#21
"Anytime you blow something at the apex, cut
the power, let the nose come through, recover and do it again." Funnily enough, that's the one part I'm getting really good at! I learned early on that the Pitts is actually pretty docile and if I find myself with no energy and just basically tumbling or falling out of a maneuver, cut the power, ease any pressures on any surfaces, the nose eventually comes down, and she more or less sorts herself out. Two things required for that to work: altitude to do it, patience to wait for it. It's kind of a weird feeling knowing that, for a few seconds, you're merely cargo while the laws of nature reassert their pre-eminence. What I've had happening in my HHs is exactly as you describe. Formerly I'd get to the apex, usually with full right aileron in, kick left rudder and she'd roll over on her back, coming out of the maneuver vertical but about 60 degrees left of axis. Nothing I was doing with aileron or timing seemed to work. So I started doing it just as above, but smoothly reducing power as the nose slices, and that seems to have resolved the problem. They're still not bang on, but I'm coming out only a few degrees off axis, which I think is solvable, and certainly wouldn't give me a zero in a comp. I just can't stand being beaten by a figure that's considered a pretty basic one! Display sequence is coming on. Hope to practice some more this weekend if the weather cooperates. I'm not ready to go for the DA yet, but a couple more sessions and some more coaching and I think I'll be there. Shawn What kind of flying to you get up to these days, Dudley? "Dudley Henriques" wrote in message ink.net... "ShawnD2112" wrote in message ... It'll take me a couple of times to digest what you've written here, Dudley, but I think I understand. So far, I'm not using any forward stick on hammerheads and the amount of aileron I need seems to vary with each flight (could it be weight dependant?). Thanks again for the tips! Shawn On the weight; in my opinion, no. You are probably doing it right and not carrying power into the apex far enough to require a counter for the precess. You would know this right away, as the nose would want to come directly back into you throwing you off line. Off the top of my head on HH's. Just remember I haven't been doing them for a while now!!! :-)))) At the apex on a HH, you have several forces in play at once, depending on the power in play when you reach the rotation point. You're carrying a ton of power up the vertical line to extend and as airspeed decreases, this power really begins to effect the airplane. Basically, torque wants to pull you left; and in the slice down, asymmetric lift wants to roll you left and precession (if you still have the power in) is in play from the prop disk. The forward stick counters the precession. Note that if you have cut the power, you have basically settled the precess problem!! Usually, if your timing is just right, you have just a bit of forward stick required at the apex just before you throttle back. It's a touchy inter-relationship between the forces and the required control pressures. The main thing in the Pitts is how close to inverted flat spin pro controls you are with power on the airplane at the apex coupled with whatever forward stick you need to counter the precess from the prop. Visualize the nose wanting to come straight back into you from the precess and you'll see right away why you need the forward stick. The main thing to remember is that with a HH, inputs are basically sequential rather than all at once. The big issue is neutralizing on the downside. Whatever you do in a Pitts, don't carry forward stick and full rudder with power too far into the slice at the apex. The good side of all this is that if you're doing it right, you're cutting the power before you reach the critical point with forward stick and the problem is solved. Anytime you blow something at the apex, cut the power, let the nose come through, recover and do it again. Dudley |
![]() "ShawnD2112" wrote in message ... "Anytime you blow something at the apex, cut the power, let the nose come through, recover and do it again." Funnily enough, that's the one part I'm getting really good at! I learned early on that the Pitts is actually pretty docile and if I find myself with no energy and just basically tumbling or falling out of a maneuver, cut the power, ease any pressures on any surfaces, the nose eventually comes down, and she more or less sorts herself out. Two things required for that to work: altitude to do it, patience to wait for it. It's kind of a weird feeling knowing that, for a few seconds, you're merely cargo while the laws of nature reassert their pre-eminence. Sort of like a coupled spin entry. Really gives you that "IN CONTROL" feeling doesn't it? :-))) What I've had happening in my HHs is exactly as you describe. Formerly I'd get to the apex, usually with full right aileron in, kick left rudder and she'd roll over on her back, coming out of the maneuver vertical but about 60 degrees left of axis. Nothing I was doing with aileron or timing seemed to work. So I started doing it just as above, but smoothly reducing power as the nose slices, and that seems to have resolved the problem. They're still not bang on, but I'm coming out only a few degrees off axis, which I think is solvable, and certainly wouldn't give me a zero in a comp. I just can't stand being beaten by a figure that's considered a pretty basic one! Actually, a good HH is not all that easy to do. The control pressure sequence varies from airplane to airplane and the timing is as exact as any maneuver you'll ever fly. Sounds like you're getting a handle on everything :-) Display sequence is coming on. Hope to practice some more this weekend if the weather cooperates. I'm not ready to go for the DA yet, but a couple more sessions and some more coaching and I think I'll be there. Sounds great. best of luck, and let me know how things are going. Shawn What kind of flying to you get up to these days, Dudley? Well, I'm still quite active as a consultant to various interests in the fighter community in the United States and I also consult on flight safety issues from time to time within the flight demonstration community, but I'm afraid my active flying days are about over. I lost the vestibular system in my right ear and have a severe balance problem above 1g. Basically what that means is that I have to allow you "younger types" out there to have all the the fun while I just watch and critique what you're doing! :-) Dudley "Dudley Henriques" wrote in message ink.net... "ShawnD2112" wrote in message ... It'll take me a couple of times to digest what you've written here, Dudley, but I think I understand. So far, I'm not using any forward stick on hammerheads and the amount of aileron I need seems to vary with each flight (could it be weight dependant?). Thanks again for the tips! Shawn On the weight; in my opinion, no. You are probably doing it right and not carrying power into the apex far enough to require a counter for the precess. You would know this right away, as the nose would want to come directly back into you throwing you off line. Off the top of my head on HH's. Just remember I haven't been doing them for a while now!!! :-)))) At the apex on a HH, you have several forces in play at once, depending on the power in play when you reach the rotation point. You're carrying a ton of power up the vertical line to extend and as airspeed decreases, this power really begins to effect the airplane. Basically, torque wants to pull you left; and in the slice down, asymmetric lift wants to roll you left and precession (if you still have the power in) is in play from the prop disk. The forward stick counters the precession. Note that if you have cut the power, you have basically settled the precess problem!! Usually, if your timing is just right, you have just a bit of forward stick required at the apex just before you throttle back. It's a touchy inter-relationship between the forces and the required control pressures. The main thing in the Pitts is how close to inverted flat spin pro controls you are with power on the airplane at the apex coupled with whatever forward stick you need to counter the precess from the prop. Visualize the nose wanting to come straight back into you from the precess and you'll see right away why you need the forward stick. The main thing to remember is that with a HH, inputs are basically sequential rather than all at once. The big issue is neutralizing on the downside. Whatever you do in a Pitts, don't carry forward stick and full rudder with power too far into the slice at the apex. The good side of all this is that if you're doing it right, you're cutting the power before you reach the critical point with forward stick and the problem is solved. Anytime you blow something at the apex, cut the power, let the nose come through, recover and do it again. Dudley |
ELT antenna-- Pitts | Al MacDonald | Aerobatics | 0 | July 15th 04 03:27 PM |
Advice on flying Pitts with Haigh Locking Tailwheel | Ditch | Home Built | 19 | January 4th 04 10:18 PM |
Pitts Fly-In | aerogirl | Aerobatics | 0 | October 27th 03 11:45 PM |
Pitts, Acro Sport, other to buy? | Dave Swartz | Aerobatics | 0 | September 3rd 03 03:18 PM |
Pitts Special - info and photo's required. | Darryl Gibbs | Aerobatics | 1 | August 5th 03 08:05 PM |
