incidents with DG1000T.
The propeller is not identical on all the above so the
failure rates will differ.
Axel Lange has worked with Solo to redesign the offending
part and is working on EASA approvals. IIRC this will be
the 3rd or 4th AD on this part, but Axel can calculate why
it failed and also how to make a part that won't...
I don't know if there's been any communication from SH
or who else uses this particular (front belt-reduction)
Solo system.
I see DG has published some info he
http://www.dg-flugzeugbau.de/index.p...1349&tx_ttnews[tt_news]=147&cHash=cd1730aca0037e72c7b2911e83136b2e
Another reminder to always operate your motor with a
plan for failure at any point...
Aaarrrggggg....
Be safe out there,
See ya, Dave "YO electric"
Old December 29th 13, 03:18 AM posted to rec.aviation.soaring
No, Like this http://www.flickr.com/photos/titanet/3923711894/
It's asymmetrical at rest but symmetrical when operating...
Dan
On Tuesday, December 24, 2013 11:22:47 AM UTC-5, Dan Marotta wrote:
Is this what you mean?
http://www.glidingmagazine.com/Image...lerPylon01.jpg
"John Firth" wrote in message
John F
Check this out
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
F-16 Norway Departs for Mission Maple Flag Maple1 Aviation Photos 0 February 27th 11 09:44 PM
Oil door departs the airframe Jack Allison Owning 5 June 15th 05 12:28 AM
Propeller for aircraft engine ground test Guy Deraspe Home Built 0 July 21st 04 04:41 AM
