#21
I saw a set of rollers with the corrugation profiles in them, and the 2024 was 'simply' hand cranked between them. Once
you have the rollers is should be pretty easy, but getting the rollers... They crank out roof gutters from the back of vans on the building site, maybe someone knows someone who has an old gutter rig... -- Dan D. .. wrote in message ... In article , "Blueskies" wrote: ala TriMotor - corrugations I kind of like the idea of corregations. Any ideas on how to accomplish them? thanks, tom |
How about cork? Probably too heavy...
-- Dan D. .. "Tim Ward" wrote in message ... wrote in message ... snip of misunderstanding Sorry I wasn't clearer on my intention. I'd only spray about an inch on the panels. Not much weight, and still get significant damping. tom Balderdash, tom. I think you are blowing in my ear. First, just how do you expect to "spray on" a 1 inch thick layer of foam INSIDE a wing? I can't do it, and I can do anything (with Duct tape!). Second, a 100 square foot wing is 14,400 square inches. One inch thick is 14,400 CUBIC inches, or 8.3 cubic feet. Top and bottom skins give 28,800 cubic inches or 16.6 cuft. At the mythical 3 lb/ft^3, that's 50 pounds. Sorry dude, that boat don't float... Yeah it will. 8^) I was talking about flat panels on the fuselage. The Zenith CH701 I would like to build has about 60 square feet of fuselage area behind the cabin. At one inch, that amounts to 5 cubic feet. One website I visited that made fire retardant spray urethane foam says 1.75 pounds per cubic foot, so the weight of this addition would be less than nine pounds. If the panels are really flat, then why spray it on? Low density foam is available in sheets. I'll bet the consistency is better than you can get from a can. Bond it on before you rivet. It shouldn't have to go all the way to the edges to prevent the oilcanning. It looks like for the 9 lb weight penalty you could increase the thickness of just those panels by about .010 inches (.15 lbs/sq ft). That would make it less likely to oilcan and stronger. Does the foam really need to be continuous? Why not just bond some foam stiffeners to the inside of the panel every six inches or so? The HP-18 sailplane wing is made from 1/2" foam on four inch centers. That technique might be more anechoic than a smooth continuous foam surface, too. You could taper the stiffeners to be thicker in the center of the panel, and get more stiffness/unit weight that way. An interesting way to bond the stiffeners might be to use 3M VHB (Very High Bond) double stick tape. It's used to bond side panels on truck and trailer bodies. Fast and no goop. Tim Ward |
Blueskies wrote:
How about cork? Probably too heavy... And absorbs water. If it wasn't heavy when you put it in, it will be after you fly through the first cloud. Whatever you use, make sure it is HYDROPHOBIC (a word I learned about in RAH) -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Why not just buy a better headset? That ought to take care of any noise
from the sheetmetal and it won't add a bunch of weight and potential for hidden corrosion to form under the deadening material. I thought this discussion was about a bush plane? All of the serious bush pilots that I know strip all of that crap OUT of their airplanes if possible. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
Del Rawlins wrote:
Why not just buy a better headset? That ought to take care of any noise from the sheetmetal and it won't add a bunch of weight and potential for hidden corrosion to form under the deadening material. I thought this discussion was about a bush plane? All of the serious bush pilots that I know strip all of that crap OUT of their airplanes if possible. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ I thought it was about a Zodiac, but i've been wrong before... But a Bush plane with rattle padding? File under Hard Lessons Learned: How important it is - and how hard it is - to keep excess weight OUT of an airplane. Temper foam is a great example. This is for sure and certain the most comfortable stuff imaginable short of free fall, but the WEIGHT! Padding a pair of bucket seats can add 30 pounds to the empty weight of the airplane. Ed Heineman would tell it loud and clear... Simplacate rather than complicate. Add lightness rather than heaviness. Richard |
In Richard Lamb wrote:
I thought it was about a Zodiac, but i've been wrong before... Could have sworn they was talking about a CH701 STOL. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
In article , Del Rawlins wrote:
In Richard Lamb wrote: I thought it was about a Zodiac, but i've been wrong before... Could have sworn they was talking about a CH701 STOL. I was talking about a CH701 rear fuselage. I agree that you should lighten and simplify whenever possible. One reason not to do anything is that the panels make quite a racket as buffeting occurs near stall. Maybe this is just another genius of Chris Heinz? thanks everybody for the discussion tom |
massophobic?
-- Dan D. .. "Ernest Christley" wrote in message . com... Blueskies wrote: How about cork? Probably too heavy... And absorbs water. If it wasn't heavy when you put it in, it will be after you fly through the first cloud. Whatever you use, make sure it is HYDROPHOBIC (a word I learned about in RAH) -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
