Results*of*Flight*Performance*Determination*o f*the*Lak‐17a*FES
Old February 25th 14, 04:23 AM posted to rec.aviation.soaring
Default Results*of*Flight*Performance*Determination*o f*the*Lak‐17a*FES
the idea of a penalty for being a motor-glider is absurd. an asg29e does not get an additional handicap penalty because it has a motor last i checked.
the idea that a motor somehow provides an advantage is subjective fantasy.. no other motor-glider gets a penalty for being a motor-glider alone. again this logic is absurd. but please, show us your examples.
Sean
I don't know where you have been the last 29 years, but the first sports class nationals was in 1985 and mg/sustainer versions have always had higher handicaps than pure gliders. Read the hc list first and then comment. ASG29e is .01 higher than ASG29. The additional wingloading is the advantage, not the motor, and these HC's have been working very well for a long time.
Rick Walters
Old February 25th 14, 02:35 PM posted to rec.aviation.soaring
Sean F (F2)
Rick,
My point is that there is no handicap penalty for "being a motor glider". The only factor that is measured in the handicap calculation is the additional weight of the motor equipment. The FES is a new situation in which it has both additional weight AND IMPORTANTLY it also has a significant, measured aerodynamic disadvantage which needs to be taken into consideration objectively when considering its handicap.
In this case, if you run the numbers, the FES handicap for the Lak17bFES is only considering the additional weight (75lbs not 135 I think boys). Regardless, no consideration or calculation has been factored in (current US handicap) to compensate for the aerodynamic drag penalty of the system (propellers, etc). These propellers effect the Lak17bFES performance each and every second it flies in contest flight. It should also be considered in the handicap ALONG WITH the extra weight.
I think the current handicap is incomplete and unfair to owners of the Lak17bFES and highly discouraging to potential new owners or those considering a modification to a current pure glider.
Sincerely,
Sean
Old February 25th 14, 03:20 PM posted to rec.aviation.soaring
On Tuesday, February 25, 2014 8:35:19 AM UTC-6, Sean F (F2) wrote:
Rick,
Sincerely,
Sean
Duly noted, Sean. Way too much noise on a 2% handicap change that nobody besides yourself gives a flip about. A couple of years ago the handicap on my LS8 was changed from .925 to .915, no idea why. Rather than screaming like a little girl about it I just concluded that - just like a fine wine - my glider is getting better with age. No conspiracy here, Sean, move along..
Herb
Old February 25th 14, 03:21 PM posted to rec.aviation.soaring
On Tuesday, February 25, 2014 9:35:19 AM UTC-5, Sean F (F2) wrote:
Rick, My point is that there is no handicap penalty for "being a motor glider". The only factor that is measured in the handicap calculation is the additional weight of the motor equipment. The FES is a new situation in which it has both additional weight AND IMPORTANTLY it also has a significant, measured aerodynamic disadvantage which needs to be taken into consideration objectively when considering its handicap. In this case, if you run the numbers, the FES handicap for the Lak17bFES is only considering the additional weight (75lbs not 135 I think boys). Regardless, no consideration or calculation has been factored in (current US handicap) to compensate for the aerodynamic drag penalty of the system (propellers, etc). These propellers effect the Lak17bFES performance each and every second it flies in contest flight. It should also be considered in the handicap ALONG WITH the extra weight. I think the current handicap is incomplete and unfair to owners of the Lak17bFES and highly discouraging to potential new owners or those considering a modification to a current pure glider. Sincerely, Sean
Then write to the handicap committee and make your case instead of campaigning on RAS which is not part of the process.
It appears to me, possibly incorrectly, that the report on this was only published very recently. I see a 1/14 date on it. If that is so, it was not really available as part of the HC consideration this year. Additionally, they would likely not be aware of it unless an affected person brought it up.
Use the process.
UH
Old February 25th 14, 04:53 PM posted to rec.aviation.soaring
Sean F (F2)
will do. thanks hank.
Old February 26th 14, 03:26 PM posted to rec.aviation.soaring
Sean F (F2)
Where can I find the contact info for the Handicap Commitee? I just looked on the SSA website and could not find anything. Did I miss it?
Old February 26th 14, 03:29 PM posted to rec.aviation.soaring
Sean F (F2)
Herb,
Thanks for your opinion. Brilliant as usual.
Sean
Old February 26th 14, 03:50 PM posted to rec.aviation.soaring
Dave Leonard
Direct link:
http://www.ssa.org/Volunteers
You will need to sign in.
Look for
Contest Handicapping Committee
Or through the menus
The SSA|About the SSA|Governance|Other Volunteer Committees
  #29
Old February 27th 14, 02:56 AM posted to rec.aviation.soaring
Sean F (F2)
Thanks Dave.
All, here is a video on the FES performance testing: https://www.youtube.com/watch?v=o0twY9cWOUg
Direct link:
Look for
