FlyWIthCE FR300 vs LXNAV Nano for OLC and Silver/Gold badge flying
Old February 27th 14, 01:22 PM posted to rec.aviation.soaring
C-FFKQ (42)
Default FlyWIthCE FR300 vs LXNAV Nano for OLC and Silver/Gold badge flying
On Wednesday, 26 February 2014 21:08:06 UTC-5, wrote:
so that would be with the Nano. With the FlyWithCE, that highest tow gets knocked down to 2092.2 msl. Margin is a bit tighter - I'm usually heading for the IP at 2000 msl. Should that be a consideration ? Or should I be tasking a longer destination or an out and back so that my tow release can be higher ?
Well, you could just decide not to submit the FlyWithCE trace at all ! If you're planning on landing at the destination, release at the appropriate height to do the flight and get a tow-pilot release signature on the claim form. Given a certified release height and a known landing point distance, you'd be fine without submitting the trace.
- John
Old February 27th 14, 02:42 PM posted to rec.aviation.soaring
Cookie
You actually don't even have to do that. You can tow high, start high...only then you have to finish high.
Cookie
You can take a tow to whatever height you like. Your start height is the
lowest point after release and before the commencement of the task. If you
take a high tow you just have to get a low point before starting
Old April 14th 14, 03:43 AM posted to rec.aviation.soaring
On Saturday, February 1, 2014 6:25:35 PM UTC-5, Doug wrote:
What are the inexpensive devices for logging Silver and Gold badge flights, and how do they compare - costs / ease of use / reliability, etc ? I will be working on my Silver badge this season, using a rented glider, so I need an inexpensive, portable, and easy to use setup. It seems to me that the FR300 is priced much lower than the others, but there must be more to it than just price. Thanks.
Doug
I used a flywithCE to log a glider flight where the attempt was to stay local and just reach the silver altitude of 3281'. I was successful with the altitude. I had an observer and filled out all the paperwork prior to the flight. I later found out that I can't use my flywithCE for the silver alt because I didn't declare this attempt using the logbook software (that's not user friendly) prior to going to the airport. I declare that the flywithCE is a waste and that I should have taken that $130 and applied it toward a real flight logger. I turned the thing on and it recorded my flight which doesn't count because I didn't declare it with software. How the heck to you declare on any software that you're going to go out and fly 5 hours or go out and climb 3281' after tow? The badge program is really confusing and I have yet to find anyone who has a good knowledge base. The most challenging part of soaring shouldn't be the mazes created by the bureaucracy to prove you did something. I can see why there is rarely talk about badges in our club. I think a lot of glider pilots have lost interest due to the complications and expense to prove something you did so you can get pin to stick in your wife's jewelry box. Does anyone want a good deal on a flywithCE?
Old April 14th 14, 07:22 AM posted to rec.aviation.soaring
darrylr
Doug
Unfortunately almost everything you wrote make no sense, and with that level of confusion you are not likely to get anywhere. So stop, take a deep breath and start over with understanding the rules. Read and understanding the sporting code yourself, and the approval document for whatever recording device you are using. Don't waste time with someone else's summary etc.--read and understand the actual FAI IGC SC3 sporting code and Annex C (Pilot and OO Guide) and the approval document for your position/flight recorder.
I'm not sure who is helping you understand what went wrong with your past silver altitude claim but you still seem to have a jumbled understanding here. Did you submit a claim and it was rejected? The explanations back from the SSA are normally very helpful, are you sure you are reading it correctly?
For example ... there is no declaration required for any altitude badge flight. If somebody is telling you there is, ask them the exact rule section number that requires this for an altitude flight. I'm suspecting you might mean that the glider or pilot info part of the declaration in the IGC file was incorrect? I'm expecting with the right OO actions and explanation that the SSA would ignore that--it is clearly the IGC's intent that errors like that even if a declaration is required do not unnecessarily result in the denial of award of a silver or gold flight performance (e.g. SC3 Annex C 6.5). And since no declaration is required for an altitude gain I'm not sure why there would be a problem here. So who thought there was a declaration required? And if basic info in an electronic declaration was wrong when your OO explained that to the SSA what exactly happened?
Again as has been advised here many times, *if* a declaration is required (and its not for your altitude flight) most pilots are much better off forgetting the electronic declaration and making a paper declaration that is more recent than any electronic one and that paper declaration will override everything (SC3 Annex C describes using a paper declaration to override electronic ones). I'm also missing how having a full ICG approved flight recorder would change any declaration related things here (but yes they are nicer for other reasons).
To the best of my knowledge the SSA has never approved the FlyWIthCE for altitude gain purposes (and based on my undemanding of that device, that is for very good reasons). A quick search and I think the current approval document is http://www.ssa.org/files/member/SSA_...%20%283%29.pdf. If that is not it then find the approval document that applies to your device. The approval document read in conjunction with SC3 defines the rules you have to follow. So how were you hoping to demonstrate any altitude gain? Were you also flying with a separate barograph?
And even if your GPS position recorder was approved for use for altitude gains then you need to include a 100m margin must be added (SC3 A7).
You have to read and undertand the rules. Print them out and spend a few hours reading them, it helps to have the definitions part in front of you as you read every rule and carefully look up the precise meaning of each term, don't just assume what anything mean. Read through the whole thing a few times and you should have an "a-ha moment" where it should become clear. If you can't get there, find help or give up now. The random walk approach of just taking flights and hoping things will work out often ends in tears. Likewise asking random idiots at the gliderport to be your OO also often ends in tears, it is really worth finding somebody who knows what they are doing, ask around locally to find out who has their diamonds or above (or even better some records as well) and see if they can be your OO or help you understand the rules. All these finicky rules etc. *are* a part of these things, and they are really not that bad once you 'get' how things work. if you don't want to deal with that minor hassle them then by all means go do somethign else in the glider for fun. Chasing badges is often a neat learning challenge and worth spending the effort on, but lots of folks get a huge amount out of this sport without doing them.
Darryl
Old April 14th 14, 12:52 PM posted to rec.aviation.soaring
Cookie
As I read the "rules" (see below) the Fly with CE IS approved for all phases of silver and gold badge flights. The altitude requires a 100 meter "extra margin".
It is my understanding that a "declaration" would only be required for distance badge flights. Altitude or duration flights do not require a "formal" declaration. BUT with flight recorders, you do have to have certain information programmed in...such as pilots name...glider info etc...
We have two Fly with CE units which we use at our commercial operation....we like them very much...they are well worth the (low) cost. The clubs I am in have purchased Cloibri, which also work great, but the cost is huge.
Erik Mann has worked very hard over the years to get "affordable" GPS units approved for badge and record flights.
The $130 Fly with CE is far more sophisticated than the old baragraph and camera set up we used to use back in the day....And if I remember correctly a Replogle baragraph cost around $650 back then...a Winter cost more!
Yeah, the "rules" for the silver badge flights seem to be overcomplicated.....in fact the silver badge is more complicated than the other badges....ALL of the required information is available with an Internet search...SSA web site etc. Lots of us have somehow struggled through and achieved the Silver badge, in spite of the paperwork!
Cookie
IGC Position Recorder PR -1- Approval Document 2013-6
Approval document for an IGC Position Recorder
Issuing Authority: Soaring Society of America (SSA)
Erik Mann, SSA FAI Badge and Record Chairman -
Date of effect: 01 June 2013
References:
A. FAI Sporting Code Section 3 (Gliders and Motor Gliders) (SC3)
Particularly: SC3 Appendix A to Chapter 4 on Position Recorders
B. Annex B to the Code (SC3B), Glossary items on Position Recorder and Validation,
and paras 1.7, 2.1.1.2, 2.2.2.
C. Annex C to the Code (SC3C), particularly para 6.1 and 6.2, also 1.1, 1.5, 3.3.
D. Specification for the IGC file format, Appendix 1 to the
Technical Specification for IGC-approved Flight Recorders
1.1 This document authorises the use of the GPS recording device described in para 2 for use as an
IGC Position Recorder (PR) for flights under the jurisdiction of the above NAC under the rules and
procedures for PRs in the FAI Sporting Code Section 3 (Gliding), in particular under References A-D
1.2 Silver and Gold Flights. At the date of publication of this document, Reference A allows IGC
Position Recorders to be used for flights for Silver and Gold IGC Badges. For other badge, diploma
and record flights, an IGC-approved Flight Recorder must be used, and can also be used for Silver and
Gold flights.
1.3. Scope. This document covers only the PR recording function and the data in the IGC-format file
that is downloaded from it (Reference D and 3.3 below). Other functions in the PR and other modules
that can be connected, are not the responsibility of the NAC or IGC.
Type of IGC Position Recorder
2.1. Name of Position Recorder: flyWithCE Flight Recorder FR300
Manufacturer: Name: flyWithCE
Address: Ulica Lojzeta Hrovata 9, 4000 Kranj, Slovenia
Tel/Fax: email:
web: www.flywithce.com
Contact name(s): Uroš Podlogar s.p
2.3. Details of the PR.
IGC Position Recorder PR -2- Approval Document 2013-6
3. Compliance with the IGC Sporting Code. This type of IGC Position Recorder complies with the
Sporting Code requirements for Position Recorders (References A-D above) as follows.
3.1. The WGS84 ellipsoid Earth Model is used for all fixes in the IGC file (SC3 Chapter 4 para A2 refers).
3.2. All fixes in IGC files downloaded from this Recorder are all obtained from real-time GPS data, and no
predicted fixes are recorded (SC3 Chapter 4 para A3 requirement). If signal is lost, the device does not
project position or otherwise use any predictive model.
3.3. The downloaded IGC file can be electronically validated at any time to ensure that the file is identical to
when it was initially downloaded (SC3 Chapter 4 para A6 requirement).
3.3.1 Downloading. IGC files are downloaded directly from the FR via USB; the device is recognized as USB
Mass Storage media.
3.3.2 The file validation program - to be used with such downloaded IGC files:
VALI-FWC.EXE and associated DLL are available from the manufacturer’s download page:
www.flywithce.com/download.html
3.4. Recording of Altitude. References: SC3 Chapter 4 para A7, Annex C to SC3 para 6.2c, Reference D.
3.4.1 Altitude data from this IGC PR - for accurate measurement is from figures in the IGC file for GPS altitude
above the WGS84 Ellipsoid, applying the margin over Pressure Altitude requirements as specified in the Sporting
Code (Reference A), currently 100 metres due to the different characteristics of GPS and Pressure Altitudes.
3.4.2 The IGC file – Field for Pressure Altitude. In IGC files from this type of Position Recorder, the field for
Pressure Altitude is recorded as Zero, in accordance with SC3C para 6.2 and Reference D,
4. Engine Recording. This PR is not able to detect the operation of a Means of Propulsion (MoP). For
gliders with a MoP, SC3 4.5.4 and SC3C 12.1 apply, and one of the following must be carried out:
4.1. Carry a separate device that records MoP use and is acceptable to the NAC, or:
4.2. Seal the MoP is such a way that the Official Observer can detect if it has been operated, or:
4.3. Disable the MoP prior to flight to the satisfaction of the Official Observer and NAC.
5. Mounting in the Glider. This Position Recorder may be mounted anywhere in the glider, and the
Official Observer must be able to show that it was in the glider for the flight concerned, and that the IGC
file used to assess the flight came from it.
6. Authority. This approval document is issued by The Soaring Society of America (SSA).
Signature Erik H Mann
Name: Erik H. Mann
Position in NAC: Chairman, SSA FAI Badge and Record Committee
Email address:
Any queries or comments about this document should be sent to the above, with a copy to the
Chairman of the IGC GFA Committee (currently:
Old April 14th 14, 01:42 PM posted to rec.aviation.soaring
I am a proponent of badge flying A,B,C, Bronze, Silver etc. They require forethought, planning and execution. All activities that require more skill, both organizational and aerodynamic than just boring holes in the airport sky. Frustration arises when pilots happen upon a flight that otherwise would qualify for a badge or badge leg yet the "planning" part of the equation was skipped. I understand the desire to have the particular flight memorialized with a badge issuance by the SSA. However, there will be other prime days in the future and this time make sure "all" the bases are covered.
The altitude "declaration" only references the IGC file header. You must have your personal and aircraft information in the header so the badge dude can positively identify your flight. This is a very basic requirement yet even last year a very accomplished pilot complained loudly because his 300k flight was not recognized due to a mistaken use of competition number instead of registration number in the header.
Please don't give up on badge flying because of a perceived inflexibility of the rules. Just take a moment to read the rules and prepare accordingly. The badge will be with you for a lifetime. The accomplishment is what makes it special. If the badge dude sent one hundred silver badges to your club to be handed out at the next meeting to anyone who "said" they had the proper altitude gain there would be no special meaning to the accomplishment. Stick with it and you will be rewarded with a badge in the mail. Wear your badge proudly so others will strive for the same.
Lane
XF
Old April 14th 14, 02:48 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Sporting Code 3, 2014, 3.4.a:
a. No declaration is required for a duration or gain of height badge flights that use only a PR or a stand-alone barograph for evidence (SC3-1.4.2), or for a straight distance flight so long as no pre-declared start or finish point is used (SC3-1.4.3).
If the header is incorrect, club records and OO proving which glider and pilot launched when should suffice...
Sporting Code 3, 2014, para 6.5:
Pilot and glider data Pilot and glider data stored in a PR or FR is not definitive until confirmed by the OO from independent evidence taken at take-off and landing. When any shared FR is used, pilot and glider data
may be from a previous flight, so care must be taken to see that the pilot and glider data is accurate; however, an error may be corrected by the OO for Silver and Gold badge claims.
Given this, have your OO correct the data, and submit... The sporting code is your friend.
2D
  #29
Old April 14th 14, 11:25 PM posted to rec.aviation.soaring
Darryl Ramm
Thanks for that, that approval is for the FR300 so it depends on the exact
position recorder being discussed for that silver altitude flight. But the
most important point is up to the pilot (and OO) to read and understand the
approval document for a position recorder (or flight recorder) and read
them in conjunction with the sporting code and annexes.
As multiple people are pointing out, yes you do not need a declaration for
an altitude flight, and if basic things like pilot name etc. are wrong in
the IGC file this is usually handled by enclosing a note from the OO. And
if this flight was actually submitted to the SSA I would have expected a
nice clear explanation of problems. So I am totally at a loss what the
problem in the silver altitude flight was.
/* snip */
Darryl
  #30
Old April 14th 14, 11:51 PM posted to rec.aviation.soaring
Papa3[_2_]
Having spent over 10 years on the SSA's Badge and Record Committee including several years as the chairman, I've seen many frustrated pilots over the years. Having recently "retired" from that program, I can speak here as an unofficial commentator. In reality, there's usually plenty of blame to be spread around.
On the one hand, you have people who have some very vague idea of various performances who show up and do just about everything "wrong" from a procedures perspective. Sometimes, they get lucky, and they've done just enough "right" to skate by. I can't tell you how many times we got files (even under the "supervision" of supposedly experienced OOs) that amounted to "I just made a really cool flight. Here's the IGC file. Now tell me what I've won". The OO is primarily responsible for making sure you follow procedures and that your performance(s) meet the requirements.
On the other hand, we have a Sporting Code with several annexes and annexes to the annexes in the form of individual FR approval documents. As an outgrowth of that, we have people trying (and often failing) to write simplified summaries. I've read the entire SC cover-to-cover literally dozens of times, yet I still find loopholes and uncovered scenarios. So, while a close read is important, it's still not a guarantee that even a conscientious pilot won't get caught up.
The best advice I can give is: 1) put a simple plan together well before you intend to start doing badges. For instance, if your goal is to get a silver badge, work to understand just that portion of the SC and build a few flight options to meet those requirements 2) find a "real" OO who understands the SC. They don't have to know how to quote it chapter-and-verse (in fact, I'd be very scared of anyone who could). They just need to be able to find the relevant sections in the SC and check your plan. And, if such a person isn't around locally, ask for help from the Badge Guy (Rollin Hasness). Even if he doesn't have time to completely spoon feed you, he can usually help you find someone locally. As a last resort, you can try to find someone on this forum who will work with you offline. Just be sure you hook up with someone who is a real expert and not just R.A.S. pundit.
Erik Mann (P3)
Hitlers application for Gold Badge rejected! Allan[_4_] Soaring 8 November 22nd 11 10:29 PM
LXNAV Nano and LX 9000 Overview Videos Available Paul Remde Soaring 3 February 28th 11 02:58 PM
IGC-approval of the LXNAV Nano GNSS Flight recorder Ian Strachan Soaring 5 September 1st 10 03:41 PM
OLC Gold / Silver League?? Grider Pirate Soaring 4 June 8th 10 04:00 AM
Silver/Gold Duration Question Dixie Sierra Soaring 11 May 30th 07 12:06 AM
