#21
Gene Nygaard wrote:
"Julian Scarfe" wrote in message ... I spent a while writing the physics bit of the New Penguin Dictionary of Science. The hardest part was knowing whether to be prescriptive (tell them what the usage *should* be) or descriptive (describe what the common usage *is*). It's a judgement call in almost every case -- for example, I had no qualms about defining "weight" quite carefully to distinguish it from "mass", even though many people say "weight" when they mean "mass". You are confused if you think you made a correct "should be" call on this. Well, perhaps you missed the fact that he was writing definitions for a dictionary of _science_ ? There is no conflict, really, between the call he made, in that context, and the everyday meaning you go on to defend, and quite convincingly so. When we say our bag of sugar has, as it might be labeled in the U.S., a "net weight" of 10 lb (4.54 kg), where the pound is of course a unit of mass officially defined as 4.5359237 kg, that is absoloutely correct and proper, well justified in linguistics, in history, and in the law. Absolutely. That's the original meaning of the word "weight," which entered the English language meaning the quantity measured with a balance, used to measure goods sold by weight in commerce. We measures mass, as that term is used in physics jargon today, with a balance--not the force due to gravity. Not quite, though you have a point. What we measure with a balance is the relationship of the force due to gravity of the object we want to weigh, to that of a reference object of a known weight. We are measuring relations between "weights", as the term is understood in physics. To illustrate this, in the absence of gravity we could not measure mass in this way (well, we might contrive a way to use inertial forces, but we'd still be measuring forces). Where you do have a point is in the sense that this method will give consistent results whether performed on earth, on the moon, or in any other gravitational field. Spring-based scales of course measure absolute weight and will only give correct (mass) results in a standard gravitational field eg. on the earth's surface. In both cases we express the result in units of mass. In other words, it isn't a case of us saying the wrong thing. We mean to say "weight"; we mean "weight" in a quite legitimate and proper meaning of the word; it just happens to be the same quantity that physicists happen to call "mass" in their jargon--but we don't normally "mean" something different from what we "say." Agreed. It's not really a case of either being wrong. It's just that in physics there is a need to differentiate and keep the two concepts apart, while in everyday life there is normally no such need. Most people (even physicists, I imagine), quite correctly and appropriately, say "weight" in everyday contexts, when referring to something that is really "mass", as the concept is understood in physics. They are not saying anything different from what they mean. They are merely applying a level of differentiation of concepts, appropriate to the situation at hand. 5.7.4 The use of the verb "to weigh" meaning "to determine the mass of," e.g., "I weighed this object and determined its mass to be 5 kg," is correct. If the weight and the gravitation are known, the mass can be determined, so the above sentence is quite correct in any context, even as strictly understood in physics. CV |
On Wed, 05 May 2004 13:57:13 +0200, CV wrote:
Not quite, though you have a point. What we measure with a balance is the relationship of the force due to gravity of the object we want to weigh, to that of a reference object of a known weight. We are measuring relations between "weights", as the term is understood in physics. There is another issue using this method ... in very critical work, one compares the volumes of the 2 objects on a balance to correct for the density of air. The air has lift as did Archimedes system to determine if some crown was pure gold g (is that the coirrect reference?) |
On Wed, 05 May 2004 21:51:30 -0400, GeorgeB wrote:
On Wed, 05 May 2004 13:57:13 +0200, CV wrote: Not quite, though you have a point. What we measure with a balance is the relationship of the force due to gravity of the object we want to weigh, to that of a reference object of a known weight. We are measuring relations between "weights", as the term is understood in physics. There is another issue using this method ... in very critical work, one compares the volumes of the 2 objects on a balance to correct for the density of air. The air has lift as did Archimedes system to determine if some crown was pure gold g (is that the coirrect reference?) Yep, but I think you meant to say bouyancy. Don |
Science. The hardest part was knowing whether to be prescriptive (tell them what the usage *should* be) or descriptive (describe what the common usage *is*). It's a judgement call in almost every case -- for example, I had no qualms about defining "weight" quite carefully to distinguish it from "mass", even though many people say "weight" when they mean "mass". "Gene Nygaard" wrote in message om... You are confused if you think you made a correct "should be" call on this. ... I think you illustrate the dilemma rather well! Are there *any* correct "should be" calls? If so, what makes them "correct"? I would note however, the words "should be" in the passage below, which you quote: '5.7.3 Considerable confusion exists in the use of the term "weight." In commercial and everyday use, the term "weight" nearly always means mass. In science and technology, "weight" has primarily meant a force due to gravity. In scientific and technical work, the term "weight" should be replaced by the term "mass" or "force," depending on the application.' :-) Julian |
Gene Nygaard wrote: "Julian Scarfe" wrote in message ... I spent a while writing the physics bit of the New Penguin Dictionary of Science. The hardest part was knowing whether to be prescriptive (tell them what the usage *should* be) or descriptive (describe what the common usage *is*). It's a judgement call in almost every case -- for example, I had no qualms about defining "weight" quite carefully to distinguish it from "mass", even though many people say "weight" when they mean "mass". You are confused if you think you made a correct "should be" call on this. Well, perhaps you missed the fact that he was writing definitions for a dictionary of _science_ ? ] Yes, of science. NOt of the mechanics section of an introductory physics textbook. Furthermore, it is often easiest to explain a jargon meaning by showing how that usage is distinguished from normal usage. There is no conflict, really, between the call he made, in that context, and the everyday meaning you go on to defend, and quite convincingly so. When we say our bag of sugar has, as it might be labeled in the U.S., a "net weight" of 10 lb (4.54 kg), where the pound is of course a unit of mass officially defined as 4.5359237 kg, that is absoloutely correct and proper, well justified in linguistics, in history, and in the law. Absolutely. That's the original meaning of the word "weight," which entered the English language meaning the quantity measured with a balance, used to measure goods sold by weight in commerce. We measures mass, as that term is used in physics jargon today, with a balance--not the force due to gravity. Not quite, though you have a point. What we measure with a balance is the relationship of the force due to gravity of the object we want to weigh, to that of a reference object of a known weight. We are measuring relations between "weights", as the term is understood in physics. To illustrate this, in the absence of gravity we could not measure mass in this way (well, we might contrive a way to use inertial forces, but we'd still be measuring forces). Pretty strange notion of what it means "to measure" something. If I have measured forces, then suppose I weighed a gold coin on one of these balances at Hammerfest, Norway, and it weighed 19 dwt 20 gr (nearly a troy ounce; the troy units of weight are always units of mass, never units of force). How much force is it exerting due to gravity? Then I take it to Quito, Ecuador, and it weighs 19 dwt 20 gr. How much force is it exerting due to gravity here, where the acceleration of free fall is much less? If it makes it easier for you, change that to 30.84 g. How much force does it exert at each place? If we've measured forces, you should be able to tell me that. But we haven't "measured" these forces. Where you do have a point is in the sense that this method will give consistent results whether performed on earth, on the moon, or in any other gravitational field. Spring-based scales of course measure absolute weight and will only give correct (mass) results in a standard gravitational field eg. on the earth's surface. In both cases we express the result in units of mass. In other words, it isn't a case of us saying the wrong thing. We mean to say "weight"; we mean "weight" in a quite legitimate and proper meaning of the word; it just happens to be the same quantity that physicists happen to call "mass" in their jargon--but we don't normally "mean" something different from what we "say." Agreed. It's not really a case of either being wrong. It's just that in physics there is a need to differentiate and keep the two concepts apart, while in everyday life there is normally no such need. But the usage in commerce is much more consistent and uniform than the usage in science. Most people (even physicists, I imagine), quite correctly and appropriately, say "weight" in everyday contexts, when referring to something that is really "mass", as the concept is understood in physics. They are not saying anything different from what they mean. They are merely applying a level of differentiation of concepts, appropriate to the situation at hand. 5.7.4 The use of the verb "to weigh" meaning "to determine the mass of," e.g., "I weighed this object and determined its mass to be 5 kg," is correct. If the weight and the gravitation are known, the mass can be determined, so the above sentence is quite correct in any context, even as strictly understood in physics. Sure, introduce some new big "ifs" not in the original. As in my example with the gold coin, usually the "gravitation" is not known. Furthermore, "weighing" the object doesn't give you a "weight" which is different from mass, as your statement assumes. The statement in that standard is intended to reflect the fact that chemists especially, and physicists as well, consider the use of the verb form acceptable in situations were many would not accept using the noun "weight" to express the result when they "weigh" something. Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ |
correct "should be" calls? If so, what makes them "correct"? Precise words = precise thoughts = precise understandings = precise behavior. Historical precedent be damned. ;-) Most of history is an example of slopping thinking. |
On Thu, 06 May 2004 14:48:08 GMT, Greg Esres
wrote: I think you illustrate the dilemma rather well! Are there *any* correct "should be" calls? If so, what makes them "correct"? Precise words = precise thoughts = precise understandings = precise behavior. So go find yourself a precise word. Maybe you can borrow one from Norwegian; the physicists using that language had more sense than those using English. They didn't choose "vekt"--the cognate of the English "weight"--for their jargon word for the force due to gravity. Instead, they chose an entirely different word, "tyngde." Historical precedent be damned. ;-) Most of history is an example of slopping thinking. The meaning of "weight" is much more consistent and uniform in commerce than it is "in science." Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ |
Gene Nygaard wrote:
Well, perhaps you missed the fact that he was writing definitions for a dictionary of _science_ ? ] Yes, of science. NOt of the mechanics section of an introductory physics textbook. Is physics not science ? Not quite, though you have a point. What we measure with a balance is the relationship of the force due to gravity of the object we want to weigh, to that of a reference object of a known weight. We are measuring relations between "weights", as the term is understood in physics. To illustrate this, in the absence of gravity we could not measure mass in this way (well, we might contrive a way to use inertial forces, but we'd still be measuring forces). Pretty strange notion of what it means "to measure" something. If I have measured forces, then suppose I weighed a gold coin on one of these balances at Hammerfest, Norway, and it weighed 19 dwt 20 gr (nearly a troy ounce; the troy units of weight are always units of mass, never units of force). How much force is it exerting due to gravity? Then I take it to Quito, Ecuador, and it weighs 19 dwt 20 gr. How much force is it exerting due to gravity here, where the acceleration of free fall is much less? If it makes it easier for you, change that to 30.84 g. How much force does it exert at each place? If we've measured forces, you should be able to tell me that. But we haven't "measured" these forces. Partly true. We have not measured their absolute values. We are not even interested in them. We have measured the relationship between two forces, which allows us to determine the mass. We still depend on there being forces for this measurement to work. Take your gold coin along on a flight on the Space Shuttle. In a weightless state, your balance would not tell you anything, but the coin would still have the same mass as in Hammerfest or Quito. 5.7.4 The use of the verb "to weigh" meaning "to determine the mass of," e.g., "I weighed this object and determined its mass to be 5 kg," is correct. If the weight and the gravitation are known, the mass can be determined, so the above sentence is quite correct in any context, even as strictly understood in physics. Sure, introduce some new big "ifs" not in the original. As in my example with the gold coin, usually the "gravitation" is not known. Furthermore, "weighing" the object doesn't give you a "weight" which is different from mass, as your statement assumes. It might, and it might not, depending on the method of "weighing". Use some kind of spring-based scales on your gold coin and it will. The statement in that standard is intended to reflect the fact that chemists especially, and physicists as well, consider the use of the verb form acceptable in situations were many would not accept using the noun "weight" to express the result when they "weigh" something. Sure, an elaborate interpretation of what it was "intended to reflect", to suit your purpose. Didnīt _someone_ just object to introducing new stuff, not in the original ? All the same, even in that context, those chemists and physicists have a good reason for accepting one and not the other, which is what my comment intended to point out. CV |
#29
On Fri, 07 May 2004 11:48:51 +0200, CV wrote:
Gene Nygaard wrote: Well, perhaps you missed the fact that he was writing definitions for a dictionary of _science_ ? ] Yes, of science. NOt of the mechanics section of an introductory physics textbook. Is physics not science ? Sure. So what? That might be useful if you want to prove the meaning we are discussing is _sometimes_ used in science. That's as far as that logic gets you. But if you look at the bigger picture, you don't have the consistency you claimed. Not even in the rest of physics. Not even in real-world application of those mechanics problems. Yes, "weight" is sometimes used with that same meaning in other areas in science. It is also used with other meanings in other areas of science. When I first learned about atomic weight, this was different in physics than it was in chemistry--one based on the oxygen-16 isotope having an atomic weight of 16, the other on the natural mixture of oxygen on Earth having an atomic weight of 16. Don't bull**** me about "molecular weight" and "atomic weight" not being used any more. Just do a search of the Internet or of Usenet. Go look at some of the thousands of periodic tables, many from colleges and universities around the world, which give you the atomic weight of the elements. When the medical sciences talk about human body weight, they measure mass in units of kilograms or pounds, not newtons and not kilograms force and not pounds force. It isn't any different if a zoologist talks about the weight of a capybara or a hummingbird or an ostrich's egg. What does weight mean when the NASA scientists and engineers tell us that the weight of the Apollo 11 lunar module at liftoff of its ascent stage was 10,776.6 lb? At the time, of course, it was only exerting a force due to gravity of somewhere around 1800 lbf. This is normal NASA usage; we still see it today in connection with the space station. For the Apollo missions, NASA has recordings of the conversations between astronauts and ground control in which the astronauts are reading off these numbers, in those units of pounds mass, and they are referring to this quantity as "weight" because that's the way it was indicated on the readout from their onboard computers. An agronomist in the U.S. might use "bushels by weight" in assessing the production from a test plot of soybeans. That is also "in science." Other scientists will measure "dry weight" of various quantities. It is mass they are interested in, not force. Not quite, though you have a point. What we measure with a balance is the relationship of the force due to gravity of the object we want to weigh, to that of a reference object of a known weight. We are measuring relations between "weights", as the term is understood in physics. To illustrate this, in the absence of gravity we could not measure mass in this way (well, we might contrive a way to use inertial forces, but we'd still be measuring forces). Pretty strange notion of what it means "to measure" something. If I have measured forces, then suppose I weighed a gold coin on one of these balances at Hammerfest, Norway, and it weighed 19 dwt 20 gr (nearly a troy ounce; the troy units of weight are always units of mass, never units of force). How much force is it exerting due to gravity? Then I take it to Quito, Ecuador, and it weighs 19 dwt 20 gr. How much force is it exerting due to gravity here, where the acceleration of free fall is much less? If it makes it easier for you, change that to 30.84 g. How much force does it exert at each place? If we've measured forces, you should be able to tell me that. But we haven't "measured" these forces. Partly true. We have not measured their absolute values. We are not even interested in them. We have measured the relationship between two forces, which allows us to determine the mass. We still depend on there being forces for this measurement to work. Take your gold coin along on a flight on the Space Shuttle. In a weightless state, your balance would not tell you anything, but the coin would still have the same mass as in Hammerfest or Quito. So you need to find a different tool when it doesn't work. A liquid in glass thermometer won't work if it is so hot the glass melts, or so cold the liquid freezes. But when it does work, we use it to measure temperature. NASA has found a different tool for the astronauts to use in weighing themselves in space. 5.7.4 The use of the verb "to weigh" meaning "to determine the mass of," e.g., "I weighed this object and determined its mass to be 5 kg," is correct. If the weight and the gravitation are known, the mass can be determined, so the above sentence is quite correct in any context, even as strictly understood in physics. Sure, introduce some new big "ifs" not in the original. As in my example with the gold coin, usually the "gravitation" is not known. Furthermore, "weighing" the object doesn't give you a "weight" which is different from mass, as your statement assumes. It might, and it might not, depending on the method of "weighing". Use some kind of spring-based scales on your gold coin and it will. Okay, we've taken care of a couple of the simpler examples. Of course, there's a reason you don't see gold buyers running around with spring scales. Now suppose I have one of those modern piezo-electric electronic load cell scales, for use in commerce or for precise measurements in the chemistry lab. Maybe it is used to weigh a bell pepper at the supermarket, or a semi-load of wheat at the grain elevator, or a package at the post office. When it is set up, the manufacturer's representative makes sure that it is set level, and goes "under the hood" to adjust it for use in that location. It is, of course, the microprocessor that makes this possible; making the adjustments is normally made more difficult than it needs to be, to reduce that chances of tampering when no inspector is around. He places a known test weight on the scale, and adjusts it so that it reads the correct amount. Then when a government inspector comes to test and certify the scale (in commerce anyway--government doesn't worry about the chemistry lab), this is done by placing test weights of known mass on the scale, making sure that the readout is within the limits allowed for the purpose for which it is used. So what do those scales "measure"? They are tested and certified on the basis of their accuracy in measuring mass in the very location in which they are used, not on their accuracy in measuring force. We never get any number we could assign to the precise amount of force the weighed object does exert at that particular location. Two such scales, properly calibrated, will give the same reading in Hammerfest and in Quito. Properly adjusted force-measuring scales would show a significantly different force due to gravity. Gene Nygaard http://ourworld.compuserve.com/homepages/Gene_Nygaard/ |
#30
Bob Moore wrote
Well....a Dutch Roll is probably not what you understand it to be, particularly if you have not flown swept-wing transport aircraft. The aileron/rudder drill sometimes taught to student pilots is not a Dutch Roll. Well said Bob! Chuck |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 04 06:28 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | July 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 06:27 AM |
