#21
Hi Richard, thanks for joining the discussion, read below...
Richard Lamb wrote in message ... SHOCK waves, not sine waves. Any periodic signal (or sound) can be thought of as an infinite sum of the harmonics of the fundamental. Even complicated waveforms. and more harmonics than a '60's rock band! Yup, lots of harmonics, each one containing its portion of the sound power. The higher the harmonic, the less power it generally contains. AND, to make it work, they ALL have to be exactly (there's the E word) and perfectly (the P word too) (I _could add Absolutely and score 3 for 3!) 180 out of phase? Its really a matter of degrees (pun intended), the closer to 180 you get, the better the cancelation, but its not an all or nothing kind of thing. For example, a 170/190 degree phase shift cancels 98%. |
There is really only one problem with your cancellation idea. To work in all
directions the sounds have to come form the same point in space. If they are not the same, all you can do is local cancellation or an interference pattern with some areas silent and some twice as loud. Just take two points and start drawing circles around each. The intersections will form lines of interference. The PDE's are harder than pulse jets since the detonation wave is supersonic. You exceed what you might call the ellasticity of the air and I don't know if linear theory (like Fourier) will apply. There is probably a dramatic discontinuity and Fourier requires at least piece wise continuity. But I have not looked at shock physics in a long time. Sombody on RAM would know, like Marry Shafer. -- Charlie Springer |
LOL also...
But that twice as loud assumes that the sounds will 'sum'. If the argument that the sounds cannot subtract, then they should be just as hard to sum.... -- Dan D. .. "DJFawcett26" wrote in message ... LOL - personally, I suspect if you use two pulse jets to cancel, all that will happen is you will have a pulse jet twice as loud! But then again, I am not a noise expert ..... well sort of I guess, I know how to make it. |
"Blueskies" wrote:
LOL also... But that twice as loud assumes that the sounds will 'sum'. If the argument that the sounds cannot subtract, then they should be just as hard to sum.... Think "double-barrel shotgun". Mark Hickey |
You can do it when you're only producing real low fundamental frequencies
and can control the phase. In a pulse jet or any kind of rocket motor, it's a ton of high-frequency broad-band noise. You might be able to control one or maybe two frequencies (assuming they are correllated), but forget about the rest of the junk. "AL" wrote in message ... Submarines use a device (the name escapes me just now) to do exactly what you guys are talking about. |
I made a device once to allow me to talk to an individual in a crowd from a
distance. I used an array of small speakers and DSPs to produce delays for each one so that it acts like a phase array RADAR and the central beam can be directed electronically with no motion of the array. The most difficult part is that the signal has to be spectrally broken down and delays calculted for each speaker AND each frequency. This is aproblem in reinforcement. The same applies to candellation. Look up "reciprocity callibration" for an idea of how complicated it is. As for summing, there is nothing mysterious. If you put two engines near each other you will sum in some places and cancel in others, but the location varies with frequency so finding silence is probematic though there may be a "sweat spot" if everything works out. There is also likely to be sum and difference frequuncies and (and more if the rsponse is nonlinear). The difference or beat frequency is the difference between two frequencies, so if the engines are not perfectly synchonized you will get a beat. If one is at 101 and one at 100, you get a nice loud 1 Hz beat as any of yo uknow from synchonizing a twin in a pane or boat. -- Charlie Springer |
I guess you're talking about interference patterns and such. All that stuff
is irrelevant. The noise coming from a pulse jet will only have a couple of periodic components. The rest is a bunch of quasi-random, aperiodic noise resulting from some extreme turbulence. While turbulence phenomena are chaotic in nature and not truly random, you might as well treat them as random for this case. You never get a periodic interference pattern setting up. "Regnirps" wrote in message ... As for summing, there is nothing mysterious. If you put two engines near each other you will sum in some places and cancel in others, but the location varies |
#29
The spectrum of the sound from the engine does indeed have several
strong harmonics that rise up from a random noise floor. I think you'd be able to cancel the periodic components of the noise leaving the random part behind. If I had to guess, you'd get rid of the buzz and be left with the roar. So with cancelation it might be similar to a jet turbine in sound. Regards p.s. As far as synchronization, if I understand correctly, most of the simple forms of these motors are started with a spark, but then carry on self sustained operation at the natural frequency of the pipe. You could however use a spark to ignite the charge slightly early and thus force synchronization. "Pete Schaefer" wrote in message news:%gc6c.32308$J05.219351@attbi_s01... I guess you're talking about interference patterns and such. All that stuff is irrelevant. The noise coming from a pulse jet will only have a couple of periodic components. The rest is a bunch of quasi-random, aperiodic noise resulting from some extreme turbulence. While turbulence phenomena are chaotic in nature and not truly random, you might as well treat them as random for this case. You never get a periodic interference pattern setting up. "Regnirps" wrote in message ... As for summing, there is nothing mysterious. If you put two engines near each other you will sum in some places and cancel in others, but the location varies |
#30
"Jay" wrote in message
m... The spectrum of the sound from the engine does indeed have several strong harmonics that rise up from a random noise floor. I think you'd be able to cancel the periodic components of the noise leaving the random part behind. If I had to guess, you'd get rid of the buzz and be left with the roar. So with cancelation it might be similar to a jet turbine in sound. Regards p.s. As far as synchronization, if I understand correctly, most of the simple forms of these motors are started with a spark, but then carry on self sustained operation at the natural frequency of the pipe. You could however use a spark to ignite the charge slightly early and thus force synchronization. Okay, already! That's enough, "I suppose" and "I think". Build something and report back next Thursday. Documentation to follow within five days. Oral boards will convene at their convenience no less than two weeks after the thesis is finalized and submitted. Warning - the penalty for failure is severe! Miss Twyla Geeter. |
