#21
Dale,
Always. I fly from a turf field....stationary runup is bad for the prop. How? If it were dirt, I might understand, but turf? Being on grass the speed doesn't become a big issue...no need to hold brakes during the checks. I disagree, strongly. Going with 2000 rpm, our Tobago would move like a rocket on our turf field. -- Thomas Borchert (EDDH) |
Ajw,
There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. You do mean, don't you, referring to your sign off, subject to the limitation "sith your clothes on"? Ah, to be young again ;-) -- Thomas Borchert (EDDH) |
On Tue, 29 Jun 2004 08:38:23 -0800, Dale wrote:
Always. I fly from a turf field....stationary runup is bad for the prop. Once rolling I come up to 1700 for the mag check, then back to idle to control speed.....up to 2000 for a quick prop check. Being on grass the speed doesn't become a big issue...no need to hold brakes during the checks. Wow. I think I will leave that one for the next life. I fly from a turf field too. The only time the surface has ever been an issue is when a 172 driver was taxiing too fast and dug up some stones with his prop. We do have the occasional walk-through by the Boy Scouts, who pick up stones and stuff. I suppose the scout-master is a pilot. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! weblog www.vivabush.org |
![]() Thomas Borchert wrote: Ah, to be young again ;-) This time with money. :-) George Patterson None of us is as dumb as all of us. |
Cub Driver wrote: I fly from a turf field too. The only time the surface has ever been an issue is when a 172 driver was taxiing too fast and dug up some stones with his prop. In a taildragger it wouldn't be a problem. I'm flying a 206, even on grass you'll pick up some dirt/small stones that erode the prop. At $8K a prop it just isn't worth it. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Thomas Borchert wrote: How? If it were dirt, I might understand, but turf? There's dirt under that grass. Even water can erode a prop, imagine what dirt or small stones can do. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Thomas Borchert wrote: I disagree, strongly. Going with 2000 rpm, our Tobago would move like a rocket on our turf field. Have you tried it? Sure, you'll be moving faster than a "walking pace" taxi, but not so fast as to be a hazard. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
![]() I'm flying a 206, even on grass you'll pick up some dirt/small stones that erode the prop. is it really the prop that picks the stones up? Anybody studied the physics involved? Jose -- (for Email, make the obvious changes in my address) |
#30
I do on occasion when the situation warrants. But that's not very often.
Turning a little sideways on the taxiway and just doing it really doesn't take that long. Switches and other checks can be done on the roll while taxiing. "G. Burkhart" wrote in message news:lk6Ec.1801$AI.68@attbi_s04... When I did my training my CFI taught me to stop at the run-up area and go through the run-up checklist. This was done at airports that had run-up areas readily available. Fairly recently, I went with an instructor that taught me to do a run-up during taxi on airports that don't have a run-up area or require back taxi on the runway. Some of the local airstrips have narrow (or no) taxiways and they lead right to the runway with little room to stop to do a run-up so I've gotten into the habit of doing the run-up while taxiing. I make sure to check outside to where I'm going while checking the mag drops, etc. That way I'm ready for departure by the time I get to the runway, which is helpful when others are following behind me on the taxiway, especially during fly-ins. Some airports require back taxi on the runway from the ramp/taxiway and I'll do the (stopped) run-up before getting on the runway or a run-up during the back taxi so I'm ready to go when I turn around for departure. Do you do 'running' run-ups? |
C-182 carb-heat causing rough running. | R.T. | Owning | 11 | November 26th 04 10:50 PM |
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE | Karsten | Home Built | 0 | September 3rd 04 07:34 PM |
Rotax 503 won't stop running | Tracy | Home Built | 2 | March 28th 04 04:56 PM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
